when I was coding a school project suddenly my R4 stopped being able to send or receive serial data, and the Tx/Rx LEDs were not turning on. I had to re-flash the firmware n the ESP32 as it wasn't even recognized by the IDE as an R4 WiFi. Now, my R4 has stopped working again, but this time partially. I can write a simple program and it works correctly but as soon as I try to connect it to the Arduino Cloud it crashes showing me this message:
Firmware name: "C:\Users\Miguel\AppData\Local\Temp\arduino\sketches\A972D38690D3AA1094BE11FD845DC34E/SketchCIencias.ino", compiled on: Jun 6 2024
Fault on interrupt or bare metal(no OS) environment
===== Thread stack information =====
addr: 20007eb8 data: 200015fc
addr: 20007ebc data: 00006269
addr: 20007ec0 data: 200009d8
addr: 20007ec4 data: 000043a7
addr: 20007ec8 data: 5adfa79d
addr: 20007ecc data: 09fd35ef
addr: 20007ed0 data: 00000000
addr: 20007ed4 data: 000151f1
addr: 20007ed8 data: 0001f950
addr: 20007edc data: 40046f00
addr: 20007ee0 data: 00000000
addr: 20007ee4 data: 0001522f
addr: 20007ee8 data: 0001f950
addr: 20007eec data: 0000db9f
addr: 20007ef0 data: 0001f950
addr: 20007ef4 data: 00012347
addr: 20007ef8 data: 0001233d
addr: 20007efc data: 00002599
=================== Registers information ====================
R0 : 00000000 R1 : 00000018 R2 : 200031a8 R3 : 00000000
R12: 00000001 LR : 0000c7d7 PC : 00000000 PSR: 400f0000
Usage fault is caused by attempts to switch to an invalid state (e.g., ARM)
Show more call stack info by run: addr2line -e "C:\Users\Miguel\AppData\Local\Temp\arduino\sketches\A972D38690D3AA1094BE11FD845DC34E/SketchCIencias.ino".elf -a -f 00000000 0000c7d6 00006268 000043a6 000151f0 0001522e 0000db9e 00012346 0001233c
I have tried reflashing the firmware, I erased the firmware from the ESP32 (since its showing me that the firmware name is a random sketch name that I don't even have in my pc anymore) and flashed it again with esptool, but nothing works
As far as I know I'm running a normal sketch since I just use the Arduino IDE (and the cloud editor). I had to reflash the firmware using Powershell a couple of times, as I said, since the board wasn't getting recognized. I can provide the sketch I'm currently working on (not finished) but I don't think it's the cause of the problem, since any other program that does not connect to the internet works as expected
#include <LCD_I2C.h>
#include <ADebouncer.h>
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/86fc0a30-f7d8-4a51-b2fc-f6c8f1024115
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
float waterFlow;
bool waterLevel;
CloudTime lastResuply;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include <Wire.h>
//#include <RTC.h>
//#include <NTPClient.h>
#include "thingProperties.h"
LCD_I2C lcd(0x27, 16, 2);
ADebouncer resuply, dispensar;
// WiFiUDP Udp; // A UDP instance to let us send and receive packets over UDP
// NTPClient timeClient(Udp);
// /*Variables y Constantes✨ */
float volDispensado;
float saldoAnterior = 0;
float saldoActual = 0;
#define COSTO_AGUA 1.50
bool DISPENSAR;
bool RESUPLY;
#define BOMBA 8
#define VALVULA 7
// unsigned long unixTime;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
// Defined in thingProperties.h
// initProperties();
// Connect to Arduino IoT Cloud
//ArduinoCloud.begin(ArduinoIoTPreferredConnection);
lastResuply = ArduinoCloud.getLocalTime();
lcd.begin();
lcd.backlight();
resuply.mode(INSTANT, 250, HIGH);
dispensar.mode(INSTANT, 250, HIGH);
pinMode(12, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
//ArduinoCloud.update();
if (Serial.available() > 0) {
saldoActual = Serial.parseFloat();
// RESUPLY = resuply.debounce(digitalRead(11));
// if (RESUPLY == LOW) {
// lastResuply = ArduinoCloud.getLocalTime();
// Serial.println("Time updated");
if (saldoActual != saldoAnterior) {
saldoAnterior = saldoActual;
lcd.clear();
lcd.setCursor(0, 1);
lcd.clear();
lcd.setCursor(5, 0);
lcd.print("Saldo"),
lcd.setCursor(5, 1);
lcd.print(saldoActual);
Serial.print("Su saldo es: ");
Serial.println(saldoActual);
DISPENSAR = dispensar.debounce(digitalRead(12));
if (DISPENSAR == LOW && saldoActual != 0) {
float volRequerido = saldoActual/COSTO_AGUA;
Serial.println(volRequerido);
do {
hydraulicsON();
} while (volDispensado < volRequerido);
void hydraulicsON() {
Serial.println("Dispensing");
digitalWrite(BOMBA, HIGH);
digitalWrite(VALVULA, HIGH);
volDispensado = analogRead(A1);
When I try running the sketch it shows the usual "connecting to WiFi" serial text from the arduino cloud code, but then says that it cannot recognize the device id and crashes showing me the message I put here first. Currently I don't have anything plugged to the board (I would normally have an I2C LCD screen, two push buttons to digital pins 11 and 12 (as pullup with the internal resistor), and two outputs from pin 7 and 8 to some optocouplers, connected to some power MOSFETs (They do not share a ground connection with the Arduino, that's why I used the optocouplers)
Hey sorry for the late reply. And yeah the code pretty much works as expected when I don't connect it to the Cloud. I built the program using the default Cloud sketch from the Arduino Cloud as a baseline. The other libraries from what I'm aware don't rely on a specific architecture to work so I don't really know what could be happening. I have also tried uploading a blank Cloud sketch that just connects to the cloud and links some variables to a cloud Thing.
