Unos 0.0.1 - A Simple OS for the Arduino
Firmata was designed to interface with programs on the computer. My program is not designed to do that at all. As a matter of fact, in a future release I plan to interface with a touchscreen shield instead of serial.
rockwallaby:
I stayed in 'lurk' mode where I was waiting for Unos release 0.0.3 (in a new thread of course) which would hopefully have 'ls' and 'df' command. :stuck_out_tongue:
I find dmesg very useful.
PLEASE don't encourage extra Threads
...R
I improved on use of RAM. Attached is the code. The commands are the same as in Unos 0.0.2.
Unos_0_0_3.ino (4.5 KB)
char *command[NUMBER_OF_COMMANDS] = {"shutdown", "restart", "print", "pinwrite"}; // << enter your commands here<< These are # 0,1,2,3 & 4
int Pin[12] = {2,3,4,5,6,7,8,9,10,11,12,13};
Hmmm.
I'm looking forward to "lsusb".
As we say in spanish: "este niño no tiene abuela" (The boy hasn't any grandmother -he has to give applauses to himself)
:wink:
I hope my sense of dryness did not elude thee. :-[
The Arduino Uno doesn't have a host USB port, so there is little point in having such a command.
rockwallaby:
Robin2 wrote: I hope my sense of dryness did not elude thee. :-[
It did not elude me, but I was concerned that others might take you literally - e.g. ...
goodinventor:
...R
Don't worry. I know better than that.
rockwallaby, the 'ls' command requires a storage device. What kind of storage device should I support?
goodinventor:
EEPROM
I added a few data management procedures. The program, Unos 0.0.4, is attached. Any ideas or problems with the program should be reported here.
Unos_0_0_4.ino (6.83 KB)
Why?
You haven't taken any notice so far.
I have. I implemented what I could, but there are extreme memory constraints. I tested it on my Arduino Uno and it does fine.
Have another look at reply #23
What do you mean by "Hmmm..."? What is the problem with the code? Anyways, attached is the guide to the system.
Unos 0.0.4 Guide.txt (2.47 KB)
You say you're trying to save precious RAM, yet the pin array is twice as big as it should be (and it shouldn't even be in RAM), and you waste more RAM storing fixed command strings in it.
But I want to be able to control all the outputs. How should I initialize my arrays so that they use as little RAM as possible?
By not putting them in RAM at all.
I can't see the point - you're not likely to want to change the commands or the pin numbers, so why are they in RAM?
Maybe instead of even using an array for the pins, I can just set them all outright. That will save a lot of RAM.
