Unreadable Characters in Serial Monitor - XBee Pro issues
Hello.
I’m having issues with XBee Pro S2B modem. One is connected to my PC with a Xbee USB dongle(http://www.rhydolabz.com/index.php?main_page=product_info&products_id=1093) and other connected to Arduino UNO with a Breakout board from Robosapiens. This would be the pin connection info.
XBee Pin 2 => Arduino RX
XBee Pin 3 => Arduino TX
The problem is When i type some characters in X-CTU terminal, i receive data in Arduino Serial Monitor in a weird way(Unreadable Characters)…
When i type some characters, it gets divided my dots automatically and when it gets received in Serial monitor it appears Weird.
PC Xbee = ZIGBEE COORDINATOR AT
Arduino XBee = ZIGBEE ROUTER AT
Serial Baud: 9600
This would be the program to read data from PC
// set the data rate for the SoftwareSerial port
Serial.println(“Hello, world?”);
void loop() // run over and over again
if (Serial.available())
Serial.print((char)Serial.read());
Instead of:
Try:
    char in = Serial.read();
    Serial.print(in);
I’ve checked it, but i get the same problem again… I’ve attached the Screenshot…
