A generic joystick class is not difficult to create. This one is patterned on the Mouse class defined in Mouse.h/Mouse.cpp. Note the Mouse class only depends on the HID class and does not contain board specific code. Each board defines its own board dependent HID class. The Mouse class works on Uno R4 WiFi so this board has a working HID class.
The following joystick class works on Uno R4 WiFi when plugged into a Windows 11 PC. The joystick has 32 buttons, 11 axes, and 2 8-way direction pads. The limits match the limits of the Windows generic joystick device driver. The class depends only on HID.h and does not contain board specific code so it may work on other boards.
JoystickWin.h
JoystickWin.h
#ifndef JOYSTICKWIN_H_
#define JOYSTICKWIN_H_
#include "HID.h"
#if !defined(_USING_HID)
#warning "Using legacy HID core (non pluggable)"
#else
#define AXIS_MIN (0)
#define AXIS_MID (AXIS_MAX / 2)
#define AXIS_MAX (0xFFFFUL)
#define BUTTONS_MAX (32)
// JoystickWin
// This overlays the data format specified by the HID report descriptor in
// JoystickWin.cpp
typedef struct __attribute__((__packed__)) {
uint32_t buttons;
uint8_t hat1:4;
uint8_t hat2:4;
uint16_t x;
uint16_t y;
uint16_t z;
uint16_t rx;
uint16_t ry;
uint16_t rz;
uint16_t rudder;
uint16_t throttle;
uint16_t accelerator;
uint16_t brake;
uint16_t steering;
} JoystickWin_Report_t;
class JoystickWin_ {
private:
JoystickWin_Report_t _hid_report;
public:
JoystickWin_(void);
void begin(void);
void end(void);
void press(int b);
void release(int b);
void releaseAll();
bool isPressed(int b);
void hat1(int d);
void hat2(int d);
void x(uint16_t a) { _hid_report.x = a; }
void y(uint16_t a) { _hid_report.y = a; }
void z(uint16_t a) { _hid_report.z = a; }
void rx(uint16_t a) { _hid_report.rx = a; }
void ry(uint16_t a) { _hid_report.ry = a; }
void rz(uint16_t a) { _hid_report.rz = a; }
void rudder(uint16_t a) { _hid_report.rudder = a; }
void throttle(uint16_t a) { _hid_report.throttle = a; }
void accelerator(uint16_t a) { _hid_report.accelerator = a; }
void brake(uint16_t a) { _hid_report.brake = a; }
void steering(uint16_t a) { _hid_report.steering = a; }
void sendReport();
extern JoystickWin_ JoystickWin;
#endif
#endif // JOYSTICKWIN_H_
JoystickWin.cpp
JoystickWin.cpp
#include "JoystickWin.h"
#if defined(_USING_HID)
static const uint8_t _hidReportDescriptor[] PROGMEM = {
0x05, 0x01, // Usage Page (Generic Desktop Ctrls)
0x09, 0x04, // Usage (Joystick)
0xA1, 0x01, // Collection (Application)
0x85, 0x04, // Report ID (4)
0x05, 0x09, // Usage Page (Button)
0x19, 0x01, // Usage Minimum (0x01)
0x29, 0x20, // Usage Maximum (0x20)
0x15, 0x00, // Logical Minimum (0)
0x25, 0x01, // Logical Maximum (1)
0x75, 0x01, // Report Size (1)
0x95, 0x20, // Report Count (32)
0x55, 0x00, // Unit Exponent (0)
0x65, 0x00, // Unit (None)
0x81, 0x02, // Input (Data,Var,Abs,No Wrap,Linear,Preferred State,No Null Position)
0x09, 0x39, // Usage (Hat switch)
0x25, 0x07, // Logical Maximum (7)
0x35, 0x00, // Physical Minimum (0)
0x46, 0x3B, 0x01, // Physical Maximum (315)
0x65, 0x14, // Unit (System: English Rotation, Length: Centimeter)
0x75, 0x04, // Report Size (4)
0x95, 0x01, // Report Count (1)
0x09, 0x01, // Usage (Pointer)
0x27, 0xFF, 0xFF, 0x00, 0x00, // Logical Maximum (65534)
0x75, 0x10, // Report Size (16)
0x95, 0x06, // Report Count (6)
0xA1, 0x00, // Collection (Physical)
0x09, 0x30, // Usage (X)
0x09, 0x31, // Usage (Y)
0x09, 0x32, // Usage (Z)
0x09, 0x33, // Usage (Rx)
0x09, 0x34, // Usage (Ry)
0x09, 0x35, // Usage (Rz)
0xC0, // End Collection
0x05, 0x02, // Usage Page (Sim Ctrls)
0x95, 0x05, // Report Count (5)
0x09, 0xBA, // Usage (Rudder)
0x09, 0xBB, // Usage (Throttle)
0x09, 0xC4, // Usage (Accelerator)
0x09, 0xC5, // Usage (Brake)
0x09, 0xC8, // Usage (Steering)
// JoystickWin
JoystickWin_::JoystickWin_(void) {
static HIDSubDescriptor node(_hidReportDescriptor, sizeof(_hidReportDescriptor));
HID().AppendDescriptor(&node);
void JoystickWin_::begin(void) {
_hid_report.buttons = 0;
_hid_report.hat1 = 8;
_hid_report.hat2 = 8;
_hid_report.x = AXIS_MID;
_hid_report.y = AXIS_MID;
_hid_report.z = AXIS_MID;
_hid_report.rx = AXIS_MID;
_hid_report.ry = AXIS_MID;
_hid_report.rz = AXIS_MID;
_hid_report.rudder = AXIS_MID;
_hid_report.throttle = AXIS_MID;
_hid_report.accelerator = AXIS_MID;
_hid_report.brake = AXIS_MID;
_hid_report.steering = AXIS_MID;
sendReport();
void JoystickWin_::end(void) {
begin();
void JoystickWin_::sendReport() {
HID().SendReport(4, (void *)&_hid_report, sizeof(_hid_report));
void JoystickWin_::press(int b) {
constrain(b, 0, BUTTONS_MAX - 1);
_hid_report.buttons |= (uint32_t)(1UL << b);
void JoystickWin_::release(int b) {
_hid_report.buttons &= ~(uint32_t)(1UL << b);
void JoystickWin_::releaseAll() {
bool JoystickWin_::isPressed(int b) {
return ((_hid_report.buttons & (uint32_t)(1UL << b)) != 0) ? true : false;
void JoystickWin_::hat1(int d) {
constrain(d, 0, 15);
_hid_report.hat1 = d;
void JoystickWin_::hat2(int d) {
_hid_report.hat2 = d;
#endif
