this is the control for my parking heater.
Uno is main control and mega thermostat
have the Uno working.
Also have the mega working.
But if I operate the Uno with the push buttons it works 100%.
But if, for example, I get a start comando from the mega on the Uno, he is stuck in a few lines.
the Uno also runs more often when he is not connected to the mega.
would it be too much for an Uno and should I go to the mega?
this is when the Uno is manually operated:
myserial started START PROCEDURE: 1 - Ventilator HIGH - Glow Plug HIGH - H_L HIGH - Fuel Pump HIGH STARTEN MISLUKT gloeispiraal LOW brandstofpomp LOW START PROCEDURE: 2 - Ventilator HIGH - Glow Plug HIGH - H_L HIGH - Fuel Pump HIGH - Glow Plug LOW START PROCEDURE COMPLETEREADY FOR ANOTHER COMMAND
and here he hangs on the mega's comando:
myserial started a START PROCEDURE: 1 - Ventilator HIGHand does not do anything anymore to a reset!
standkachel_17_02_19_org.zip (17.3 KB)
Temperature_Control_17_02_19_org.zip (20.5 KB)
