Uno Wifi Rev. 2 Unresponsive - Short read, read only 0 out of 64 bytes
When I attempt to upload a sketch (even blink) to my Ardunio Uno Wifi Rev2, I get the following error message
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Greg\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino16/etc/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : xplainedmini_updi
         Overriding Baud Rate          : 115200
avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
         AVR Part                      : ATmega4809
         Chip Erase delay              : 0 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 0
         StabDelay                     : 0
         CmdexeDelay                   : 0
         SyncLoops                     : 0
         ByteDelay                     : 0
         PollIndex                     : 0
         PollValue                     : 0x00
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           prodsig        0     0     0    0 no         61   61      0     0     0 0x00 0x00
           fuses          0     0     0    0 no          9    0      0     0     0 0x00 0x00
           fuse0          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse1          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse2          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse4          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse5          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse6          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse7          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           fuse8          0     0     0    0 no          1    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0     0     0 0x00 0x00
           data           0     0     0    0 no          0    0      0     0     0 0x00 0x00
           usersig        0     0     0    0 no         64   64      0     0     0 0x00 0x00
           flash          0     0     0    0 no      49152  128      0     0     0 0x00 0x00
           eeprom         0     0     0    0 no        256   64      0     0     0 0x00 0x00
         Programmer Type : JTAGICE3_UPDI
         Description     : Atmel AVR XplainedMini in UPDI mode
         ICE hardware version: 0
         ICE firmware version: 1.19 (rel. 57)
         Serial number   : AB8D41668C90C8C9C839
         Vtarget         : 5.00 V
         JTAG clock megaAVR/program: 0 kHz
         JTAG clock megaAVR/debug:   0 kHz
         JTAG clock Xmega: 0 kHz
         PDI clock Xmega : 0 kHz
avrdude: Short read, read only 0 out of 64 bytes
avrdude: jtag3_edbg_recv(): Unexpected response 0x00
avrdude: retrying with external reset applied
avrdude: jtag3_edbg_send(): Unexpected response 0x81, 0x11
avrdude: jtag3_edbg_recv(): Unexpected response 0x80
avrdude: JTAGEN fuse disabled?
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: jtag3_edbg_signoff(): unexpected response 0x81, 0x11
avrdude: jtag3_edbg_signoff(): unexpected response 0x01, 0x00
An error occurred while uploading the sketch
avrdude done.  Thank you.
What I've tried:
  • Multiple computers (other Ardunio work on them)
  • Loopback Test: No response to input.
  • Reset button (Press or press and hold or press hold and pray)
  • When plugged in, it has the steady green "on" light. The TX / RX doesn't flash.
Based upon the logs, it seems to be a memory issue similar to this thread: Trouble reading/writing EEPROM via avrdude - Microcontrollers - Arduino Forum . I do not even come close to understanding the ardunio well enough to sort out if it is a memory / register issue. If someone could point me in the right direction, that would be much appreciated!
Cheers!
I think it's almost certainly completely unrelated to that other issue - the mega2560 is based on the classic AVR architecture, and the Uno Wifi Rev. 2 is based on megaAVR architecture. They use a completely different programming method.
Also, I suggest you edit the topic of the thread to specify that it's an Uno Wifi Rev. 2.
The Uno Wifi (not Rev. 2) uses a different processor (a classic avr) - really the only things they have in common is the name, shape, and the fact that they have on-board WiFi.
Arduino is very bad at choosing names for their products that will not result in confusion (see also, their three recently introduced "Nano" boards (Every, and whatever the other two are), which each use a different processor from both eachother and the "Arduino Nano", and their naming one board the Due, and the other the Duemillanove, so people who don't speak Italian (who would know that Duemillanove means "two thousand nine", the year it was released, and hence very different than Due ("two") would assume that "Due" was an abbreviation for "Duemillanove")
Thanks for the time - added to the subject!
Any ideas on how I could troubleshoot it further?
Did you ever solve this problem? I have the same error.
