Uno Ram Usage ?
Am fairly new to C++ and while coding a project find the RAM is almost used up, yet the global and local variables I specified seem low by comparison and am only using 4 common libraries.
Searching around seems like nested functions can cause high usage but not doing that, its all quiet simple sequential code.
Do these figures look typical for C++, do the libraries/C++ normally use up so much ram or is something wrong ?
thanks.
Libraries - Wire, RTClib, LiquidCystal, EEprom
Globals - Floats 30, Bytes 70, Int 10, Locals Bytes 10 - estimate about 330 bytes in total ?
from Studio 7 and A 1.65
Binary sketch size: 23,624 bytes (used 73% of a 32,256 byte maximum) (0.81 secs)
Minimum Memory Usage: 1726 bytes (84% of a 2048 byte maximum)
You are probably wasting your RAM on strings constants that need RAM when not put to PROGMEM.
But without seeing you code, that's just a guess.
(30 * 4) + 70 + (10 * 2) + 10 = ?
This is the Programming section; it's a reasonable expectation to see code.
Sorry Guys, just thought I might have missed a very general point about C++ and Ram useage as its all new to me. ( old Pic Assembly coder)
My full code attached, please excuse/ don’t laught too much at its simplicity as finding it hard to convert to the C++ way.
form.ino.ino (48.8 KB)
Everything that looks like thislcd.print("Tank Controller ");should look like thislcd.print(F("Tank Controller "));
You’ve got a lot of code for adding leading zeroes, it seems, like this
		if (ssON_hh < 10) {
			lcd.print (F("0"));
			lcd.print (ssON_hh,DEC);
		else{
			lcd.print (ssON_hh);
Wouldn’t it be better to factor it all into a single function?
void printLeadingZero (int x)
  if (x < 10)
    lcd.print ('0');
  lcd.print (x);
You could even pass in the device, so it would work for Serial or LCD.
Sketch as posted: 1695 bytes RAM
Sketch with F() for Serial: 1523 bytes RAM
Sketch with F() for lcd: 997 bytes RAM*
  • this is attached
form.ino.ino (50.4 KB)
I got it to just over 700 bytes of RAM.
The code could be a lot smaller with some factoring.
You'll save even more RAM if you make the I/O pins "const byte", as they should be.
Many thanks guys,
That does seem to cure the problem, though was clearly not aware of the Strings/Progmem issue.
Could not find an explanation of that F parameter in the lcd.print section though it is mentioned in the Serial.print "You can pass flash-memory based strings to Serial.print() by wrapping them with F()." but think the point about the RAM space is easily missed by the beginer.
Did find this link with gives a fuller explanation.
Thanks also for the heads up about the leading zeros in its own function and I/O pins though expect there are a few other areas I could similarly improve, once I learn a lot more ! :slight_smile:
cheers
with all the tips above, you may want to simplify your code using sprintf()
instead of:
   lcd.setCursor (0,0);
 if(now.hour() <10)
 lcd.print('0');
 lcd.print(now.hour(), DEC);
 lcd.print(":");
 if(now.minute() <10)
 lcd.print('0');
 lcd.print(now.minute(), DEC);
 lcd.print(" ");
 float tst1 = 0;
 lcd.print (tempC, DEC);
try something like:
  char myMessage[12] = "";
  sprintf(myMessage"%02d:%02d %2dC", now.hour(), now.minute(), (int)tempC);
  lcd.print(myMessage);
it uses a bit of overhead but it is easy to read
Using sprintf adds around 1.5k code...
P.S. in the code I posted above, I forgot to change some println("..."),
after changing them I got to 859 bytes .
Whandall:
Yes, thanks, just been checking it out and noticing your changes and the lcd.write and then seeing the WString.h code when trying out lcd output variations.
learnt a lot !
cheers
BulldogLowell:
Of course, you really meant sprint_P :wink:
