Uno: When writing to an SD card, the little red led on the SD card module blinks. How do I emulate this on a larger LED?
Arduino Uno, SD card, random temp sensor (removed from code)
Absolute noob here. I spent a couple hours watching videos and trying to figure this out but I give up lol. It should be easy, right? So, below's my code. I thought it would be a boolean thing. The Tx LED flashes twice, and the red SD card module's LED flashes twice. I'm not sure what it's flashing for though: opening and closing the text file? opening/writing and closing?
Ideally, I want the LED to flash twice brightly to emulate the coolness factor of these onboard LEDs... but I was just trying to get it to turn on in the first place.
I also tried setting sdState = LOW, rather than to false, but that didn't work either.
Any help would be appreciated. Thank you!
#include <SPI.h>
#include <SD.h>
//Global Definitions
uint32_t timeStamp = 0;
//LED — for photoresistor, this will change
const int ledSD = 2;
bool sdState = false;
// DO NOT USE PIN 10
//SD Card
File myFile; //name of file object
const int cS = 4; //SD card write
  pinMode(ledSD, OUTPUT);
  pinMode(10, OUTPUT); //Required for SD card module, do not use
//SD CARD
  Serial.print("Initializing SD card...");
  // see if the card is present and can be initialized:
  if (!SD.begin(cS)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1);
  Serial.println("card initialized.");
 //Print initial startup
 myFile = SD.open("text.txt", FILE_WRITE);
  if (myFile) {
    myFile.println("");
    myFile.close();
    // debug
    Serial.println("");
//debug
  timeStamp = millis(); // this declaration must be in void loop
//LED
/*  unsigned long ms = millis();
  if ( (ms - preTime) >= 1000) {
    preTime = ms;
  if (sdState == true){
    digitalWrite(ledSD, HIGH);
      digitalWrite(ledSD, LOW);
 // SD CARD WRITE
  if (myFile) {
    sdState = true;
//Time
    myFile.print(timeStamp);
    Serial.print(timeStamp);
  myFile.close();
  sdState = false;
else {
    Serial.println("error opening templog");
  //END SD card write
delay(5000);
Hello
Try this non-real-time solution by using additional delay() functions.
#include <SPI.h>
#include <SD.h>
//SD Card
  //SD CARD
    while (1);
  if (myFile) {
    myFile.println("");
    myFile.close();
    // debug
    Serial.println("");
  //debug
  //LED
      preTime = ms;
  if (sdState == true) {
  // SD CARD WRITE
  if (myFile) {
    sdState = true;
    //Time
    myFile.close();
    sdState = false;
    digitalWrite(ledSD,HIGH);
    delay (1000);
    digitalWrite(ledSD,LOW);
    delay (1000);
    delay (1000);
  else {
  //END SD card write
  delay(5000);
That certainly works, and I'll use it, thank you.
I think my frustration is that I was trying to make it connected to an action, rather than just blinking at the end of the loop.
Quick update, this was working beautifully, thank you again
