Uno R3 - can you run Server and Udp simultaneously?
I have been running a web server on my Uno w/Ethernet shield. All has been fine in its own program.
I wanted to add time-stamps to my logging of data and found I can make a UDP call to an NTP server, get back the seconds and convert them to meaningful strings with the Time.h library. This works fine in its own program.
The problem is when I try to combine the code into one program. I think it's a conflict between running the server and UDP at the same time:
EthernetServer server(80);
EthernetUDP Udp;
Udp.begin(8888);
Does anyone know if it is possible to run both simultaneously?
Thanks,
Jake
Theoretically you can but you have to change the EthernetServer class. In the distributed version it uses all available sockets (4) to have them ready to accept connections from clients. If you change that to use only 3, one gets free for the UDP use. BTW, the problematic call is server.begin(), which overwrites the UDP setup.
Thank you, I'll give that a try.
UPDATE:
I found a solution: I initialize the UDP and set the clock after pinging an NTP server.
Only after that do I initialize the web Server.
It works, so moving on! :smiley:
Thanks for the help.
Jake
In the past the below code worked, but now there is an "error compiling".
edit: rebooted my netbook and the complie error has gone away.
//zoomkat 12-08-11, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send an g to test client and
//see what the arduino client/server receives
//web page buttons make pin 4 high/low
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//NTP server implementation added by RobertJP
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
IPAddress ip(192,168,1,102); // ip in lan
IPAddress gateway(192,168,1,1); // internet access via router
IPAddress subnet(255,255,255,0); //subnet mask
IPAddress myserver(208,104,2,86); // zoomkat web page
EthernetServer server(84); //server port
EthernetClient client;
String readString;
//////////////////////NTP declarations
IPAddress timeServer(77,245,91,218); // time.nist.gov NTP server
const int NTP_PACKET_SIZE= 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
EthernetUDP Udp; // A UDP instance to let us send and receive packets over UDP
unsigned int localPort = 8888; //Port to listen for UDP packets
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  Ethernet.begin(mac,ip,gateway,gateway,subnet);
  server.begin();
  Serial.println("server/client 1.0 test 12/08/11"); // keep track of what is loaded
  Serial.println("Send an g in serial monitor to test client"); // what to do to test client
  Udp.begin(localPort);
  Serial.println("UDP started");
void loop(){
  // check for serial input
  if (Serial.available() > 0)
    byte inChar;
    inChar = Serial.read();
    if(inChar == 'g')
      sendGET(); // call sendGET function
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
            //now output HTML data header
          if(readString.indexOf('?') >=0) { //don't send new page
            client.println("HTTP/1.1 204 Robert");
            client.println();
            client.println();
          else {
            client.println("HTTP/1.1 200 OK"); //send new page
            client.println("Content-Type: text/html");
            client.println();
            client.println("<HTML>");
            client.println("<HEAD>");
            client.println("<TITLE>Arduino GET test page</TITLE>");
            client.println("</HEAD>");
            client.println("<BODY>");
            client.println("<H1>Zoomkat's simple Arduino 1.0 button</H1>");
            client.println("<a href=\"/?on\" target=\"inlineframe\">ON</a>");
            client.println("<a href=\"/?off\" target=\"inlineframe\">OFF</a>");
            //client.println("<IFRAME name=inlineframe src=\"res://D:/WINDOWS/dnserror.htm\" width=1 height=1\">");
            client.println("<IFRAME name=inlineframe style=\"display:none\" >");
            client.println("</IFRAME>");
            client.println("</BODY>");
            client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on") >0)//checks for on
            digitalWrite(5, HIGH);    // set pin 4 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            digitalWrite(5, LOW);    // set pin 4 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
void sendGET()
  Serial.println("Send GET");
  sendNTPpacket(timeServer); // send an NTP packet to a time server
   // wait to see if a reply is available
  if ( Udp.parsePacket() ) {
    Serial.println("Got it!");
    // We've received a packet, read the data from it
    Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
    //the timestamp starts at byte 40 of the received packet and is four bytes,
    // or two words, long. First, esxtract the two words:
    unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
    unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
    // combine the four bytes (two words) into a long integer
    // this is NTP time (seconds since Jan 1 1900):
    unsigned long secsSince1900 = highWord << 16 | lowWord;
    Serial.print("Seconds since Jan 1 1900 = " );
    Serial.println(secsSince1900);
    // now convert NTP time into everyday time:
    Serial.print("Unix time = ");
    // Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
    const unsigned long seventyYears = 2208988800UL;
    // subtract seventy years:
    unsigned long epoch = secsSince1900 - seventyYears;
    // print Unix time:
    Serial.println(epoch);
    // print the hour, minute and second:
    Serial.print("The UTC time is ");       // UTC is the time at Greenwich Meridian (GMT)
    Serial.print(1+(epoch  % 86400L) / 3600); // print the hour (86400 equals secs per day)
    Serial.print(':');
    if ( ((epoch % 3600) / 60) < 10 ) {
      // In the first 10 minutes of each hour, we'll want a leading '0'
      Serial.print('0');
    Serial.print((epoch  % 3600) / 60); // print the minute (3600 equals secs per minute)
    Serial.print(':');
    if ( (epoch % 60) < 10 ) {
      // In the first 10 seconds of each minute, we'll want a leading '0'
      Serial.print('0');
    Serial.println(epoch %60); // print the second
  Serial.println("Done!");
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address)
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
  Udp.endPacket();
Thanks this is a very useful hint.
What is the best way to modify the EthernetServer class to allow udp and server to coexist?
thanks
This works, thank you!!!
In the Ethernet library code in your workspace folder, change:
In "Ethernet.h" change definition from 4 to 3:
#define MAX_SOCK_NUM 3
In "Ethernet.cpp" change the initializes from 4 to 3 zeros - funny there's a related comment:
// XXX: don't make assumptions about the value of MAX_SOCK_NUM.
uint8_t EthernetClass::_state[MAX_SOCK_NUM] = { 0, 0, 0 };
uint16_t EthernetClass::_server_port[MAX_SOCK_NUM] = { 0, 0, 0 };
I have used the server and UDP together, and i never had to change the MAX_SOCK_NUM to 3. I always start the udp before the server.
I am trying to do the same thing (run a web server along with UDP server).
SurferTim when you say "start the udp before the server" are you saying put this in your startup code
Ethernet.begin(mac,ip);
Instead of this?
Or are you saying this?
server.begin();
I have EthernetServer server(80) in the declarations.
artart:
// start the w5100
// start the UDP
// start the server
server.begin();
I'm saying that. The UDP socket will be socket #0. The server will use sockets #1 to #3 (or #7 if a w5200/w5500).
edit: If you want to see how things are going with your sockets, I use this code. I call it with a character I send from the serial monitor.
#include <utility/w5100.h>
byte socketStat[MAX_SOCK_NUM];
void ShowSockStatus()
  for (int i = 0; i < MAX_SOCK_NUM; i++) {
    Serial.print(F("Socket#"));
    Serial.print(i);
    uint8_t s = W5100.readSnSR(i);
    socketStat[i] = s;
    Serial.print(F(":0x"));
    Serial.print(s,16);
    Serial.print(F(" "));
    Serial.print(W5100.readSnPORT(i));
    Serial.print(F(" D:"));
    uint8_t dip[4];
    W5100.readSnDIPR(i, dip);
    for (int j=0; j<4; j++) {
      Serial.print(dip[j],10);
      if (j<3) Serial.print(".");
    Serial.print(F("("));
    Serial.print(W5100.readSnDPORT(i));
    Serial.println(F(")"));
