Salutations!
First let me start by saying I am fairly new to coding on arduino - I originally took filler programming class back in college and they only taught us cobolt... which from what I understand is a next to useless language today.
To preface this project, it is supposed to control neopixel leds to activate on a RFID tag. When activated it should spin LED's counter clockwise green with increasing speed before lighting the whole thing solid for a few seconds, then turn off and go to a slow tracing spin of white LED's until reactivated. If this sounds familiar its because I'm trying to mimic the activity of a Disney World magic band reader since my sister is a Disneyholic and figured it'd be awesome to make this for her for Christmas.
I originally got most of the code from Dominick Civitano on github. I've been trying to modify it to make it more appropriate for what I am looking for, including adding more LED control and the custom RFID tags (which may need to be looked at too since I'm trying to use several). The coding I added to have the white LED trace is toward the bottom before the loop void() as this is where I suspected to put it. However I am getting a unqualified-id before '{' token error despite seeing proper open and close amounts.
The error is located in this statement:
pixels.setPixelColor(41, pixels.Color(0,0,0));
pixels.show();
{//idle white LED circling
#define IDLE_TICK_MSEC 500 // time between LED movements
static uint32_t tm = millis();
static int led_index = 0;
if (millis() - tm >= IDLE_TICK_MSEC)
{ tm = millis();
// bump the LED
led_index = (led_index+1) % 42;
// render the pixels
for (int i=0; i < 42; i++)
pixels.setPixelColor(i, i == led_index ? pixels.Color(25, 25, 25) : pixels.Color(0, 0, 0));
pixels.show();
Below is the full code in case you'd need the entirety to look over:
* INITIAL AUTHOR: Dominick Civitano
* See: https://github.com/miguelbalboa/rfid/tree/master/examples/rfid_write_personal_data
* Uses MIFARE RFID card using RFID-RC522 reader
* Uses MFRC522 - Library
* MFRC522 Arduino Arduino Arduino Arduino Arduino
* Reader/PCD Uno/101 Mega Nano v3 Leonardo/Micro Pro Micro
* Signal Pin Pin Pin Pin Pin Pin
* RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
* SPI SS SDA(SS) 10 53 D10 10 10
* SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
* SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
* SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
#ifdef __AVR__
#include <avr/power.h>
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
// Use pins 2 and 3 to communicate with DFPlayer Mini
static const uint8_t PIN_MP3_TX = 11; // Connects to module's RX
static const uint8_t PIN_MP3_RX = 10; // Connects to module's TX
SoftwareSerial softwareSerial(PIN_MP3_RX, PIN_MP3_TX);
// Create the Player object
DFRobotDFPlayerMini player;
#endif
#include <SPI.h>
#include <MFRC522.h>
#define PIN 6
#define NUMPIXELS 42
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
#define RST_PIN 5 // Configurable, see typical pin layout above
#define SS_PIN 53 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
const int relay = 7; //relay control pin
pinMode(relay,OUTPUT);
Serial.begin(9600); // Initialize serial communications with the PC
softwareSerial.begin(9600);
if (player.begin(softwareSerial)) {
Serial.println("speaker on");
// Set volume to maximum (0 to 30).
player.volume(20);
// Play the first MP3 file on the SD card
digitalWrite(relay, LOW);
SPI.begin();
pixels.begin();
pixels.show(); // Initialize all pixels to 'off'
// Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println(F("Read personal data on a MIFARE PICC:")); //shows in serial that it is ready to read
void disney(){
pixels.setPixelColor(41, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(40, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(40, pixels.Color(0,0,0));
pixels.setPixelColor(39, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(39, pixels.Color(0,0,0));
pixels.setPixelColor(38, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(38, pixels.Color(0,0,0));
pixels.setPixelColor(37, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(37, pixels.Color(0,0,0));
pixels.setPixelColor(36, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(36, pixels.Color(0,0,0));
pixels.setPixelColor(35, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(35, pixels.Color(0,0,0));
pixels.setPixelColor(34, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(34, pixels.Color(0,0,0));
pixels.setPixelColor(33, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(33, pixels.Color(0,0,0));
pixels.setPixelColor(32, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(32, pixels.Color(0,0,0));
pixels.setPixelColor(31, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(31, pixels.Color(0,0,0));
pixels.setPixelColor(30, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(30, pixels.Color(0,0,0));
pixels.setPixelColor(29, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(29, pixels.Color(0,0,0));
pixels.setPixelColor(28, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(28, pixels.Color(0,0,0));
pixels.setPixelColor(27, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(27, pixels.Color(0,0,0));
pixels.setPixelColor(26, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(26, pixels.Color(0,0,0));
pixels.setPixelColor(25, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(25, pixels.Color(0,0,0));
pixels.setPixelColor(24, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(24, pixels.Color(0,0,0));
pixels.setPixelColor(23, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(23, pixels.Color(0,0,0));
pixels.setPixelColor(22, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(22, pixels.Color(0,0,0));
pixels.setPixelColor(21, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(21, pixels.Color(0,0,0));
pixels.setPixelColor(20, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(20, pixels.Color(0,0,0));
pixels.setPixelColor(19, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(19, pixels.Color(0,0,0));
pixels.setPixelColor(18, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(18, pixels.Color(0,0,0));
pixels.setPixelColor(17, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(17, pixels.Color(0,0,0));
pixels.setPixelColor(16, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(16, pixels.Color(0,0,0));
pixels.setPixelColor(15, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(15, pixels.Color(0,0,0));
pixels.setPixelColor(14, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(14, pixels.Color(0,0,0));
pixels.setPixelColor(13, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(13, pixels.Color(0,0,0));
pixels.setPixelColor(12, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(12, pixels.Color(0,0,0));
pixels.setPixelColor(11, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(11, pixels.Color(0,0,0));
pixels.setPixelColor(10, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(10, pixels.Color(0,0,0));
pixels.setPixelColor(9, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(9, pixels.Color(0,0,0));
pixels.setPixelColor(8, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(8, pixels.Color(0,0,0));
pixels.setPixelColor(7, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(7, pixels.Color(0,0,0));
pixels.setPixelColor(6, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(6, pixels.Color(0,0,0));
pixels.setPixelColor(5, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(5, pixels.Color(0,0,0));
pixels.setPixelColor(4, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(4, pixels.Color(0,0,0));
pixels.setPixelColor(3, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(3, pixels.Color(0,0,0));
pixels.setPixelColor(2, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(2, pixels.Color(0,0,0));
pixels.setPixelColor(1, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(1, pixels.Color(0,0,0));
pixels.setPixelColor(0, pixels.Color(0,25,0));
pixels.show();
delay(50);
pixels.setPixelColor(0, pixels.Color(0,0,0));
pixels.show();
delay(50);
void disneyaccess()
// player.play(1);
pixels.show();
if(digitalRead(relay) == HIGH)
digitalWrite(relay,LOW);
Serial.println("Relay off");
digitalWrite(relay,HIGH);
Serial.println("Relay on");
void disneyoff()
pixels.show();
{ tm = millis();
// bump the LED
pixels.show();
// Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
//some variables we need
byte block;
byte len;
MFRC522::StatusCode status;
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
Serial.println(F("**Card Detected:**"));
Serial.print("UID tag :");
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.print("Message : ");
content.toUpperCase();
if (content.substring(1) == "04 4e b4 aa 15 75 80","04 4a a7 32 16 75 80","04 6a 78 52 16 75 80","04 21 60 52 60 74 80") //change here the UID of the card/cards that you want to give access
Serial.println("Authorized access");
disney();
disney();
disney();
disneyaccess();
player.play(1);
delay(2000);
disneyoff();
delay(2500);
else {
Serial.println(" Access denied");
mfrc522.PICC_DumpDetailsToSerial(&(mfrc522.uid)); //dump some details about the card
//mfrc522.PICC_DumpToSerial(&(mfrc522.uid)); //uncomment this to see all blocks in hex
Serial.print(F("Name: "));
byte buffer1[18];
block = 4;
len = 18;
//------------------------------------------- GET FIRST NAME
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 4, &key, &(mfrc522.uid)); //line 834 of MFRC522.cpp file
if (status != MFRC522::STATUS_OK) {
Serial.print(F("Authentication failed: "));
Serial.println(mfrc522.GetStatusCodeName(status));
return;
status = mfrc522.MIFARE_Read(block, buffer1, &len);
Serial.print(F("Reading failed: "));
return;
//PRINT FIRST NAME
for (uint8_t i = 0; i < 16; i++)
if (buffer1[i] != 32)
Serial.write(buffer1[i]);
Serial.print(" ");
//---------------------------------------- GET LAST NAME
byte buffer2[18];
block = 1;
status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, 1, &key, &(mfrc522.uid)); //line 834
return;
status = mfrc522.MIFARE_Read(block, buffer2, &len);
return;
//PRINT LAST NAME
for (uint8_t i = 0; i < 16; i++) {
Serial.write(buffer2[i] );
Serial.println(F("\n**End Reading**\n"));
delay(1000); //change value if you want to read cards faster
mfrc522.PICC_HaltA();
mfrc522.PCD_StopCrypto1();
