Unqualified-id before '.' token
Hi , i try to include my own header to the main code. However it always show unqualified-id token'.' at temperature.begin() and temperature.calculate_temperature(). Could you guy give me advice on my issue/
main code
#include <Arduino.h>
#include "temperature.h"
  Serial.println("Hello, ESP32!");
  temperature.begin();
  temperature.calculate_temperature();
  delay(10); // this speeds up the simulation
temperature.h :
#ifndef temperature_h
#define temperature_h
class temperature {
  public:
  void begin();
  void calculate_temperature();
#endif
temperature.cpp :
#define Temp_sense 21
void temperature::begin(){
 pinMode(Temp_sense,INPUT);
void temperature::calculate_temperature(void){
   const float BETA = 3950;
   int analogValue = analogRead(Temp_sense);
   float celsius = 1 / (log(1 / (1023. / analogValue - 1)) / BETA + 1.0 / 298.15) - 273.15;
   Serial.println(celsius);
You have a class named temperature but no object of that class
As @UKHeliBob said... you need to first define an object of type "temperature"... and then you can use the methods on that object.
In the example below (I've just put all your code in one program), first we define an object... and then you can use it.
// ---------- Class declaration ---------------
class temperature
  public:
  void begin();
// ----------- Class definition -------------
// --------- Main program -----------------
temperature Temperature;      // <<<<<<< You need to define a "temperature" object.
  Temperature.begin();        // Note upper case T (the object you defined above)
  Temperature.calculate_temperature();     // Note upper case T (the object you defined above)
