@sterretje not sure why you thought I was unwilling to share my code, I never said anything like that. I was asking more of a general hardware related question so I didn't think the sketch would matter, I have attached it below. I have also included the error I am getting. Keep in mind that the sketch is a work in progress I have not finished the changes, as well as I had to remove some of the functionality of the original code as some of that was interfering with getting the changes working. I'll add those back in later. There's also a lot of Serial.print statements but those are for debugging and will be removed. The system runs a pump with a stepper motor, originally the operator would enter how many steps for the motor, a dwell time and how many times to repeat the process. They now what to enter the speed of the pump, how long to run it and a pause time but instead of repeating the same parameters they can change the next phases settings. Currently I have it limited to 10 phases, if they need less they enter a 0 for the last phase number. While the pump is running it measure two pressure transmitters and stores the data on a SD card. Form fit to me means I can unplug the first component and plug a second one in the same place without making any changes and it works the same as the first. There is an extremal power supply, real time clock, 2 pushbuttons, two pressure transmitter, the SD card and the stepper motor controller. I don't want to have to rewire all of that. If I can plug the Every into this shield, solder female header pins on and plug all the connections in the same place I'll be happy. As mentioned earlier I was able to compile this sketch with a Every without making any changes so the libraries I'm using must be compatible.
Here is the sketch
[code]
// stepper motor control code
// Enter cycle values, number of steps, dwell time between steps, and number of increments on serial monitor
// Comands to control test also entered on serial monitor, s = start, p = pause, r = resume, e = end, or use pushbutton to start cycle
// Added a purge cycle, when the purge pushbutton is pressed the pump will go 1 revolution in 1 minute
// Added 2 pressure sensors, RTC and SD card for data logging
// Rev 6 added an arrary to hold phase #, Speed, Time, Dwell
// Changed stepper libray to be able to control speed
// Copyright Process Services 2020
//#include <AccelStepper.h>
#include <Stepper.h>
#include <SPI.h>
#include <SdFat.h> // SD card & FAT filesystem library
#include <Wire.h>
#include "RTClib.h"
// RTC variables
RTC_DS3231 realClock; // Establishes the chipset of the Real Time Clock
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
// SD Variables
SdFat SD; // SD card filesystem
unsigned int SDyear = 2019;
byte SDmonth = 11;
byte SDday = 15;
byte SDhour = 6;
byte SDminute = 11;
byte SDsecond = 00;
char logFileName[20] = " "; // current log file name
File logfile; // the logging file
DateTime now ;
int errorNumb = 0; // system error number to display message
const int chipSelect = 10;
// Motor pin definitions
// Blue - 28BYJ48 pin 1
// Pink - 28BYJ48 pin 2
// Yellow - 28BYJ48 pin 3
// Orange - 28BYJ48 pin 4
// Red - 28BYJ48 pin 5 (VCC)
#define motorPin1 3 // IN1 on the ULN2003 driver 1
#define motorPin2 4 // IN2 on the ULN2003 driver 1
#define motorPin3 5 // IN3 on the ULN2003 driver 1
#define motorPin4 6 // IN4 on the ULN2003 driver 1
const int stepsPerRevolution = 200; // number of steps per a revolution of motor
// initialize the stepper library on pins 3 through 11:
Stepper EF_Stepper(stepsPerRevolution, 3, 4, 5, 6);
#define repeatPb 8 // Repeat cycle pushbutton
#define purgePb 9 // purge cycle pushbutton
int led = 13; // set led to pin 13
String dataIn; // string from operator
char d1; // character from string
String x; // String from operator
// Pressure Sensors
int InPrssPin = A0; // Inlet pressure to A0
int OutPrssPin = A1; // Outlet pressure to A1
int InPrssRaw = 0; // Inlet Pressure raw value
int OutPrssRaw = 0; // Outlet Pressure raw value
float InPrssScld = 0.0; // Inlet pressure scaled
float OutPrssScld = 0.0; // Outlet pressure scaled
float InPrssPeak = 0.0; // Inlet Pressure Peak
float OutPrssPeak = 0.0; // Outlet Pressure Peak
int InatPeak = 0;
// temporary array for use when parsing
const byte numChars = 64;
char receivedChars[numChars];
char tempChars[numChars];
char dataInChars[numChars];
boolean newData = false;
char startMarker = '<';
char endMarker = '>';
char comma = ',';
// variables for test cycle
long incr = 0; // number of poles per increment
int poles = 0; // total poles incremented
int dwell = 0; // dwell time between steps
int totSteps = 0; // total number of steps
int runCycle = 0; // run cycle enable
long stepCount = 0; // current step counts
int i = 0;
int purgeMode = 0; // purge mode run bit
int purgeSteps = 0;
float purgeDwell = 0.014; // Purge dwell time between steps
int purgeIncr = 0; // purge step counter
int totalPurgeSteps = 4096; // number of steps in purge cycle 1 revolution
long PmpStartTm; // time pump started
long PmpStopTm; // time pump stopped
int phaseNum ; // entered phase number
int phaseCount = 0; // count the number of phase entered
int pmpEnb = 0; // pump is enabled
int pmpStpd = 0; // pump stopped
// Purge variables
int purgeDist = 4096; // distance pump goes during Purge, 4096 = 1 revolution
int purgeSpd = 70; // speed of pump during purge, 75 = 1 minute for a revolution
// Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper with 28BYJ-48
//AccelStepper stepMotor(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4); // AccelStepper::FULL4WIRE
// declare phase parameter array
long phase[11] [4];
// stepper.setSpeed(64); // 1 min//64 1rpm //128 2rpm //ENTER 4100 FOR 1 rev OF THE ROLLER
// Set some constraints on the stepper motor
//stepMotor.setMaxSpeed(500.0);
//stepMotor.setAcceleration(100.0);
// stepMotor.setSpeed(50);
pinMode(led, OUTPUT); // set led pin to an output
pinMode(repeatPb, INPUT_PULLUP); // input for repeat pushbutton
pinMode(purgePb, INPUT_PULLUP); // input for purge pushbutton
// Start realClock
Wire.begin(); // Starts the Wire library allows I2C communication to the Real Time Clock
realClock.begin(); // Starts communications to the RTC
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
errorNumb = 1;
error("Card failed, or not present");
Serial.println("card initialized.");
// call function to enter test parameters
phase_setup();
for (int i = 0; i <= 10; i++) {
Serial.print(phase[i][0]);
Serial.print("\t");
Serial.print(phase[i][1]);
Serial.print("\t");
Serial.print(phase[i][2]);
Serial.print("\t");
Serial.print(phase[i][3]);
Serial.println("\t");
} // end for
} // end Setup
if (digitalRead(repeatPb) == LOW) {
runCycle = 1;
phaseNum = 1;
Serial.println("PB pressed");
} // end if (digitalRead(repeatPb) == LOW)
// for(int x = 1; x <= phaseCount; x++){
// Serial.println("in for");
// ******************* Phase Start ***************************************************
if (runCycle == 1 && purgeMode == 0) {
if (pmpEnb == 0) {
PmpStartTm = millis(); // capture pump start time
pmpEnb = 1;
} // end if(pmpEnb == 0){
if (pmpEnb) {
// start motor at phase speed
EF_Stepper.setSpeed(phase[phaseNum][0]);
Serial.println(phase[phaseNum][0]);
// EF_Stepper.setSpeed(phase[1][0]);
// step 1/100 of a revolution:
EF_Stepper.step(stepsPerRevolution / 100);
Serial.println("runCycle");
Serial.println(phase[phaseNum][1]);
if (millis() > (PmpStartTm + phase[phaseNum][1])) {
runCycle = 0;
pmpEnb = 0;
pmpStpd = 1;
PmpStopTm = millis();
Serial.println("Pump Stopped");
} // end if(millis() > (PmpStartTm + phase[phaseNum][1]))
} // end if(pmpEnb)
} // end if(runCycle == 1)
if (pmpStpd && (millis() > (PmpStopTm + phase[phaseNum][2]))) {
pmpStpd = 0;
phaseNum++; // increment phase number
runCycle = 1;
Serial.println("Phase end");
} // end if(millis() > (PmpStartTm + phase[phaseNum][2]))
//************************* Phase Stop ********************************************************************
// } // end for(int x; x <= phaseCount; x++)
} // end loop
void recvWithStartEndMarkers() { // reads variables from controller
static boolean recvInProgress = false;
static byte ndx = 0;
// char startMarker = '<';
// char endMarker = '>';
char rc;
// while (Serial1.available() > 0 && newData == false) {
// rc = Serial1.read();
dataIn.toCharArray(dataInChars, 64);
// rc = Serial.read();
if (recvInProgress == true) {
if (dataInChars != endMarker) {
receivedChars[ndx] = dataInChars;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (dataInChars == startMarker) {
recvInProgress = true;
// } // end while (Serial1.available()
} // end void recvWithStartEndMarkers()
void parseData() { // split the data into its parts
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok(tempChars, ","); // get the first part - the string
poles = atoi(strtokIndx); // step value
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
dwell = atoi(strtokIndx); // dwell time
totSteps = atoi(strtokIndx); // total number of steps
} // end void parseData()
void dateTime(uint16_t* date, uint16_t* time)
SDyear = now.year();
SDmonth = now.month();
SDday = now.day();
SDhour = now.hour();
SDminute = now.minute();
SDsecond = now.second();
*date = FAT_DATE(SDyear, SDmonth, SDday);
*time = FAT_TIME(SDhour, SDminute, SDsecond);
} // end void datetime
void error(char *str)
Serial.print("error: ");
Serial.println(str);
Serial.println(errorNumb);
// red LED indicates error
// digitalWrite(redLEDpin, HIGH);
// display fault on screen
if (errorNumb == 1) {
Serial.println("Insert SD Card");
else if (errorNumb == 2) {
Serial.println("Failed to Create File");
while (1);
} // end void error
void phase_setup() {
// initialize start of phase parameters
for (phaseNum = 0; phaseNum <= 10; phaseNum++) {
Serial.println("Enter Phase Number");
while (Serial.available() == 0) {} // wait for number of steps to be entered
// poles = Serial.parseInt(); // set steps to entered value
phaseNum = Serial.parseInt(); // set steps to entered value
incr = poles; // set for first step
Serial.read(); // clear serial buffer
// Serial.println(poles);
Serial.println(phaseNum);
phaseCount = phaseCount = 1;
if (phaseNum == 0) {
return;
} // end if(phaseNum == 0)
Serial.println("Enter number of steps");
phase[phaseNum][0] = Serial.parseInt(); // set steps to entered value
Serial.println("Enter Speed (0 to 100%)");
while (Serial.available() == 0) {} // wait for Dwell Time to be entered
//dwell = Serial.parseInt(); // set steps to entered value
//Serial.println(dwell);
Serial.println("Enter Phase Time in milliseconds");
// totSteps = Serial.parseInt(); // set total number of steps to entered value
phase[phaseNum][1] = Serial.parseInt(); // set steps to entered value
//Serial.println(totSteps);
Serial.println("Enter Pause Time in milliseconds");
phase[phaseNum][2] = Serial.parseInt(); // set steps to entered value
Serial.println(phase[phaseNum][2]);
} // for (phaseNum
} // end phase_setup
[/code]
And here is the error
C:\Users\EOFLOW\Documents\Arduino\Stepper_Control_6\Stepper_Control_6.ino: In function 'void setup()':
C:\Users\EOFLOW\Documents\Arduino\Stepper_Control_6\Stepper_Control_6.ino:140:40: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\EOFLOW\Documents\Arduino\Stepper_Control_6\Stepper_Control_6.ino: In function 'void recvWithStartEndMarkers()':
C:\Users\EOFLOW\Documents\Arduino\Stepper_Control_6\Stepper_Control_6.ino:231:24: warning: ISO C++ forbids comparison between pointer and integer [-fpermissive]
C:\Users\EOFLOW\Documents\Arduino\Stepper_Control_6\Stepper_Control_6.ino:232:28: warning: invalid conversion from 'char*' to 'char' [-fpermissive]
C:\Users\EOFLOW\Documents\Arduino\Stepper_Control_6\Stepper_Control_6.ino:246:27: warning: ISO C++ forbids comparison between pointer and integer [-fpermissive]
Sketch uses 14030 bytes (43%) of program storage space. Maximum is 32256 bytes.
Global variables use 1592 bytes (77%) of dynamic memory, leaving 456 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur.
Thanks for your help and let me know if you need any more info.
