Uno R4 minima swRTC problem
Hi. I'm trying to make a data logger using SD card.
I want to make logger that shows sensor data and time stamps.
For that, I found that it requires swRTC library to record time.
So I downloaded it and tried its sample code, but it didn't work.
I received these error messages:
In file included from C:\Users\AppData\Local\Temp.arduinoIDE-unsaved202385-26756-rh0pup.w2cdr\sketch_sep5b\sketch_sep5b.ino:1:0:
C:\Users\OneDrive\����\Arduino\libraries\swRTC/swRTC.h:62:2: error: #error Sorry, microcontroller not supported!
C:\Users\OneDrive\����\Arduino\libraries\swRTC/swRTC.h:75:2: error: #error Sorry, clock frequency not supported!
exit status 1
Compilation error: exit status 1
and the code is:
swRTC rtc;
  rtc.stopRTC();
  rtc.setDate(9, 9, 2023);
  rtc.setTime(0, 0, 0);
  rtc.startRTC();
  Serial.print(rtc.getHours(), DEC);
  Serial.print(":");
  Serial.print(rtc.getMinutes(), DEC);
  Serial.print(":");
  Serial.print(rtc.getSeconds(), DEC);
  Serial.print("\t");
  Serial.print(rtc.getYear(), DEC);
  Serial.print("/");
  Serial.print(rtc.getMonth(), DEC);
  Serial.print("/");
  Serial.println(rtc.getDay(), DEC);
I'm very new to arduino and I can't figure out why it didn't work and how to make this right.
My board is Uno R4 Minima.
Thanks.
Welcome to the forum
From the swRTC library GitHub page
swRTC is a library that implements a software-RTC on an Arduino board or an Atmel microcontroller
As indicated by the error message, your board does not have the required microcontroller
What features of the library were you hoping to use ? Have you considered using a real RTC ?
I only want some timestamps as: 00:00:01, 00:00:02 ... It doesn't matter if it's not a real RTC.
Does it need additional module?
The R4 Minima has a built in RTC. You don't need an external one nor a software derived one.
It works!!!!! I didn't know there was a tutorial. Thanks!!!
Please mark as a solution if it helped to let people know the thread is done.
