Uno Timer2 Interrupts
Hey all,
Trying to get timer2 interrupts working for my UNO. Here is my current code I’m using:
#include <Wire.h>
volatile uint16_t setbit = 0;
  // initialize timer2
  noInterrupts();           // disable all interrupts
  TCCR2A = 0;
  TCCR2B = 0;
  TCNT2 = 0;
  OCR2A = 157;            // compare match register 16MHz/1024/100Hz = 156.25 < 256 OK!
  TCCR2B |= (1 << WGM12);   // CTC mode
  TCCR2B |= (1 << CS10);    // 1024 prescaler
  TCCR2B |= (1 << CS12);    // 1024 prescaler
  TIMSK2 |= (1 << OCIE2A);  // enable timer compare interrupt
  interrupts();             // enable all interrupts
ISR(TIMER2_COMPA_vect)          // timer compare interrupt service routine
  setbit=1;
  if (setbit==0)
    //Serial.println("Loop");
  if (setbit==1)
  Serial.print("Interrupt "); Serial.println(millis()); //Serial print the current millis
  setbit = 0;
This should call an interrupt every 10ms (100hz). Instead I’m getting the following output:
Interrupt 1
Interrupt 3
Interrupt 5
Interrupt 7
Interrupt 9
Interrupt 11
Interrupt 13
Interrupt 15
Interrupt 17
Interrupt 19
Interrupt 21
Interrupt 23
Interrupt 25
Interrupt 27
Interrupt 29
Interrupt 31
Interrupt 33
Interrupt 35
Interrupt 37
I would expect to see
Interrupt 1
Interrupt 11
Interrupt 21
etc.
Any thoughts on what I could be doing wrong? Really struggling with this…
Jim
