UNO R4 WIFI problem compiling with _BV function
Hi Everyone
I'm new to Arduino UNO R4 and this is my first time posting.
I'm trying to compile a sketch on UNO R4 Wifi which works fine on UNO R3 and which uses a library "cADC" to read Thermocouple temperatures from a MCP3424 18-bit ADC
When compiling I am getting
"error '_BV' was not declared in this scope"
The library uses "_BV" for reading and setting bits on the config register in the ADC
I'm running IDE 2.3.2 with select Board: UNO R4 Wifi with Boards package 1.1.0 loaded
The error message is quite descriptive but I am confused about what I should exactly do.
Is "_BV" supported on UNO R4 Renesas architecture ?
I know that _BV is anticipating 8-bits and the Renesas CPU is 32 bits
Should I try to use "BIT" functions instead
How do I "declare the function in this scope"
Apologies if these are dumb newby questions
Any suggestion would be appreciated.
Thank you in advance.
library code for cADC.cpp and cADC.h is below
cADC.cpp
// cADC library
// Version date: August 20, 2010
// interface with MCP3424 18-bit ADC
// *** BSD License ***
// Copyright (c) 2010, MLG Properties, LLC
// All rights reserved.
// Contributor:  Jim Gallt
// Redistribution and use in source and binary forms, with or without modification, are
// permitted provided that the following conditions are met:
//   Redistributions of source code must retain the above copyright notice, this list of
//   conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright notice, this list
//   of conditions and the following disclaimer in the documentation and/or other materials
//   provided with the distribution.
//   Neither the name of the MLG Properties, LLC nor the names of its contributors may be
//   used to endorse or promote products derived from this software without specific prior
//   written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS
// OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
// MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL
// THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
// SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
// HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
// OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
// SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Acknowledgement is given to Bill Welch for his development of the prototype hardware and software
// upon which much of this library is based.
// 20110609  Significant revision for flexibility in selecting modes of operation
// 20120126  Arduino 1.0 compatibility
//  (thanks and acknowledgement to Arnaud Kodeck for his code contributions).
#include "cADC.h"
#if defined(ARDUINO) && ARDUINO >= 100
#define _READ read
#define _WRITE write
#else
#define _READ receive
#define _WRITE send
#endif
// --------------------------------------------------- dFilterRC
filterRC::filterRC() {
 level = 0;
 y = 0;
 first = true;
void filterRC::init( int32_t percent ) {
 level = percent;
 first = true;
int32_t filterRC::doFilter ( int32_t xi ) {
   if( first) {
     y = xi;
     first = false;
     return y;
   float yy = (float)(100 - level) * (float)xi * 0.01;
   float yyy = (float)level * (float)y * 0.01;
   yy += yyy;
   return y = round( yy );
cADC::cADC( uint8_t addr ) {
  a_adc = addr; // address of ADC chip
  cal_gain = CAL_GAIN;
  cal_offset = CAL_OFFSET;
  setCfg( ADC_BITS_18, ADC_GAIN_8, ADC_CONV_1SHOT ); // 18 bit, 8X, 1 shot
// --------------------------------------------------setCfg
void cADC::setCfg( uint8_t res, uint8_t gain, uint8_t conv  ){
  cfg = res | gain | conv;
  // set uV value of the LSB for conversions to uV
  switch ( res ){
    case ADC_BITS_12 :
      convTime = _CONV_TIME_12;
      nLSB = 0;  // bit shift count = ADC_BITS - 12
    case ADC_BITS_14 :
      convTime = _CONV_TIME_14;
      nLSB = 2;  // bit shift count = ADC_BITS - 12
    case ADC_BITS_16 :
      convTime = _CONV_TIME_16;
      nLSB = 4;  // bit shift count = ADC_BITS - 12
    case ADC_BITS_18 :
      convTime = _CONV_TIME_18;
      nLSB = 6;  // bit shift count = ADC_BITS - 12
    default :
// -------------------------------------------------- getConvTime
uint16_t cADC::getConvTime() {
  return convTime;
// --------------------------------------------------setCal
void cADC::setCal( float gain, int8_t offs ) {
  cal_gain = gain - 1.0;  // to reduce loss of significance
  cal_offset = offs;
int32_t cADC::readuV() {
  int32_t v;
  // resolution determines number of bytes requested
  if( ( cfg & ADC_RES_MASK ) == ADC_BITS_18 ) { // 3 data bytes
    Wire.requestFrom( a_adc, (uint8_t) 4 );
    uint8_t a = Wire._READ(); // first data byte
    uint8_t b = Wire._READ(); // second data byte
    uint8_t c = Wire._READ(); // 3rd data byte
    v = a;
    v <<= 24; // v = a : 0 : 0 : 0
    v >>= 16; // v = s : s : a : 0
    v |= b; //   v = s : s : a : b
    v <<= 8; //  v = s : a : b : 0
    v |= c; //   v = s : a : b : c
  else { // 2 data bytes
    Wire.requestFrom( a_adc, (uint8_t) 3 );
    v = a;
  uint8_t stat = Wire._READ(); // read the status byte returned from the ADC
  v *= 1000;  // convert to uV.  This cannot overflow ( 10 bits + 18 bits < 31 bits )
  // bit shift count for ADC gain
  uint8_t gn = stat & ADC_GAIN_MASK;
  // shift based on ADC resolution plus ADC gain
  v >>= ( nLSB + gn ); // v = raw reading, uV
  // calculate effect of external calibration gain; minimize loss of significance
  int32_t deltaV = round( (float)v * cal_gain );
  return v + deltaV;  // returns corrected, unfiltered value of uV
void cADC::nextConversion( uint8_t chan ) {
  Wire.beginTransmission( a_adc );
  Wire._WRITE( cfg | ( ( chan & B00000011 ) << ADC_C0 ) );
  Wire.endTransmission();
// ----------------------------------------------------------- ambSensor
ambSensor::ambSensor( uint8_t addr ) {
 a_amb = addr; // I2C address
 filter.init( 0 );
 setCfg( AMB_BITS_12 ); // default is 12 bits
// sets up the configuration byte
void ambSensor::setCfg( uint8_t res ) {
  cfg = res | convMode;
  switch ( res ) {
    case AMB_BITS_9 :
      convTime = _AMB_CONV_TIME_9;
      nLSB = 7;  // shift count
    case AMB_BITS_10 :
      convTime = _AMB_CONV_TIME_10;
      nLSB = 6;  // shift count
    case AMB_BITS_11 :
      convTime = _AMB_CONV_TIME_11;
      nLSB = 5;  // shift count
    case AMB_BITS_12 :
      convTime = _AMB_CONV_TIME_12;
      nLSB = 4;  // shift count
// returns minimum time required for a conversion
uint16_t ambSensor::getConvTime() {
  return convTime;
// puts the 9800 in shutdown.  Required for one-shot mode
void ambSensor::ambShutdown() {
  Wire.beginTransmission( a_amb );
  Wire._WRITE( AMB_REGSEL_CFG ); // point to config reg
  Wire._WRITE( (uint8_t)AMB_SHUTDOWN );
  // delay needed here?
void ambSensor::init( int fpercent, uint8_t cmode ) {
  filter.init( fpercent );
  convMode = cmode;
  if( cmode == AMB_CONV_1SHOT )
    ambShutdown();
void ambSensor::nextConversion() {
  Wire._WRITE( (uint8_t)AMB_REGSEL_CFG ); // configuration register
  Wire._WRITE( cfg ); // request a conversion
int32_t ambSensor::readSensor() {
  uint8_t a, b;
  Wire._WRITE( (uint8_t)AMB_REGSEL_TMP ); // point to temperature reg.
  Wire.requestFrom( a_amb, (uint8_t)2 );
  a = Wire._READ();
  b = Wire._READ();
  raw = a;     //  0 : 0 : 0 : a
  raw <<= 24;   // a : 0 : 0 : 0
  raw >>= 16;  //  s : s : a : 0
  raw |= b;    //  s : s : a : b
  // 12-bit, nLSB = 4
  // 11-bit, nLSB = 5
  // 10-bit, nLSB = 6
  //  9-bit, nLSB = 7
  raw >>= nLSB;  // first nLSB bits in b are undefined
  raw <<= nLSB;  // they are gone now, replaced by zero
  raw >>= 4;  // move bits to right to form raw code
  filtered = filter.doFilter( raw << AMB_FACTOR ); // create more resolution for filter
  ambC = (float)filtered;
  ambC += temp_offset * AMB_LSB_INV;  // calibration correction
  ambC *= AMB_LSB;  // Ta = code / 16 per MCP9800 datasheet
  ambF = 1.8 * ambC + 32.0;
  return filtered;
float ambSensor::getAmbC() { return ambC; }
float ambSensor::getAmbF() { return ambF; }
float ambSensor::getOffset() {
 return temp_offset;
void ambSensor::setOffset( float tempC ) {
 temp_offset = tempC;
#undef _READ
#undef _WRITE
and cADC.h
// cADC library
// Revision history:
//  Original version date: 9-June-2011
//  20110609  Revisions to cADC for greater control over mode selection
//  20120126:  Compatibility with Arduino 1.0
#ifndef _cADC_H
#define _cADC_H
#include <Wire.h>
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
// class for digital filtering of raw signals
class filterRC {
public:
 filterRC();
 void init( int32_t percent );
 int32_t doFilter( int32_t xi );
protected:
 int32_t level; // filtering level, 0 to 100%
 int32_t y; // most recent value of function
 bool first; // special handling of first call
// -------------- ADC configuration
#define ADC_RDY 7  // ready bit
#define ADC_C1  6  // channel selection bit 1
#define ADC_C0  5  // channel selection bit 0
#define ADC_CMB 4  // conversion mode bit (1 = continuous 0 = one shot)
#define ADC_SR1 3  // sample rate selection bit 1 (11 = 18 bit)
#define ADC_SR0 2  // sample rate selection bit 0
#define ADC_G1  1  // gain select bit 1
#define ADC_G0  0  // gain select bit 0
#define ADC_GAIN_MASK ( _BV(ADC_G1) | _BV(ADC_G0) )
#define ADC_RES_MASK  ( _BV(ADC_SR1) | _BV(ADC_SR0) )
// some 3424 config register values
#define ADC_BITS_18 ( _BV(ADC_SR1) | _BV(ADC_SR0) )
#define ADC_BITS_16 ( _BV(ADC_SR1) )
#define ADC_BITS_14 ( _BV(ADC_SR0) )
#define ADC_BITS_12 0
#define ADC_GAIN_8 ( _BV(ADC_G1) | _BV(ADC_G0) )
#define ADC_GAIN_4 ( _BV(ADC_G1) )
#define ADC_GAIN_2 ( _BV(ADC_G0) )
#define ADC_GAIN_1 0
#define ADC_CHAN_4 ( _BV(ADC_C1) | _BV(ADC_C0) )
#define ADC_CHAN_3 ( _BV(ADC_C1) )
#define ADC_CHAN_2 ( _BV(ADC_C0) )
#define ADC_CHAN_1 0
#define ADC_CONV_CONT  ( _BV(ADC_CMB) )
#define ADC_CONV_1SHOT ( _BV(ADC_RDY) )
// calibration of ADC
#define CAL_OFFSET  ( 0 )  // microvolts
#define CAL_GAIN 1.00
// ADC I2C address
#define A_ADC 0x68
#define BITS_TO_uV 15.625  // LSB = 15.625 uV, 18 bit mode
#define MAX_CHAN 4 // maximum number of channels to sample
#define _CONV_TIME_18 300 // millis
#define _CONV_TIME_16 80 // millis
#define _CONV_TIME_14 20 // millis
#define _CONV_TIME_12 5 // millis
class cADC {
 public:
  cADC( uint8_t addr = A_ADC ); // constructor
  int32_t readuV(); // retrieves sample and converts to uV
  void nextConversion( uint8_t chan );  // requests the next conversion
  void setCal( float gaincal, int8_t offs ); // sets calibration gain/offset for 50000 uV and 0 uV
  void setCfg( uint8_t resolution = ADC_BITS_18, uint8_t gain = ADC_GAIN_8, uint8_t conversion = ADC_CONV_1SHOT );
  uint16_t getConvTime(); // returns time required for a conversion
 protected:
  uint8_t cfg; // resolution, gain, and conversion mode settings
  uint8_t a_adc;
  float cal_gain; // = calibration factor minus 1.0000
  int8_t cal_offset;
  uint16_t convTime;  // milliseconds
//  float xLSB;  // microvolt value of LSB
  // LSB uV = 1,000 * 2^12 / 2^n, where n = ADC resolution bits
  uint8_t nLSB; // shift count = resolution bits minus 12
// -------------------- MCP9800 configuration
#define AMB_REGSEL_CFG B00000001
#define AMB_REGSEL_TMP B00000000
// configuration register bits
#define AMB_CFG_CONV 7 // 1 shot vs continuous
#define AMB_CFG_RES1 6 // resolution MSB
#define AMB_CFG_RES0 5 // resolution LSB
#define AMB_CFG_FLT1 4 // fault queue
#define AMB_CFG_FLT0 3 // fault queue
#define AMB_CFG_PLRT 2 // active polarity
#define AMB_CFG_COMP 1 // comparator
#define AMB_CFG_SHUT 0 // shutdown
#define AMB_BITS_9  0
#define AMB_BITS_10 ( _BV( AMB_CFG_RES0 ) )
#define AMB_BITS_11 ( _BV( AMB_CFG_RES1 ) )
#define AMB_BITS_12 ( _BV( AMB_CFG_RES1 ) | _BV( AMB_CFG_RES0 ) )
#define AMB_SHUTDOWN ( _BV( AMB_CFG_SHUT ) )
#define AMB_CONV_1SHOT ( _BV( AMB_CFG_CONV ) | _BV( AMB_CFG_SHUT ) )
#define AMB_CONV_CONT 0
#define AMB_CONV_MASK ( _BV( AMB_CFG_CONV ) | _BV( AMB_CFG_SHUT ) )
#define _AMB_CONV_TIME_9 38 // 9-bit conversion time
#define _AMB_CONV_TIME_10 75 // 10-bit conversion time
#define _AMB_CONV_TIME_11 150 // 11-bit conversion time
#define _AMB_CONV_TIME_12 290 // 12-bit conversion time
#define A_AMB 0x48 // I2C address for MCP9800
//#define MCP9800_DELAY _AMB_CONV_TIME_12 // minimum sample period for MCP9800
#define TEMP_OFFSET ( 0.0 )  // Celsius offset
#define AMB_FACTOR 10 // n << 10 = 1024 use to create some additional resolution
#define AMB_LSB (0.0625/1024) // value of MCP9800 LSB in 12-bit mode, div. by 1000
#define AMB_LSB_INV (16.0*1024) // reciprocal of AMB_LSB
// this class communicates with MCP9800 ambient sensor and optionally performs filtering
class ambSensor {
 public:
  ambSensor( uint8_t addr = A_AMB ); // default constructor
  void init( int fpercent = 0, uint8_t cmode = AMB_CONV_1SHOT ); // setup the MCP9800, initialize the filter
  void nextConversion(); // instruct 9800 to perform a conversion
  int32_t readSensor(); // reads chip, returns 16x the ambient Celsius temperature
  float getAmbF(); // computes and returns current F
  float getAmbC(); // computes and returns current C
  float getOffset(); // returns calibration information
  void setOffset( float tempC ); // set calibration offset
  void setCfg( uint8_t res );
  void ambShutdown(); // put the 9800 in shutdown mode (must follow Wire.begin() )
 protected:
  uint8_t cfg; // configuration byte
  uint8_t convMode; // AMB_CONV_1SHOT or AMB_CONV_CONT
  uint16_t convTime; // required delay between conversions
  uint8_t nLSB;  // shift count to get rid of insignificant bits
  uint8_t a_amb;  // I2C address
  filterRC filter;
  float temp_offset;  // calibration offset (Celsius)
  float ambF, ambC; // most recent filtered readings
  int32_t filtered; // up to date filtered raw reading
  int32_t raw; // most recent raw sensor reading
#endif
_BV(...) is apparently an AVR only thing. Try changing _BV(...) to bit(...) in the library and see how that goes.
Simply define:
#define _BV( bit ) ( 1 << (bit) )
Guglielmo
solved - many thanks
regds Phil
