Unojoy:Joystick with more analog input
I'm working on a custom controller for Microsoft Flight Simulator, specifically designed to control 4 independent throttles, flaps, and spoilers. These controls require multiple analog inputs to achieve smooth, precise adjustments—more than the standard setup I'm currently working with. I've been using an Arduino Uno with the UnoJoy library to emulate a USB game controller, but I'm hitting limitations with analog inputs. My goal is to support at least 6+ analog axes (to cover the 4 throttles plus flaps and spoilers), but the current setup only recognizes 4 analog axes. I've tried modifying the `dataForController_t` struct to add fields for `slider1` and `slider2`, updated the HID report descriptor to include 6 axes (adding `Usage (Slider)` and `Usage (Dial)` with `Report Count = 6`), and adjusted the serial reading logic to fetch additional bytes for the new axes. However, the extra analog inputs still aren't detected by the system. Given that I may need even more analog inputs for future expansions, I'm also considering switching to an Arduino Mega (which has more analog pins) to support additional controls. But I'm unsure how to adapt the UnoJoy library or HID configuration to work with the Mega for more analog axes. Has anyone successfully expanded analog input count beyond 4 with UnoJoy, either on the Uno or Mega? Guidance on struct definitions, HID descriptor tweaks, or firmware adjustments for supporting more analog axes (especially for flight simulator controls) would be incredibly helpful!
Welcome to the forum
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
I would also advise you to edit your post to break it into multiple paragraphs to make it easier to read
as @UKHeliBob suggested rewrite the paragraph and also post your annotated schematic showing exactly how you have wired it. You will also need to post your code.
You are correct the system does not detect them. Your software has to access them via analogRead.
I have no problem using all analog inputs on the UNO and with the Nano there are two more analog inputs. It is all controlled via your code.
