Uno-to-Uno AVR ISP: “Yikes!” error message (with pic)
Ah, you're right! The resistor placement was a case of following the diagram without paying attention to the reversed position of the rails.
Just another example of why Fritzing's suck.
I have no idea why I bought the one I did; it's a 32.768 Mhz.
I think you'll find it's actually 32.768 kHz, not mHz. That's why I asked, that little round can format is most commonly found in DS1302/7 and other RTC applications.
avr_fred:
I see that now. I wish there was something else as convenient...
OH GOOD GODS, I can’t even get that right. You’re correct, of course, kilohertz not megahertz.
avr_fred:
One observation.
The 10k reset line resistor is a pullup device. It appears you have it wired to the ground side of the power rail rather than VCC.
If the above doesn't resolve the problem then two questions.
  1. Do you know with certainty that the crystal you have is indeed a 16mhz device and is known to work with an ATmega328?
  2. Just for sake of completeness, why don't you post another photo of your breadboard '328 with the crystal wiring changes?
Sorry for the delay. Still getting an error (“avrdude: stk500_recv(): programmer is not responding”). Here’s the new picture. THANKS!
@avr_fred said:
"The 10k reset line resistor is a pullup device. It appears you have it wired to the ground side of the power rail rather than VCC."
Still on the ground side?
kprims:
OY. Yep, fixed now.
New error (tried with both chips, same thing):
Arduino: 1.6.4 (Mac OS X), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega2560 -cstk500v1 -P/dev/cu.usbmodem1411 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xD8:m -Ulfuse:w:0xFF:m
avrdude: Version 6.0.1, compiled on Apr 14 2015 at 16:30:25
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/scabbot/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem1411
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Error while burning bootloader.
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e950f
avrdude: Expected signature for ATmega2560 is 1E 98 01
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
  enabled in File > Preferences.
THANKS AGAIN!
"Using Port : /dev/cu.usbmodem1411
Chip Erase delay : 9000 us"
Try selecting an atmega328p instead of an Atmega2560.
Like Arduno/Uno.
kprims:
Like Arduno/Uno.
Ay ay ay! Done. I think this is a good message, yes?
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/cu.usbmodem1411 -b19200 -Uflash:w:/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/bootloaders/optiboot/optiboot_atmega328.hex:i -Ulock:w:0x0F:m
         AVR Part                      : ATmega328P
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/bootloaders/optiboot/optiboot_atmega328.hex"
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: load data flash data from input file /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: input file /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/bootloaders/optiboot/optiboot_atmega328.hex contains 32768 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 32768 bytes of flash verified
avrdude: reading input file "0x0F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.05s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock verified
NOW, when I move the chip back to the (student’s) board, it’s giving me a “not in sync” error... AND pushing the reset button doesn’t make the onboard LEDs blink... Can I assume the chip is okay (now) and the board is cooked?
Thanks so much for your patience!
"Ay ay ay! Done. I think this is a good message, yes?"
It's a great message. :slight_smile:
Make sure your chip is put back in the Uno with the right orientation. Check both Uno's for the notch in the Dip socket.
I have one clone Uno with the dip socket reversed. Your working Uno should be the one to use for the right pattern.
