Hello!
Ok, so i have two arduinos, Model UNO R3, one bought from china ( probably not exactly the same hardware as the original but it works perfect!) and one original which does not work. i will try to explain my problem as precise as possible.
If i start my working arduino it works perfectly(hooking it up to the usb) and gets detected by the system, the "L" led on the board gives me the fast bootblinks and it is up and running.
If i connect the faulty one it doesn't get recognised or detected by my system at all ( Windows 8, same as the setup above) , the usb cable connection gives to computer absolutely nothing, nothing detects it, not in arduino IDE, not in device manager under any category. Also, when i connect this arduino the "L" led does not blink at all. It just lits and glows all the time ( yellow/orange colour).
This is when i use the working arduino with the working arduinos ATmega328P-PE chip, and the faulty whith the faulty ones chip ( Same model on the chip).
If i change the setup to this:
I put the faulty arduinos Atmega328P-PE chip, on the working ones board and plug it into the usb port.
My computer detects it and i can see it in both Arduino IDE and device manager and it is installed becouse i have used an arduino uno R3 before on this computer.
However i can't write code to the arduino, when i try i get this error:
"Binary sketch size: 1 084 bytes (of a 32 256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00"'
Edit: with this setup the L led on the working board is lit all the just like the faulty one.
I put the working arduinos Atmega328P-PE chip ( Loaded with a simple blink led 13 program) on the faulty ones board and plug it into the USB.
It starts up, gives me the bootblinks and starts the program, however my computer does not detect it in any way like i said before.
----------END OF DESCRIBING-----------
My guess would be that on the faulty arduino both the ATmega328P-PE and the smaller chip controlling the USB connection to the ATmega328P-PE is damaged. That the bootloader is gone on both. I can't seem to find any solution for a problem that looks like this one in any way and that is why i hope some of you fellow guys could help me ! ![]()
Sincerely, Zackarias Montell SWEDEN.
EDIT:
I would really like to get the board working ( I actually have two original boards with the same problem). Im planning to order new ATmega328P-PE chips from ebay whith the bootloader for Uno R3 already pre-installed and also to buy a programming tool for the ICSP pins on the board (both will be linked below), maybe that will help me as i progress. If you know, please help me to indentify if i can use this programming tool for this board.
Links:
(http://www.ebay.com/itm/2x-Atmega328-w-Arduino-UNO-Optiboot-Bootloader-ATMEGA328P-PU-2pcs-/331101688939?pt=LH_DefaultDomain_0&hash=item4d1732d46b)
(http://www.ebay.com/itm/171165989666)
