UNO R4 Minima not entering bootloader state
I recently purchased an uno r4 minima board with the hopes of using it to drive an LCD display. However, I pretty quickly ran into a problem where the device does not register in the device manager of my computer, therefore I cannot use it in the Arduino IDE nor check in on the device status any other way (that I can find at least). I tried pressing the reset button twice to enter the bootloader mode, but nothing happened (the "power on" light stayed on and I did not get the orange breathing light). I also tried holding the reset button for an extended period of time just in case that would do anything, but still nothing. I checked other connections in the device manager to see if it was loading under something weird. I have checked that the cord I am using can convey data (it's the one I use to connect my phone to my car to play music, and it works splendidly for that use). I saw online that I could possibly use Renesas to re-flash the bootloader, but when I try that it gets stuck in an infinite "running" dialog.
I feel like I have run out of options for debugging my device and any input would be greatly appreciated!
Try checking the " Bootloader" section of https://docs.arduino.cc/tutorials/uno-r4-minima/cheat-sheet/ and implement the steps correctly. If the process does not work and you have official Arduino UNO R4 Minima purchased from Arduino directly, then contact the Arduino support team via Contact us
with details of the issue and your purchase receipt.
