Uno fusing m/c controler
Depending on temperature control 3 different Relay Switch.
In this Uno project there is two temperature senescence (k type temp more than 130 C) and two relay hear to power up heater (step by step depending time )both heater must be heat with same temperature . If one increase higher than other than stop first one , sure about same than relay both of them. stop temperature up to 130 c .
Once both temperature reach 130 c than stop increasing temperature and hold this temperature up to 7 min.this period called "holding time"
After holding time stop both heater relay and start other relay ,this relay connected with fan and cooling motor.
Device connected in this project ..
1... Arduino Uno
2... connector board
3... two K type Heater
4... 3 relay control Board
5.. cooling fan
6... I2C oled display
7... connecting wire
My next step Is programming ...
I have no idea what your Title means or how it relates to your Post. Before I read your Post I assumed from the Title that your Arduino was causing a fuse to blow - that is the usual meaning of "fusing".
chinmoyrick:
"Senescence" is the adjective from "senesce" which means ""deteriorate with age" (Concise Oxford Dictionary).
I guess you meant "sensors"
Let us know how you get on.
...R
I think the OP is trying to heat and cool an oven of some sort that follows a heating profile.
First heating the oven to a set temperature, holding it there for a set time, then cooling it with a ventilation fan.
The heater is two elements that work together with two K-Type Temp Sensor, not K type heater as OP has listed.
Each heater has its own temp sensor so as to keep the temperature even along the oven.
Am I right? Chinmoyrik?
Do you have any code at all?
What is your programming experience?
Tom.... :slight_smile:
fusing machine ..
http://www.makerbook.org/arduino/A4_Machine_Catalogue.pdf
catalog of fusing machine I want to make ckt and operation kit with arduino uno board . I only describe about Basic work.
sorry for my English
tomGeorge you are right ,
1.. plz give me some time for posting fritzing file (finding 3relay controller fritzing and k type sensor file ).
2.. don't understand about temperature sensor code calculation(have to order a k type sensor, never work with this type scencer )
3.. I have little experience about arduino code (write one sketch with nodemcu with rfid sensor..server attandance..its working)
I can control 3 rely with
http://www.makerbook.org/arduino/step1.jpg
Thank u.
Please do not use fritzing.
This way you can mark pin numbers and part number/names.
fritzy is not a good schematic.
Try a CAD program called ExpressPCB it is free and is very compact to download and easy to use.
There are mny CAD programs much better than fritzy.
Its a short sketch ..
