Please help to solve this issue error compile EmonLib.h with board UNO WIFI REV2
What issue ?
What code ?
What hardware ?
What circuit ?
Code
#include "EmonLib.h" // Include Emon Library
EnergyMonitor emon1; // Create an instance
emon1.current(A0, 111.1); // Current: input pin, calibration.
double Irms = emon1.calcIrms(1480); // Calculate Irms only
Serial.print(Irms*230.0); // Apparent power
Serial.print(" ");
Serial.println(Irms); // Irms
Error MSG
C:\Users\ctatong\Documents\Arduino\libraries\EmonLib\EmonLib.cpp: In member function 'long int EnergyMonitor::readVcc()':
C:\Users\ctatong\Documents\Arduino\libraries\EmonLib\EmonLib.cpp:258:3: error: 'ADCSRA' was not declared in this scope
ADCSRA |= _BV(ADSC); // Convert
The error is because the EmonLib library is not compatible with the Uno WiFi Rev2. Despite the name, the Uno WiFi Rev2 uses a different microcontroller than the Uno. This microcontroller is fairly new, with significant differences from the traditional AVR microcontrollers, and has never been used by the Arduino world before the release of the Uno WiFi Rev2. For this reason, you will find that some 3rd party libraries are not compatible with the Uno WiFi Rev2. The support will surely improve over time, but for now you can think of yourself as a pioneer in new territory.
Your options are:
- Study the datasheet for the Uno WiFi Rev2's ATmega4809 microcontroller and modify the EmonLib code to work with it.
- Use a board that is already compatible with EmonLib.
