Please help...
I get this when trying to upload sketch to Arduino Uno Wifi via serial USB
"avrdude: stk500_recv(): programmer is not responding"
So far troubleshooting...
- uninstalled and reinstalled CH340 Driver several times (I'm on Mac Monterray 12.3.1)
- disconnected modules and retried
- connects OK on Arduino Uno board and uploads no errors
- checked IDE is up-to-date v 2.0.2
- disconnected arduino USB, reconnected and reset and re run upload
- checked serial connection is correct and re run upload
- checked correct board Arduino Uno Wifi and re run upload
- changed sketch to simple LED blink from library, selected Arduino Uno Wifi and re run upload
- tried and tip from the forum to use Arduino Duemilanove ir Diecimila board instead - same error
- also the USB cable is the same one used successfully to connect to the Arduino Uno
I read somewhere about bootloading the CH340 Driver to the two Arduino chips??? No idea how to do this.
Let me know if there are any other recommendations such as get a different board
