Hi guys, I'm guessing the main difference between the two are the inboard features like the USB loader and external power hook up ? also will i need the FTDI Friend for loading code ?
I need to add relays to my board for isolation and diodes as well and i have no real estate on the board unless i add a shield and then that gets bulky.
What's a "Prototino ATMega328" ??
You need to provide links and background information if you want people to respond here...
Anyone have any suggestions ?
Thanks
Looks OK. It looks like you can install either the ICSP header (and then use a standalone programmer like the USBtinyISP, or another Arduino, to program it). Or install the FTDI header and get an FTDI cable.
" With the prototyping area integrated into the board with the microprocessor, your project will have fewer boards and fewer wires, and because of that, fewer mistakes and fewer shorts. "
Mistakes and shorts still possible tho 8)
