Hello all,
When using the WifiNINA "ScanNetworks" sketch.... The serial monitor is not returning any networks and gives me this message.
" Please upgrade the firmware"
number of available networks:0
Couldn't get a wifi connection
I am using an Arduino Uno Wifi Rev2, i have the following library installed WifiNINA ver. 1.8.0. The current NINA firmware version is "(1.4.1)(Arduino Uno Wifi Rev2)"...
I have been using this for weeks prior with no problem,,, connected to the web as a client, connected to Blynk and Cayenne.... I am afraid the module is fried somehow possibly?? Is there a way to know if the wifi module is ok?
Thanks
EDIT: I thought i should mention,,, Yes, there is a network available, it is the same network i am using now to write this message and connect with you all
my code …
This example prints the board's MAC address, and
scans for available Wifi networks using the NINA module.
Every ten seconds, it scans again. It doesn't actually
connect to any network, so no encryption scheme is specified.
Circuit:
Board with NINA module (Arduino MKR WiFi 1010, MKR VIDOR 4000 and UNO WiFi Rev.2)
created 13 July 2010
by dlf (Metodo2 srl)
modified 21 Junn 2012
by Tom Igoe and Jaymes Dec
#include <SPI.h>
#include <WiFiNINA.h>
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC: ");
printMacAddress(mac);
// scan for existing networks:
Serial.println("Scanning available networks...");
listNetworks();
delay(10000);
void listNetworks() {
// scan for nearby networks:
Serial.println("** Scan Networks **");
int numSsid = WiFi.scanNetworks();
if (numSsid == -1) {
Serial.println("Couldn't get a wifi connection");
while (true);
// print the list of networks seen:
Serial.print("number of available networks:");
Serial.println(numSsid);
// print the network number and name for each network found:
for (int thisNet = 0; thisNet < numSsid; thisNet++) {
Serial.print(thisNet);
Serial.print(") ");
Serial.print(WiFi.SSID(thisNet));
Serial.print("\tSignal: ");
Serial.print(WiFi.RSSI(thisNet));
Serial.print(" dBm");
Serial.print("\tEncryption: ");
printEncryptionType(WiFi.encryptionType(thisNet));
void printEncryptionType(int thisType) {
// read the encryption type and print out the name:
switch (thisType) {
case ENC_TYPE_WEP:
Serial.println("WEP");
case ENC_TYPE_TKIP:
Serial.println("WPA");
case ENC_TYPE_CCMP:
Serial.println("WPA2");
case ENC_TYPE_NONE:
Serial.println("None");
case ENC_TYPE_AUTO:
Serial.println("Auto");
case ENC_TYPE_UNKNOWN:
default:
Serial.println("Unknown");
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
my error message…
Sketch uses 9147 bytes (18%) of program storage space. Maximum is 48640 bytes.
Global variables use 661 bytes (10%) of dynamic memory, leaving 5483 bytes for local variables. Maximum is 6144 bytes.
avrdude: WARNING: invalid value for unused bits in fuse "fuse5", should be set to 1 according to datasheet
This behaviour is deprecated and will result in an error in future version
You probably want to use 0xcd instead of 0xc9 (double check with your datasheet first).
Well,
Thanks alot for the answers everyone! You guys were a real help! LOL! just kidding... people are busy, i get it.
Anyways, had an idea this morning and decided to program and uploading with the Mac instead of windows based PC and all is good... Guess i'll just stay with the Mac...
Who knows what that's all about?? me and computers don't get along too well
Post Closed!
