Update: The Arduino source code does support I2C on the SCI hardware. So in theory, it should be possible to create a TwoWire object for a new I2C bus.
Hi @Koepel - how do you create the SCI version and is it only available on D0/D1?
The pins definition has:
/****** UART CORE DEFINES ******/
#define SERIAL_HOWMANY 3
#define UART1_TX_PIN 22
#define UART1_RX_PIN 23
#define UART2_TX_PIN 1
#define UART2_RX_PIN 0
#define UART3_TX_PIN 24
#define UART3_RX_PIN 25
/****** WIRE CORE DEFINES ******/
#define WIRE_HOWMANY 2
#define WIRE_SDA_PIN 18 /* A4 */
#define WIRE_SCL_PIN 19 /* A5 */
#define WIRE1_SDA_PIN 27
#define WIRE1_SCL_PIN 26
Can you retain the Serial Monitor over USB if you change the Serial "HOWMANY" to 1 (pins 22 & 23) while commenting out UART2 & UART3?
Or does that break something not having UART2 and use SERIAL?
And if change the Wire "HOWMANY" to 3 and add WIRE2 for pins 1 & 0, how do you define them as SCI IIC instead if hardware I2C?
Wire.cpp "Version 2022 for Renesas RA4" looks like it has everything for SCI I2C.
And Wire.h
#include "r_sci_i2c.h"
But still can't seem to put it all together to make it work on D0/D1, or how to manually create an SCI I2C bus.
But will keep trying...
I'm thinking in this direction:
#include <Wire.h>
int sda_pin = ...
int scl_pin = ...
// The last parameter "true" is to select the SCI hardware.
TwoWire myWire(scl_pin, sda_pin, SPEED_STANDARD, ADDRESS_MODE_7_BITS, true);
myWire.begin();
I don't know about the Serial communication to the computer, I forgot what I have read about it in the last days, sorry.
Hi @Koepel - my concern is why the Advanced Section of the full pinout only lists D0 & D1 as being potentially SCI Simple I2C capable?
Is there something 'under the hood' that is required to make it work, which might be present in the Wire library, but not officially supported?
I will try your suggestion.
If only we could ask the person responsible for the 2022 changes...
I didn't notice it before, but funny enough, the Uno R4 Wifi Cheat Sheet I2C section gives the example...
#include <Wire.h>
Wire.begin() //SDA & SDL
Wire1.begin(); //SDA1 & SDL1
Wire2.begin(); //SDA2 & SDL2
However, not matter what I try, I can't seem to communicate with a device on Wire2.
Thanks,
for some reason I never noticed that part.
I created my own cheat sheet, actually the Pin information extracted from their PDF, where I created a page in WIFI order and another in MINIMA order...
Wifi:
WIFI | Main Usage | Minima | I/O ports | LQFP64 | Power, System, Clock, Debug, CAC, VBATT |
Interrupt | AGT | GPT_OPS, POEG | GPT | RTC | USBFS,CAN | SCI | IIC | SPI | SSIE | ADC14 | DAC12, OPAMP | ACMPLP | SLCDC | CTSU |
0 | Serial1 | 0 | P301 | 31 | IRQ6 | AGTIO0 | GTOULO | GTIOC4B | RXD2/ MISO2/ SCL2 CTS9_ RTS9/ SS9 |
SSLB2 | SEG01/ COM5 |
TS09 | ||||||||
1 | Serial1 | 1 | P302 | 30 | IRQ5 | GTOUUP | GTIOC4A | TXD2/ MOSI2/ SDA2 |
SSLB3 | SEG02/ COM6 |
TS08 | |||||||||
2 | 3 | P104 | 44 | KR04/ IRQ1 |
GTETRGB | GTIOC1B | RXD0/ MISO0/ SCL0 |
SSLA1 | COM0 | TS13 | ||||||||||
3 | 2 | P105 | 43 | KR05/ IRQ0 |
GTETRGA | GTIOC1A | SSLA2 | COM1 | TS34 | |||||||||||
4 | 6 | P106 | 42 | KR06 | GTIOC0B | SSLA3 | COM2 | |||||||||||||
5 | 7 | P107 | 41 | KR07 | GTIOC0A | COM3 | ||||||||||||||
6 | 13 | P111 | 36 | IRQ4 | GTIOC3A | SCK2 SCK9 |
RSPCKB | CAPH | TS12 | |||||||||||
7 | 10 | P112 | 37 | GTIOC3B | TXD2/ MOSI2/ SDA2 SCK1 |
SSLB0 | SSIBCK0 | CAPL | TSCAP | |||||||||||
8 | 8 | P304 | 28 | IRQ9 | GTIOC7A | SEG20 | TS11 | |||||||||||||
9 | 9 | P303 | 29 | GTIOC7B | SEG03/ COM7 |
TS02 | ||||||||||||||
10 | 4 | P103 | 45 | KR03 | GTOWUP | GTIOC2A | CTX0 | CTS0_ RTS0/ SS0 |
SSLA0 | AN019 | CMPREF1 | VL4 | ||||||||
11 | P411 | 12 | IRQ4 | AGTOA1 | GTOVUP | GTIOC6A | TXD0/ MOSI0/ SDA0 |
MOSIA | SEG07 | TS07 | ||||||||||
12 | P410 | 13 | IRQ5 | AGTOB1 | GTOVLO | GTIOC6B | RXD0/ MISO0/ SCL0 |
MISOA | SEG08 | TS06 | ||||||||||
13 | 5 | P102 | 46 | KR02 | AGTO0 | GTOWLO | GTIOC2B | CRX0 | SCK0 TXD2/ MOSI2/ SDA2 |
RSPCKA | AN020/ ADTRG0 |
CMPIN1 | VL3 | |||||||
14 | 14(A0) | P014 | 53 | AN009 | DA0 | |||||||||||||||
15 | 15(A1) | P000 | 64 | IRQ6 | AN000 | AMP0+ | TS21 | |||||||||||||
16 | 16(A2) | P001 | 63 | IRQ7 | AN001 | AMP0- | TS22 | |||||||||||||
17 | 17(A3) | P002 | 62 | IRQ2 | AN002 | AMP0O | ||||||||||||||
18 | 18(A4/SDA) | P101 | 47 | KR01/ IRQ1 |
AGTEE0 | GTETRGB | GTIOC5A | TXD0/ MOSI0/ SDA0 CTS1_ RTS1/ SS1 |
SDA1 | MOSIA | AN021 | CMPREF0 | VL2 | |||||||
19 | 19(A5/SCL) | P100 | 48 | KR00/ IRQ2 |
AGTIO0 | GTETRGA | GTIOC5B | RXD0/ MISO0/ SCL0 SCK1 |
SCL1 | MISOA | AN022 | CMPIN0 | VL1 | |||||||
20 | 20 | P500 | 49 | AGTOA0 | GTIU | GTIOC2A | USB_VB USEN |
AN016 | CMPREF1 | SEG34 | ||||||||||
22 | Serial | 11 | P109 | 34 | TDO/SWO/ CLKOUT |
GTOVUP | GTIOC1A | CTX0 | SCK1 TXD9/ MOSI9/ SDA9 |
MOSIB | SEG23 | TS10 | ||||||||
23 | Serial | 12 | P110 | 35 | TDI | IRQ3 | GTOVLO | GTIOC1B | CRX0 | CTS2_ RTS2/ SS2 RXD9/ MISO9/ SCL9 |
MISOB | VCOUT | SEG24 | |||||||
24 | Serial2 / ESP32 | P501 | 50 | IRQ11 | AGTOB0 | GTIV | GTIOC2B | USB_OV RCURA |
TXD1/ MOSI1/ SDA1 |
AN017 | CMPIN1 | SEG35 | ||||||||
25 | Serial2 / ESP32 | P502 | 51 | IRQ12 | GTIW | GTIOC3B | USB_OV RCURB |
RXD1/ MISO1/ SCL1 |
AN018 | CMPREF0 | SEG36 | |||||||||
26 | P400 | 1 | CACREF | IRQ0 | AGTIO1 | GTIOC6A | SCK0 SCK1 |
SCL0 | AUDIO_CL K |
SEG04 | TS20 | |||||||||
27 | P401 | 2 | IRQ5 | GTETRGA | GTIOC6B | CTX0 | CTS0_ RTS0/ SS0 TXD1/ MOSI1/ SDA1 |
SDA0 | SEG05 | TS19 | ||||||||||
28 | P003 | 61 | AN003 | AMP1O | ||||||||||||||||
29 | P004 | 60 | IRQ3 | AN004 | AMP2O | |||||||||||||||
30 | P011 | 58 | VREFL0 | IRQ15 | AN006 | AMP2+ | TS31 | |||||||||||||
31 | P012 | 55 | VREFH | AN007 | AMP1- | |||||||||||||||
32 | P013 | 54 | VREFL | AN008 | AMP1+ | |||||||||||||||
33 | P015 | 52 | IRQ7 | AN010 | TS28 | |||||||||||||||
34 | P204 | 24 | CACREF | AGTIO1 | GTIW | GTIOC4B | USB_OV RCURB |
SCK0 SCK9 |
SCL0 | RSPCKB | SEG14 | TS00 | ||||||||
35 | P205 | 23 | CLKOUT | IRQ1 | AGTO1 | GTIV | GTIOC4A | USB_OV RCURA |
TXD0/ MOSI0/ SDA0 CTS9_ RTS9/ SS9 |
SCL1 | SSLB0 | SEG13 | TSCAP | |||||||
36 | P206 | 22 | IRQ0 | GTIU | USB_VB USEN |
RXD0/ MISO0/ SCL0 |
SDA1 | SSLB1 | SEG12 | TS01 | ||||||||||
37 | P212 | 10 | EXTAL | IRQ3 | AGTEE1 | GTETRGB | GTIOC0B | RXD1/ MISO1/ SCL1 |
38 | P213 | 9 | XTAL | IRQ2 | GTETRGA | GTIOC0A | TXD1/ MOSI1/ SDA1 |
21 (usb Switch) | P408 | 15 | IRQ7 | GTOWLO | GTIOC5B | USB_ID | CTS1_ RTS1/ SS1 RXD9/ MISO9/ SCL9 |
SCL0 | SEG10 | TS04 |
Again nothing special but file is up at: UNOR4-stuff/arduino_uno_r4.xlsx at main · KurtE/UNOR4-stuff · GitHub
And I did figure out for example how to use the extra Serial port, as I have added to my Serial port test program:
//connect Serial1 TX -> Serial2 RX, Serial2 TX -> Serial3 RX, Serial3 TX -> Serial4 RX....
#if defined(ARDUINO_UNOR4_WIFI)
UART _UART4_(18, 19);
#else
UART _UART2_(18, 19);
#endif
#define SPD 115200
int loop_count = 0;
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(13, OUTPUT);
while (!Serial && millis() < 4000) ;
delay(800);
Serial.println("Test all Serials");
Serial.print("Baud rate: ");
Serial.println(SPD, DEC);
Serial1.begin(SPD);
Serial3.begin(SPD);
#else
Serial2.begin(SPD);
#endif
#define MIN(a, b) ((a) <= (b)? (a) : (b))
uint8_t buffer[80];
int available;
int available_for_write;
int cb;
if ((available = Serial.available()) != 0) {
available_for_write = Serial1.availableForWrite();
cb = MIN(MIN(available, available_for_write), sizeof(buffer));
if (cb) {
Serial.readBytes(buffer, cb);
Serial1.write(buffer, cb);
if ((available = Serial1.available()) != 0) {
available_for_write = Serial.availableForWrite();
if (cb) {
Serial1.readBytes(buffer, cb);
Serial.write(buffer, cb);
if ((available = Serial3.available()) != 0) {
available_for_write = Serial3.availableForWrite();
if (cb) {
Serial3.readBytes(buffer, cb);
Serial3.write(buffer, cb);
#else
if ((available = Serial2.available()) != 0) {
available_for_write = Serial2.availableForWrite();
if (cb) {
Serial2.readBytes(buffer, cb);
Serial2.write(buffer, cb);
#endif
digitalWrite(5, HIGH);
delayMicroseconds(100); // give time form things to propagate
digitalWrite(5, LOW);
Hi @KurtE - I hope you don't mind a few questions.
The differences between the R4 WiFi and Minima get really confusing for me.
For now I am concentrating on the R4 WiFi because I want to use BLE.
So you created a UART4 on pins 18 & 19 correct?
The standard Pinout shows an SCI UART on D0 & D1 (P301 & P302).
It also shows a different UART on the ESP32-S3 header which is P109 & P110 (SCI9) according to the wiring diagram.
I believe this is the one used for the Serial Monitor back out to the USB port?
The pin definition for the WiFi variant has 3 UARTs:
From experimentation it seems like UART1 is for the Serial Monitor back through the USB port and UART3 is used by the BLE library, so it must also be tied to the ESP32-S3 (and the wiring diagram shows P501 & P502 (SCI1) traversing the level translator.
The advanced section of the Full Pinout shows an additional UART on D18 & D19 (P100 & P101) and that is what you have successfully enabled?
That's very cool.
So there is hope to somehow enable the SCI I2C (Wire2) on D0 & D1 (P301 & P302) even though they are defaulted to UART2?
Do you think that can be done while still using the Serial Monitor (USB) and BLE radio, which I believe are UART1 & UART3, but not really sure?
Thank you for your wisdom
Not a problem. Note I am new to these boards as well!
So take some of this with a grain of salt.
Correct
For the Wifi Board, there are 3 UARTS/Serial objects that are defined:
If you look at the header file: Arduino.h you will see:
#ifndef NO_USB
#define Serial SerialUSB
#define Serial1 _UART1_
#define Serial2 _UART2_
#define Serial3 _UART3_
#define Serial4 _UART4_
#define Serial5 _UART5_
#else
#define Serial _UART1_
#define Serial1 _UART2_
#define Serial2 _UART3_
#define Serial3 _UART4_
#define Serial4 _UART5_
#endif
The Wifi board is built with NO_USB
So: Serial, which is our USB Serial (through the ESP32) is built using UART1 on pins 22, 23
which are TXD9/RXD9 or SCI 9
For Serial1 uses UART2 on pins 0, 1 - which are SCI 2
Serial2 -> UART3 pins 24/25 Are SCI 1, is used to communicate between the main processor and ESP32 and this is for Wifi and BLE. And Side note: SCI1 has FIFO hardware buffer. 2 and 9 - do not but instead have simple double buffer setup.
So I created Serial3 which by their defines maps to UART4 and so I looked for available SCI pins,
We are already using SCI(1, 2, 9), so the only left is SCI0, so I looked for TXD0/RXD0
Found TXD0 on 11, 18, 35 and RXD0 on 12, 19, 36
Have not tried 11 and 12 but 35, 36 are for the LED matrix so not easy to get to so I tried
18, 19 which worked.
Now the Minima does not have the ESP32 and uses the processor chips built in USB capabilities.
So the mapping for Serial->UARTx is different.
it only has defined Serial1 -> _UART1
So I used Serial2 in my example which goes to UART2
There is no reason why it should not work. Obviously you could not use the Serial1 object if those pins are doing something else.
To verify this, I pulled out an SSD1306 128x64 display. And I am using the Adafruit SSD1306 library. So I brought up their example sketch, modified it slightly as my display has I2C address 0x3c default was 0x3d and it worked..
So then moved it to pins 0, 1
Changed the sketch: To define and use Wire2.
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
#define WIRE2_SCL_PIN 0
#define WIRE2_SDA_PIN 1
TwoWire Wire2(WIRE2_SCL_PIN, WIRE2_SDA_PIN);
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire2, OLED_RESET);
Rebuilt the sketch and the example stuff is running on the display.
Hope that helps
The 3rd I2C bus works!
Thank you @Koepel and @KurtE
I now have 3 active I2C buses along with BLE and the Serial Monitor working together.
I wish I could mark 2 solutions.
@Koepel 's post above does work, but I must have made a dumb mistake when originally trying to test it.
It really helped that @KurtE confirmed it.
It seems to work regardless of the prefer_sci bool being true or false.
I am leaving it set to true since the SCI IIC code seems to have been put in place for some purpose and that is how it appears to be classified on the full pinout diagram...
#include <Wire.h>
TwoWire Wire2(WIRE2_SCL_PIN, WIRE2_SDA_PIN, SPEED_STANDARD, ADDRESS_MODE_7_BITS, true);
Wire2.begin();
FYI - after upgrading to core 1.0.4 my 3rd I2C bus had to remove the "SPEED_STANDARD" parameter.
The code I was using...
#include <Wire.h>
...gave the following error message:
'SPEED_STANDARD' was not declared in this scope
^~~~~~~~~~~~~~exit status 1
Compilation error: 'SPEED_STANDARD' was not declared in this scope
Hovering my mouse pointer over Wire2 for the hint showed:
TwoWire Wire2(WIRE2_SCL_PIN, WIRE2_SDA_PIN, <recovery - expr>(),ADDRESS_MODE_7_BITS, true)
Just removing SPEED_STANDRD works:
TwoWire Wire2(WIRE2_SCL_PIN, WIRE2_SDA_PIN, ADDRESS_MODE_7_BITS, true);
Peeking around the Wire library it appears they are defining RATE now independently.
Now I just need to confirm I can individually set all 3 I2C busses to different rates.
