[Uno] Error while burning bootloader
I'm trying to install Marlin onto my Ender 3 Pro but when trying to burn the bootloader I'm getting this
Arduino: 1.8.15 (Windows 10), Board: "Sanguino, ATmega644 or ATmega644A (16 MHz)"
Error while burning bootloader.
And nothing else. I'm following this guide here, however I am using male to female instead of female to female DuPont wires, and they're hooked up to d10-d13, 5v and ground.
Help would be greatly appreciated.
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. Select File > Preferences from the Arduino IDE's menus.
  2. Check the checkbox next to "Show verbose output during: upload".
  3. Click the OK button.
  4. Select Tools > Burn Bootloader from the Arduino IDE's menus.
  5. After the Burn Bootloader process fails, you'll see a button on the right side of the orange bar: Copy error messages. Click that button.
  6. Open a forum reply here by clicking the Reply button.
  7. Click the </> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  8. Press Ctrl+V. This will paste the compilation output into the code block.
  9. Move the cursor outside of the code block markup before you add any additional text to your reply.
  10. Click the Reply button to post the output.
sure
D:\++Downloads\arduino-1.8.15-windows\arduino-1.8.15\hardware\tools\avr/bin/avrdude -CD:\++Downloads\arduino-1.8.15-windows\arduino-1.8.15\hardware\tools\avr/etc/avrdude.conf -v -patmega644 -cstk500v2 -Pusb -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "D:\++Downloads\arduino-1.8.15-windows\arduino-1.8.15\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
avrdude done.  Thank you.
The tutorial's author left out a very important step.
Select "Arduino as ISP" from the Arduino IDE's Tools > Programmer menu and then try burning the bootloader again.
That seemed to help part of the problem but now I have another error.
D:\++Downloads\arduino-1.8.15-windows\arduino-1.8.15\hardware\tools\avr/bin/avrdude -CD:\++Downloads\arduino-1.8.15-windows\arduino-1.8.15\hardware\tools\avr/etc/avrdude.conf -v -patmega644 -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
         Using Port                    : COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega644
         Chip Erase delay              : 55000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10   128    0 no       2048    8      0  9000  9000 0xff 0xff
           flash         33     6   256    0 yes     65536  256    256  4500  4500 0xff 0xff
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
That is progress. This new error is usually caused by bad wiring. Double check all your wiring to make sure it's right.
I double checked my wiring and it seems to all be fine, I also have the blue led indication from the 3d printer that the wiring is correct.
OK, then it probably means that your 3D printer has been physically damaged and you will need to replace the controller.
yeahhh, see the whole reason I'm trying to install Marlin is because bad firmware bricked my printer. As all my free options are exhausted I'll just buy a new board off Amazon. Thanks for the help
If you are based in the UK, I can try to upload the bootloader for you, just pay for return shipping!
