"unqualifiied-id expected before"if" error
every time i try to compile my project it keeps giving me these errors. its my first time making something without a guide. Here’s the code:
const int pingPin=2;
const int ledpin=3;
const int beeppin=4;
const int slowflash=1000;
const int medflash=500;
const int fastflash=250;
const int superfastflash=100;
void setup(){
int nodetect=100;
int fardetect=80;
int meddetect=60;
int closedetect=40;
int veryclosedetect=20;
pinMode(ledpin,OUTPUT);
pinMode(beeppin,OUTPUT);
void loop(){
long duration, inches, cm;//detremine length
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
digitalWrite(pingPin, LOW);pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
delay(100);
long microsecondsToInches(long microseconds)
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
return microseconds / 29 / 2;
const int nodetect=100;
const int fardetect=80;
const int meddetect=60;
const int closedetect=40;
const int veryclosedetect=20;
if (microsecondsToInches >= nodetect){
digitalWrite(ledpin,HIGH);
delay(slowflash);
digitalWrite(ledpin,LOW)
delay(slowflash);
if (microsecondsToInches >= fardetect && (microsecondsToInches <= nodetect))
delay(medflash);
digitalWrite(ledpin,LOW);
delay(medflash);
if (microsecondsToInches >= meddetect && (microsecondsToInches <= fardetect))
digitalWrite(ledpin, HIGH);
delay (fastflash);
delay(fastflash);
if (microsecondsToInches >= closedetect && (microsecondsToInches <= meddetect))
delay(superfastflash);
if (microsecondsToInches >= veryclosedetect && (microsecondsToInches <= closedetect))
digitalWrite(beeppin, HIGH);
delay (superfastflash);
digitalWrite(beeppin,LOW);
   delay(slowflash);
   delay(slowflash);
   delay(medflash);
   delay(medflash);
   delay (fastflash);
   delay(fastflash);
All that stuff needs to be inside a function.
You’ve declared a number of variables inside setup that you never use.
Please use CODE TAGS when posting code, do not use “format for forum” or whatever it is called
