Uno I2C problem with MCP3425 SOT23-6 eval board (ADC)
I have been trying to make my Arduino Uno work with MCP3425 SOT23-6 Evaluation board, but no success. Could you help me out? I connected A4 pin to SDA and A5 pin to SCL with pull-up resistor, and when I probe, the SDA and SCL pins, they look almost the same. Somehow SDA looks the same as clock signal without signs of any data traffic. I checked if there is any short, but couldn’t find it. In the serial monitor window, I don’t see anything. Here is my code:
//Include Wire I2C library
#include <Wire.h>
int sensor_address = B1101000;
//Start serial communication at 9600 baud
//Create a Wire object
Wire.begin();
delay(10);
void readSensor(byte *a, byte *b, byte *c)
Wire.beginTransmission(sensor_address);
Wire.write(B10011000);
Wire.endTransmission();
Wire.requestFrom(sensor_address, 3);
while(Wire.available() == 0);
*a = Wire.read();
*b = Wire.read();
*c = Wire.read();
byte aa, bb, cc;
readSensor(&aa, &bb, &cc);
Serial.print(aa);
Serial.print(“t”);
Serial.print(bb);
Serial.print(“t”);
Serial.println(cc);
Here is data sheet for MCP3425: http://ww1.microchip.com/downloads/en/DeviceDoc/22072a.pdf
Your help would be appreciated. Thanks!
