arduino uno r4 wifi model
- boards manager install OK
- Port OK
- Example Code Upload, But No device found on COM18
Failed uploading: uploading error: exit status 1. Error Print - Try Firmware Updates Failed
what's happen ? and What's the solution?
Hi @lovedream0517. I'm going to ask you to post the full verbose output from an upload attempt.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
compilation in the "Preferences" dialog.<CODE/>
icon on the post composer toolbar.```
) to your reply to make sure the error messages are correctly formatted.스케치는 프로그램 저장 공간 51640 바이트(19%)를 사용. 최대 262144 바이트.
전역 변수는 동적 메모리 6744바이트(20%)를 사용, 26024바이트의 지역변수가 남음. 최대는 32768 바이트.
It's the same as the number 3 I wrote.
Please try again, but this time be careful to follow my instructions exactly so that the forum helpers will have the information we need to effectively provide assistance.
It's the same if I try again. The firearm update in the forum helper keeps failing as well. Please tell me how to fix it specifically.
I'm ready to help you solve the problem as soon as you provide the information I requested.
FQBN: arduino:renesas_uno:unor4wifi
Using board 'unor4wifi' from platform in folder: C:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0
Using core 'arduino' from platform in folder: C:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0
Detecting libraries used...
C:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\아이씨뱅큐\AppData\Local\Temp\arduino\sketches\8CD44A36DEE5885B244FCD06CD9CF992/Blink.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\variants\UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\cores\arduino/tinyusb -IC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\cores\arduino/api/deprecated -IC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\cores\arduino/api/deprecated-avr-comp -IC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\cores\arduino -IC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\variants\UNOWIFIR4 -iprefixC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0 @C:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\variants\UNOWIFIR4/includes.txt C:\Users\아이씨뱅큐\AppData\Local\Temp\arduino\sketches\8CD44A36DEE5885B244FCD06CD9CF992\sketch\Blink.ino.cpp -o nul
Generating function prototypes...
C:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\아이씨뱅큐\AppData\Local\Temp\arduino\sketches\8CD44A36DEE5885B244FCD06CD9CF992/Blink.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\variants\UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\cores\arduino/tinyusb -IC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\cores\arduino/api/deprecated -IC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\cores\arduino/api/deprecated-avr-comp -IC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\cores\arduino -IC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\variants\UNOWIFIR4 -iprefixC:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0 @C:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.1.0\variants\UNOWIFIR4/includes.txt C:\Users\아이씨뱅큐\AppData\Local\Temp\arduino\sketches\8CD44A36DEE5885B244FCD06CD9CF992\sketch\Blink.ino.cpp -o C:\Users\아이씨뱅큐\AppData\Local\Temp\3722212988\sketch_merged.cpp
C:\Users\아이씨뱅큐\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\아이씨뱅큐\AppData\Local\Temp\3722212988\sketch_merged.cpp
스케치를 컴파일 중…
"C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992/Blink.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/tinyusb" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4" "-iprefixC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0" "@C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/includes.txt" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992\\sketch\\Blink.ino.cpp" -o "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992/Blink.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/tinyusb" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4" "-iprefixC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0" "@C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/includes.txt" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4\\variant.cpp" -o "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992\\core\\variant.cpp.o"
"C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -c -w -Os -g3 -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu11 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/tinyusb" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4" "-iprefixC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0" "@C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/includes.txt" -o "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992\\core\\tmp_gen_c_files\\main.c.o" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4\\tmp_gen_c_files\\main.c"
"C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -c -w -Os -g3 -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu11 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/tinyusb" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4" "-iprefixC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0" "@C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/includes.txt" -o "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992\\core\\tmp_gen_c_files\\pin_data.c.o" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4\\tmp_gen_c_files\\pin_data.c"
"C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-gcc" -c -w -Os -g3 -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu11 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/tinyusb" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/api/deprecated" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\cores\\arduino" "-IC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4" "-iprefixC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0" "@C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/includes.txt" -o "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992\\core\\tmp_gen_c_files\\common_data.c.o" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4\\tmp_gen_c_files\\common_data.c"
Using precompiled core: C:\Users\아이씨뱅큐\AppData\Local\Temp\arduino\cores\arduino_renesas_uno_unor4wifi_d14ab33de9464a18afb9bfa05993a028\core.a
Linking everything together...
"C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -Wl,--gc-sections --specs=nosys.specs -w -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -o "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992/Blink.ino.elf" "-LC:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992" "-LC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4" "-TC:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/fsp.ld" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992\\sketch\\Blink.ino.cpp.o" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992\\core\\tmp_gen_c_files\\common_data.c.o" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992\\core\\tmp_gen_c_files\\main.c.o" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992\\core\\tmp_gen_c_files\\pin_data.c.o" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992\\core\\variant.cpp.o" -Wl,--whole-archive -Wl,--start-group "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.1.0\\variants\\UNOWIFIR4/libs/libfsp.a" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992/..\\..\\cores\\arduino_renesas_uno_unor4wifi_d14ab33de9464a18afb9bfa05993a028\\core.a" -Wl,--no-whole-archive --specs=nano.specs -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group "-Wl,-Map,C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992/Blink.ino.map"
"C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary -j .text -j .data "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992/Blink.ino.elf" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992/Blink.ino.bin"
"C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -j .text -j .data "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992/Blink.ino.elf" "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992/Blink.ino.hex"
"C:\\Users\\아이씨뱅큐\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\아이씨뱅큐\\AppData\\Local\\Temp\\arduino\\sketches\\8CD44A36DEE5885B244FCD06CD9CF992/Blink.ino.elf"
Error and Power Input, Board Very Hot. what's happen? what's the solution?
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
https://www.arduino.cc/en/Main/Products
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
https://www.arduino.cc/en/Tutorial/BuiltInExamples/Blink
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
Arduino IDE File > Examples > 01.Basic > Blink code upload, Like what I wrote above, an error occurs and the board gets hot
