UNO FCC certification
Hello All
I am hoping someone can give me a concrete answer on this:
Is the UNO FCC part 15 compliant?
I have searched the FCC website (which is barely running :() and I cannot find any evidence of such compliance? Does anyone know?
If it testing is still underway, when is it expected to be completed?
What does the certification mean?
Roughly-Certification means that the device in question has been tested for spurious radio emissions in an accredited test facility and been found to emit less than allowable amounts under:
and a test report has been submitted reporting that to the FCC, who in turn registers the details of the device as compliant. It allows manufacturers, integrators and customers to have some confidence that the emissions from that device won't cause too much grief.
Just my understanding of it anyways.
Yes it is reported that it does have FCC compliance. The reason you can't find it on the FCC web site is that they only list the devices that are intentional emitters. These need an FCC identification number and that is what you are looking up on the site. However there is no need for an ID number for devices that are not intentional emitters, like the Arduino.
If you want confirmation of certification then contact the manufacturers or your suppler.
i have contacted my supplier. This is what they said:
"Not sure. I think there was some data regarding it on the arduino.cc forums. The documentation or PCB doesn't list the certification numbers, but I can't imagine it being impossible to find."
As far as I can tell the offical word is "pending FCC certification." http://arduino.cc/blog/2010/09/24/dinner-is-ready/
My understanding is that any residential product that could potentially emit RF interference (digital clock above 9KHz) needs to certified (and assigned an FCC ID) or verified (no FCC ID required). Which depends on what type of device it is.
So, is the Arduino a 'CPU Board' as defined by the FCC. If so, it should be certified (and assigned an FCC ID) prior to marketing. If it is an 'other class B digital device' then it needs verification.
Disclaimer: I am not a lawyer, nor do I play one on TV.
That response from your supplier is not sufficient and he is in breach of the law with that reply.
@Tim
As I said no FCC ID is required for an unintentional emitter, that is something that is not designed to emit EM radiation and only emits it as an unintentional consequence of the design. So for example an Xbee is meant to emit radio waves, and arduino is not. The A or B classification is determined by the size of the emissions.
I saw a Video of the UNO launch in which Massimo said it had been FCC tested. The suppler MUST be able to supply you with a certificate.
Everything under FCC part 15 subpart B is an unintentional emitter (intentional emitters are covered under FCC part 15 subpart C). Scanners and radar detectors are two examples of part 15-B unitentional emitters that do require certification and thus an FCC ID.
Class A and class B have differing radiation and conduction limits, the definition is based on industrial or residential use not on emissions.
From FCC part 15.3:
(h) Class A digital device. A digital device that is marketed for use in a commercial, industrial or business environment, exclusive of a device which is marketed for use by the general public or is intended to be used in the home.
(i) Class B digital device. A digital device that is marketed for use in a residential environment notwithstanding use in commercial, business and industrial environments. Examples of such devices include, but are not limited to, personal computers, calculators, and similar electronic devices that are marketed for use by the general public.
Disclaimer: I haven't passed the bar since my last post, so I am still not a lawyer.
Yes that's what they say officially but normally you have a choice of A or B with a lot of equipment. At least that is what they offered me every time I have had something FCC approved.
That's a new one on me. Mind you they are always changing the rules, it's just basically an import blocking measure dressed up with some fancy conditions.
Arduino Uno has FCC logo on it; so I assume it's FCC compliant.
