Uno with DS18B20 Temp Sensor Trying to display Temp on 2x16 LCD
Uno with keyes DS18B20 board temperature sensor trying to display temperature on duinotech 2x16 LCD
Can display temperature on Serial Monitor but not on LCD. Just flashers display on LCD. Up loads OK
My operating system is 8.1. The first 20 lines are libries.
This is my code
#include <LiquidCrystal.h>
#include <BAE910.h>
#include <DS18B20.h>
#include <DS2401.h>
#include <DS2405.h>
#include <DS2408.h>
#include <DS2413.h>
#include <DS2423.h>
#include <DS2431.h>
#include <DS2433.h>
#include <DS2438.h>
#include <DS2450.h>
#include <DS2502.h>
#include <DS2506.h>
#include <DS2890.h>
#include <OneWireHub.h>
#include <OneWireHub_config.h>
#include <OneWireItem.h>
#include <platform.h>
#include <DallasTemperature.h>
LiquidCrystal lcd(2, 3, 4, 9, 10, 11, 12);
//Include library
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
  Serial.begin(9600); //Begin serial communication
  Serial.println("Arduino Digital Temperature // Serial Monitor Version"); //Print a message
  sensors.begin();
   lcd.begin(2, 16);
   lcd.clear();
void loop(void)
  // Send the command to get temperatures
  sensors.requestTemperatures();      // This works
  Serial.print("Temperature is: ");   // This works
  float temp = sensors.getTempCByIndex(0); // This works
  Serial.println(temp); // (This works)Why "byIndex"? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
  lcd.setCursor(0,0);     // This dose not work
  lcd.print("Actual: ");  // This dose not work
  lcd.print(temp);        // This dose not work  Only fashers on LCD seen
  //Update value every 1 sec.
Why do you need all those DS "libries"? You only have ONE sensor.
//Include library
Isn't it stupid to try to use pin 2 for the LCD AND the one wire bus?
