UNO Detecting 24 vac via TWO OF optocoupler (HCPL3700) not working
hi all.
I succeeded in detecting a change in state by obtaining a 24 VAC signal by referring to the forum above.
Note:
DIGITALWRITE(PIN13) = internal LED UNO
DIGITALWRITE (PIN12) = External LED on Breadboard
I want to do this.:
  1. Internal LED ON (PIN13) when 24 VAC is supplied to the first optical coupler.
  2. External LED ON (PIN12) when 24 VAC is supplied to the second optical coupler.
  3. Built-in LED off if no current flows through the second optical coupler (PIN13)
  4. Built-in LED off (PIN13) if no current flows through the first optical coupler
The problem is as follows:
One more optical coupler. Therefore, two source codes were duplicated.
The first optical coupler is the same as my expectations.
The second optical coupler does not detect any state changes.
THANKS!
const int sensorPin = 10;
const int sensorPin1 = 11;
const int ledPin =  13;
const int ledPin1 =  12;
int lastSensorState;
int currentSensorState;
int stateChangeCnt = 0;
int lastSensorState1;
int currentSensorState1;
int stateChangeCnt1 = 0;
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  pinMode(sensorPin, INPUT);
  pinMode(ledPin1, OUTPUT);
  digitalWrite(ledPin1, LOW);
  pinMode(sensorPin1, INPUT);
    /////////// 1st optocoupler
  currentSensorState = digitalRead(sensorPin);
  if (currentSensorState != lastSensorState)
    Serial.print(stateChangeCnt);
    Serial.print(" : ");
    Serial.print(currentSensorState);
    Serial.print(lastSensorState);
    Serial.print("\r\n");
    if (currentSensorState == HIGH )
    else if
    (currentSensorState != HIGH )
      digitalWrite(ledPin, HIGH );
    lastSensorState = currentSensorState;
    stateChangeCnt++;
    /////////// 2nd optocoupler
    currentSensorState1 = digitalRead(sensorPin1);
    if (currentSensorState1 != lastSensorState1)
      Serial.print(stateChangeCnt1);
      Serial.print(currentSensorState1);
      Serial.print(lastSensorState1);
      if (currentSensorState1 == HIGH)
      else if
      (currentSensorState1 != HIGH )
        digitalWrite(ledPin1, HIGH);
      lastSensorState1 = currentSensorState1;
      stateChangeCnt1++;
try reversing the LEDs
const int ledPin1 =  13;
const int ledPin =  12;
We need to see your schematic and wiring too.
You may need:
pinMode(sensorPin, INPUT_PULUP);
pinMode(sensorPin1, INPUT_PULUP);
yeah, result is just reversing LEDs.
but, i can only get an inverted ending.
must need schematic and wiring?
  pinMode(sensorPin, INPUT_PULLUP);
  pinMode(sensorPin1, INPUT_PULLUP);
    if (currentSensorState == LOW )
      digitalWrite(ledPin, HIGH);
    else if
    (currentSensorState != LOW )
      digitalWrite(ledPin, LOW );
    stateChangeCnt++;
      if (currentSensorState1 == LOW)
      else if
      (currentSensorState1 != LOW )
      stateChangeCnt1++;
when i removed footnote line, the code function properly. (LED is ON & OFF as my expectation)
  **if (currentSensorState != lastSensorState)**
**    Serial.print(stateChangeCnt);**
**    Serial.print(" : ");**
**    Serial.print(currentSensorState);**
**    Serial.print(lastSensorState);**
**    Serial.print("\r\n");**
    else if
    stateChangeCnt++;
      else if
      (currentSensorState1 == LOW )
      stateChangeCnt1++;
First of all, I'm not clear about whether you say now it's working? If not... Okay I need to back up. Have you tried simple sketches that prove that both sensors are working? You said the second one did not, so that is a good place to start. Eliminate the code that processes the sensor data, just echo it somehow, like serial. It sounds like you already tested both LEDs?
I don't know what a footnote line is. Did you try auto-formatting your code to highlight the code blocks? In the lines you've highlighted with a '**', there is an extra '{'. Maybe that has something to do with it.
It's instructive, as you say, when I took a step back and looked at the code again, I found a couple of screws missing.
The screws were "{" and "}" in the middle of the code.
    else if
    stateChangeCnt++;
      else if
      stateChangeCnt1++;
Status report, Scotty? Works, not works?
thanks! Now that I picked up all the screws, I could drive.
Great, fantastic!
