I have an application in which I wish to run an Arduino Uno as an I2C master to both another Uno and a Raspberry Pi running python. I am successful sending to the Uno but not to the Pi which raises a Remote I/O Error on the first read. I have included a bi-directional logic level converter to step down the voltage on SDA and SCL.
An I2cdetect -y 1 on the Pi detects the slave Uno, so it would appear that the I2C connections are correct
The Arduino code:
#include <Wire.h>
#define PI_ADDRESS 0x08
#define UNO_ADDRESS 0x04
void setup(){
Wire.begin(0x00);
void loop(){
sendData(UNO_ADDRESS, 1);
sendData(PI_ADDRESS, 1);
sendData(UNO_ADDRESS, 0);
sendData(PI_ADDRESS, 0);
void sendData(int Address, byte sendByte){
Wire.beginTransmission(Address);
Wire.write(sendByte);
Wire.endTransmission(true);
Serial.println(sendByte);
And the python code
#!/usr/bin/env python
from time import sleep
import smbus
bus = smbus.SMBus(1)
address = 0x08
sleep (2)
while 1:
data = bus.read_byte(address)
print(data)
sleep(0.5)
Execution results in an IOError: [Errno 121] Remote I/O Error
Any insights that you might have would be appreciated
