Uno to SSC 32U
I need an SSC 32U unit to control 4 continuous servos, I need it to move them in 1 direction for an amount of time determined by an arduino programmed to determine it. I know it is possible to control one directly from an Uno, but I have no idea where t start coding. How do I go about doing this?
Why bother with the SSC 32U? The arduino can control the servos directly!
Mark
PS In fact both the uno and the SSC32U use the same chip!
M
Thanks, is there a difference between coding servos and continuous servos?
Also, since all 4 motors i plan to use will be synchronized, can I get by with one signal pin?
I'm limited to 9 volts, it's not a particularly heavy car, will it work?
JTMMcBroom:
Below is servo test code you can try to see how to control the continuous rotation servos directly from the arduino. Servo controllers are useful when there are a large number of servos or one wants to move standard servos at slower speeds. Also, powering a servo that is made for 4.8-6v directly with 9v may damage the servo.
// zoomkat 3-28-14 serial servo incremental test code
// using serial monitor type a character (s to increase or a
// to decrease) and enter to change servo position
// (two hands required, one for letter entry and one for enter key)
// use strings like 90x or 1500x for new servo position
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include<Servo.h>
String readString;
Servo myservo;
int pos=1500; //~neutral value for continuous rotation servo
//int pos=90;
  myservo.attach(7, 400, 2600); //servo control pin, and range if desired
  Serial.println("serial servo incremental test code");
  Serial.println("type a character (s to increase or a to decrease)");
  Serial.println("and enter to change servo position");
  Serial.println("use strings like 90x or 1500x for new servo position");
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    if(readString.indexOf('x') >0) {
      pos = readString.toInt();
    if(readString =="a"){
      (pos=pos-1); //use larger numbers for larger increments
      if(pos<0) (pos=0); //prevent negative number
    if (readString =="s"){
      (pos=pos+1);
    if(pos >= 400) //determine servo write method
      Serial.println(pos);
      myservo.writeMicroseconds(pos);
      myservo.write(pos);
  readString=""; //empty for next input
That depends on what "not particularly heavy" means. Is that like telling your girlfriend that she's not particularly fat?
How much current can the 9 volt power supply supply?
What kind of terrain is the car running on? In what temperature?
Hi does anyone know how to get a servo to go in the negative position with the SSC-32 I can only move my servos in one direction other then returning back to its starting point
mikez82:
Try the servo "sweep" example in the IDE.
