Uno & Olimex AVR-ISP-MK2
Hello, I recently bought an Olimex AVR-ISP-MK2 so that I could reflash a Freeduino Host Board(http://forum.moderndevice.com/viewtopic.php?f=23&t=684&sid=4f80627751a42bd050bdfbbce6dc63cf). Before I did that I wanted to just try it out a standard Uno so I don't break the host board.
So I've been trying to upload sketches with the programmer to the uno. I'm using Ubuntu 12.04 and have followed these instructions on creating new rules: https://sites.google.com/site/nottiematt/home/my-digital-brain/avrisp-mkii-on-ubuntu
The physical setup: I have the 2x3 PDI cable plugged onto the Uno. I have the USB type B (the square one) going from my MK2 to the PC. I have the Uno powered from a battery. I read something about maybe needing to plug power into the MKII but I'm not sure if that was as well as the battery for the Uno or instead of it. Or where to plug it in. When I plug in the MKII to the PC a solid red LED turns on, that is the only LED on the MKII that ever comes on.
Finally when I try to run: sudo avrdude -p m328p -c avrispmkii -P usb -B 6 -F -vvvv
I get the output at the bottom of the post. Device signature = 0x000000 is the same as if there were no Arduino plugged in, so it looks like the MK2 is working but it can't find the Uno.
I've been at this for 2 days so I'd appreciate any help. I may be doing sommet stupid since I've not done this before.
avrdude: Version 5.11.1, compiled on Oct 30 2011 at 10:37:28
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/etc/avrdude.conf"
         User configuration file is "/home/andrew/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : avrispmkii
         Setting bit clk period        : 6.0
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200012345
avrdude: usbdev_open(): using read endpoint 0x83
avrdude: Sent: . [01]
avrdude: Recv: . [01] . [00] . [0a] A [41] V [56] R [52] I [49] S [53] P [50] _ [5f] M [4d] K [4b] 2 [32]
avrdude: stk500v2_getsync(): found AVRISP mkII programmer
Using p = 8.00 us for SCK (param = 6)
avrdude: Sent: . [03] . [98]
avrdude: Recv: . [03] . [00] . [06]
avrdude: Skipping paramter write; parameter value already set.
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel AVR ISP mkII
         Programmer Model: AVRISP mkII
avrdude: Sent: . [03] . [90]
avrdude: Recv: . [03] . [00] . [00]
avrdude: Sent: . [03] . [91]
avrdude: Recv: . [03] . [00] . [01]
avrdude: Sent: . [03] . [92]
avrdude: Recv: . [03] . [00] . [11]
         Hardware Version: 0
         Firmware Version Master : 1.17
avrdude: Sent: . [03] . [94]
avrdude: Recv: . [03] . [00] ! [21]
         Vtarget         : 3.3 V
         SCK period      : 8.00 us
avrdude: Sent: . [10] . [c8] d [64] . [19]   [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00]
avrdude: Recv: . [10] . [c0]
avrdude: stk500v2_command(): command failed
avrdude: Sent: . [03] . [a1]
avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status: Unknown status 0x00
avrdude: initialization failed, rc=-1
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
avrdude: Sent: . [11] . [01] . [01]
avrdude: Recv: . [11] . [00]
avrdude done.  Thank you.
