I just got two new UNO SMD R2 from sparkfun. I discovered a very bad bug on my boards. It seems that something is allowing 5V on to the 3.3V power rail (might have blown a nice new IMU too... This is observed on both boards so it is not a fluke. Can anyone else confirm this on their SMD R2?
This happens with both USB and external DC power jack. I'm having some issues troubleshooting as the UNO SMD R2 eagle files are not available, only the R1 is posted right now. 5V DC bus voltage is 4.97, 3.3V bus is 4.93 unfortunately.
Sorry for the long delay in response, went on vacation.
Anywho: this is not an UNO R2, this is an UNO SMD R2. I've posted pictures below:
Has anyone ever seen these before? I'm just looking for a parts list or schematic. I think there might be a 5.5v regulator in place of the 3.3v regulator as the two busses are not shorted together (testing with my meter).
I've just purchased an Uno smd version. I found that the 3.3v pin is actually at 5.0v, even with a load on it.
I had a closer look at the 3.3v regulator (LP2985) and it's marked "LOUA", same as the one in the post by creeg2 above.
According to the datasheet at national semiconductor (http://www.national.com/ds/LP/LP2985.pdf), this is a 5.0v regulator, which explains why I'm not seeing 3.3v.
I've emailed the vendor where I purchased it, we'll see what can be done about it.
