Hi @Heelix and @mauroalfieri. There were some reports of uploads to the UNO R4 WiFi failing with a "No device found on ..." error here:
The developers made a fix in the firmware. There is now a pre-release version of that firmware available and the affected users are reporting that it solved the error for them.
If you would like to give that pre-release version of the firmware a try, I'll provide instructions for installing it:
- Unplug any non-essential USB devices from your computer.
- Connect the UNO R4 WiFi board to your computer with the USB cable.
- Open the release page for the latest version of the firmware in your web browser:
https://github.com/arduino/uno-r4-wifi-usb-bridge/releases/tag/0.2.1-rc1 - Click the "unor4wifi-update-macos.zip"download link under the "Assets" section of the release page:
- Wait for the download to finish.
- Unzip the downloaded file.
- Control-click on the unzipped
unor4wifi-update-macosfolder.
A context menu will open. - Select "New Terminal at Folder" from the context menu.
A terminal window will open. - Type the following command in the Terminal window:
chmod a+x update.command && sudo xattr -d com.apple.quarantine bin/espflash && sudo xattr -d com.apple.quarantine bin/unor4wifi-reboot-macos && ./update.command - Press the Enter key.
A "Password" prompt will appear in the Terminal window. - Type your macOS user password.
- The terminal window might now show a list of the serial ports present on your computer.
For example:
If so, use the ↓ key on your keyboard to select the port of the UNO R4 WiFi board from the list and then press the Enter key.Start flashing firmware [2023-07-11T08:55:51Z INFO ] Detected 6 serial ports [2023-07-11T08:55:51Z INFO ] Ports which match a known common dev board are highlighted [2023-07-11T08:55:51Z INFO ] Please select a port ❯ /dev/cu.wlan-debug /dev/tty.wlan-debug /dev/cu.Bluetooth-Incoming-Port /dev/tty.Bluetooth-Incoming-Port /dev/cu.usbmodem2214101 - USB JTAG_serial debug unit /dev/tty.usbmodem2214101 - USB JTAG_serial debug unit - The terminal window will now show the following prompt:
Press the N key on your keyboard.? Remember this serial port for future use? (y/n) › - The flashing process should now start. Wait for it to finish, as indicated by output that looks something like this:
[2023-07-11T08:59:44Z INFO ] Serial port: '/dev/cu.usbmodem2214101' [2023-07-11T08:59:44Z INFO ] Connecting... [2023-07-11T08:59:45Z INFO ] Using flash stub Chip type: esp32s3 (revision v0.1) Crystal frequency: 40MHz Flash size: 8MB Features: WiFi, BLE MAC address: dc:54:75:c4:c6:54 [00:00:14] [========================================] 689/689 0x0 - Close the Terminal window.
- Disconnect the USB cable of the UNO R4 WiFi board from your computer.
- Connect the UNO R4 WiFi board to your computer with the USB cable again.
Please let me know if you have any questions or problems while following those instructions.
