Uno_24 def, how alter for duemilanove?
Hi, I'm trying hard to get LCDs work with my Arduino :D Yet being a NewB, have some trouble in understanding code, but well, this is a good example to learn from I couldn't find by google, what should I do to make the driver compatible with my LCD, when the driver has been made compatible for Uno 2.4 but my board is a duemilanove.
I'd be very happy if someone please give me some idea, from what to start...I hardly understand this code I found in lib, but I understand it is a pin conversion. What should I possibly change for my duemilanove please?
#ifndef _UNO_24_SHIELD_
#define _UNO_24_SHIELD_
// Code provided by Smoke And Wires
// http://www.smokeandwires.co.nz
// This code has been taken from the Adafruit TFT Library and modified
//  by us for use with our TFT Shields / Modules
// For original code / licensing please refer to
// https://github.com/adafruit/TFTLCD-Library
// This header file serves two purposes:
// 1) Isolate non-portable MCU port- and pin-specific identifiers and
//    operations so the library code itself remains somewhat agnostic
//    (PORTs and pin numbers are always referenced through macros).
// 2) GCC doesn't always respect the "inline" keyword, so this is a
//    ham-fisted manner of forcing the issue to minimize function calls.
//    This sometimes makes the library a bit bigger than before, but fast++.
//    However, because they're macros, we need to be SUPER CAREFUL about
//    parameters -- for example, write8(x) may expand to multiple PORT
//    writes that all refer to x, so it needs to be a constant or fixed
//    variable and not something like *ptr++ (which, after macro
//    expansion, may increment the pointer repeatedly and run off into
//    la-la land).  Macros also give us fine-grained control over which
//    operations are inlined on which boards (balancing speed against
//    available program space).
// Smoke And Wires 2.4 Shield pin usage:
// LCD Data Bit :    7    6    5    4    3    2    1    0
// Digital pin #:    7    6    5    4    3    2    9    8
// Uno port/pin :  PD7  PD6  PD5  PD4  PD3  PD2  PB1  PB0
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// Pixel read operations require a minimum 400 nS delay from RD_ACTIVE
// to polling the input pins.  At 16 MHz, one machine cycle is 62.5 nS.
// This code burns 7 cycles (437.5 nS) doing nothing; the RJMPs are
// equivalent to two NOPs each, final NOP burns the 7th cycle, and the
// last line is a radioactive mutant emoticon.
#define DELAY7        \
  asm volatile(       \
    "rjmp .+0" "\n\t" \
    "rjmp .+0" "\n\t" \
    "rjmp .+0" "\n\t" \
    "nop"      "\n"   \
  // // These set the PORT directions as required before the write and read
  // // operations.  Because write operations are much more common than reads,
  // // the data-reading functions in the library code set the PORT(s) to
  // // input before a read, and restore them back to the write state before
  // // returning.  This avoids having to set it for output inside every
  // // drawing method.  The default state has them initialized for writes.
  // #define setWriteDirInline() { DDRD |=  B11010000; DDRB |=  B00101111; }
  // #define setReadDirInline()  { DDRD &= ~B11010000; DDRB &= ~B00101111; }
  #define write8inline(d) {                          \
    PORTD = (PORTD & B00000011) | ((d) & B11111100); \
    PORTB = (PORTB & B11111100) | ((d) & B00000011); \
    WR_STROBE; }
  #define read8inline(result) {                       \
    RD_ACTIVE;                                        \
    DELAY7;                                           \
    result = (PIND & B11111100) | (PINB & B00000011); \
    RD_IDLE; }
  #define setWriteDirInline() { DDRD |=  B11111100; DDRB |=  B00000011; }
  #define setReadDirInline()  { DDRD &= ~B11111100; DDRB &= ~B00000011; }
  // As part of the inline control, macros reference other macros...if any
  // of these are left undefined, an equivalent function version (non-inline)
  // is declared later.  The Uno has a moderate amount of program space, so
  // only write8() is inlined -- that one provides the most performance
  // benefit, but unfortunately also generates the most bloat.  This is
  // why only certain cases are inlined for each board.
  #define write8 write8inline
 // When using the TFT breakout board, control pins are configurable.
 #define RD_ACTIVE  *rdPort &=  rdPinUnset
 #define RD_IDLE    *rdPort |=  rdPinSet
 #define WR_ACTIVE  *wrPort &=  wrPinUnset
 #define WR_IDLE    *wrPort |=  wrPinSet
 #define CD_COMMAND *cdPort &=  cdPinUnset
 #define CD_DATA    *cdPort |=  cdPinSet
 #define CS_ACTIVE  *csPort &=  csPinUnset
 #define CS_IDLE    *csPort |=  csPinSet
// #endif
// #endif
// Data write strobe, ~2 instructions and always inline
#define WR_STROBE { WR_ACTIVE; WR_IDLE; }
// These higher-level operations are usually functionalized,
// except on Mega where's there's gobs and gobs of program space.
// Set value of TFT register: 8-bit address, 8-bit value
#define writeRegister8inline(a, d) { \
  CD_COMMAND; write8(a); CD_DATA; write8(d); }
// Set value of TFT register: 16-bit address, 16-bit value
// See notes at top about macro expansion, hence hi & lo temp vars
#define writeRegister16inline(a, d) { \
  uint8_t hi, lo; \
  hi = (a) >> 8; lo = (a); CD_COMMAND; write8(hi); write8(lo); \
  hi = (d) >> 8; lo = (d); CD_DATA   ; write8(hi); write8(lo); }
// Set value of 2 TFT registers: Two 8-bit addresses (hi & lo), 16-bit value
#define writeRegisterPairInline(aH, aL, d) { \
  uint8_t hi = (d) >> 8, lo = (d); \
  CD_COMMAND; write8(aH); CD_DATA; write8(hi); \
  CD_COMMAND; write8(aL); CD_DATA; write8(lo); }
#endif // _UUNO_24_SHIELD_
What the heck is a Uno 2.4?
I think UNO_24 is a 2.4inch LCD display. The code should not need to change to run on a Duemilanove. However, if you only have an ATmega168 in your duemilanove, you may find that the code is too large to fit. Graphics displays tend to eat up a lot of memory very quickly, with things like font tables.
