i bought arduino Uno and datalogging module (SD card and RTC(DS1307) in one module). According documentation my module should comunicate with Arduino Uno using SPI (D10,D11,D12,D13) - SD card and I2C (A4,A5) - RTC.
I am able to write and read to/from SD card but i am not able to write/read RTC. I have read a few topics regarding DS1307 issues and i tried to fix it. Here is what i found/tried:
HW
I measured voltages on my DS1307 pins.
Ubat = 3,03V, Ucc = 4,45V
In DS1307 datasheet is written that it is not possible to read/write if Ucc < 1,25Ubat. In my case Ucc limit should be __1,253,03V = 3,79V__. I guess i should be able to read/write RTC because 4,45V > 3,79V.
On the other hand there are written recommended operation conditions and supply voltage (Ucc) should be at least 4,5V. And 4,45V < 4,5V. BTW power LED on datalogging module shines red.
Datashett DS1307
Do you think that my problem is low Ucc?
If yes, what should i do? How can i increase supply voltage on ready-to-use module?
SW
I tried to read/ write to RTC using this code (i tried enable/disable oscilator - write to RTC but result of all registers was 0 = i was not able to write to RTC). I found the code somewhere on this forum:
// DS1307 I2C Read and Write Timekeeper Registers 0x00-0X07
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68
#define startRegister 0x00
#define endRegister 0x07
//data storage registers 0X08-0X3F
Wire.begin();
Serial.print("Register");
Serial.print("\t");
Serial.println("Bit Values");
// writeNVRAM(0x00, B00000000);//enable oscillator and set seconds to 0
//writeNVRAM(0x00, B10000000);//disable oscillator set CH bit
for (int a = startRegister; a <= endRegister; a++)
byte b = readNVRAM(a);
Serial.print("0X");
if (a < 16)
Serial.print("0");
Serial.print(a, HEX);
Serial.print("\t");
Serial.print("\t");
for (int i = 7; i >= 0; i-- )
Serial.print((b >> i) & 0X01);//shift and select first bit, no speed advantage
void writeNVRAM(byte location, byte data)
// writes data to DS1307 NVRAM location
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.write(location);
Wire.write(data);
Wire.endTransmission();
byte readNVRAM(byte location)//// reads data from DS1307 NVRAM location
Wire.requestFrom(DS1307_I2C_ADDRESS, 1);
Wire.read();
Can be my problem I2C?
How can i test that I2C communication between UNO and datalogging module works?
How can i know that commands Wire.Write or Wire.Read works? Is possible to get some error code in case that Wire.Write or Wire.Read fails?
Thanks for answers and recommendations
