UNO R3 clone wont setup on kali os
i cant get my computer to read the board when i try to setup with Arduino cloud it dont pick it up iv even tried the latest IDE same thing anyone know what im doing wrong?
  1. Run lsusb; is your board recognised?
  2. dmesg
    • Disconnect your board.
    • Run dmesg -w.
    • Add some empty lines after the current output so it's easier to see the output from the next step.
    • Connect the board and observe the changes. Post the changes here.
    • Close dmesg using <CTRL>C
If you find a reference to BRLTTY, you need to disable or uninstall it.
You also need to make yourself a member of the dialout (or whatever it is called in Kali) group.
Above are generic Linux instructions, I'm not familiar with Kali.
Note:
I do not use the cloud. get it first working on the IDE, later you can fix the cloud (if still needed).
[36696.451775] usb 1-6.4: FTDI USB Serial Device converter now attached to ttyUSB0
its picking it up just not on the ide??
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0b05:19af ASUSTek Computer, Inc. AURA LED Controller
Bus 001 Device 003: ID 046d:c52f Logitech, Inc. Nano Receiver
Bus 001 Device 004: ID 174c:2074 ASMedia Technology Inc. ASM1074 High-Speed hub
Bus 001 Device 005: ID 1e71:170e NZXT Kraken X
Bus 001 Device 007: ID 8087:0033 Intel Corp. AX211 Bluetooth
Bus 001 Device 012: ID 1a2c:4094 China Resource Semico Co., Ltd USB Keyboard
Bus 001 Device 015: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 174c:3074 ASMedia Technology Inc. ASM1074 SuperSpeed hub
im already a member of dialout aswell
That looks good in which case I do not know the answer; sorry.
efforts appreciated! probably just gonna buy an actual Arduino lmao
I've just tested a SparkFun Redboard (not the QWIIC; also FT232) in Ubuntu 24.04 and it works as expected in IDE 2.3.4 (AppImage).
