Hello! I am using a ping sensor with an arduino uno board. I bought a kit with ping sensor, servo motor and mount. I am sweeping the servo back and forth ~180 deg. and pinging between moves. I have tried two approaches with differing unreliable output. I describe the unreliable output below. The sketch is very small so I will post the whole thing.
// sketch to move servo and ping a distance// two different ways with different results
#include <ServoTimer2.h>
const int pin6 = 6; //attaches servo to pin 6
const int ping1 = 7; //attaches ping sensor to pin 7
long duration1; // used in ping function
long cm1; // distance value
int num1; // direction value out of servo1
int dir; // var for switch to sweep servo back & forth in move
ServoTimer2 servo1; // declare objects for servos
Serial.begin(9600); // initialize serial communication:
servo1.attach(pin6); // attach pins to the servos
dir = 0; // set initial direction of switch statement
int num1 = 0; // initialize servo movement var
duration1 = 0; // initialize ping var
long ping() // function to drive the ping sensors
pinMode(ping1, OUTPUT);
digitalWrite(ping1, LOW);
delayMicroseconds(4); //was 2
digitalWrite(ping1, HIGH);
delayMicroseconds(10); //was 5
pinMode(ping1, INPUT);
duration1 = pulseIn(ping1, HIGH);
cm1 = microsecondsToCentimeters(duration1);
return cm1;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
} // end of ping
long out()
Serial.print(cm1);
Serial.println(" cm1 ");
int move_another(){ // this gets good distance values from i = 45 down to i = 12 then bad distance
int count = 0;
int i;
for ( i = 1; i != 60; i++){ // servo starts in the middle so for the first loop it hangs from i = 30 until i = 60
if ( i <= 30 ){ // then it sweeps back and forth ~180 deg correctly
num1 = (servo1.read() - 50);
delay(5);
servo1.write(num1);
delay(400);
ping();
out();
count = count + 1;
Serial.print(i);
Serial.println(" i < 15 ");
else{
num1 = (servo1.read() + 50);
delay(5);
servo1.write(num1);
delay(400);
ping();
out();
count = count + 1;
Serial.print(i);
Serial.println(" i > 15 ");
int move(){ // This one gets 29 good distances then 29 bad ones ( always 15 cm)
switch (dir) {
case 0:
ping();
out();
delay(5);
servo1.write(num1);
delay(250);
if (num1 >= 2250){
dir = 1;
case 1:
ping();
out();
delay(5);
servo1.write(num1);
delay(250);
if (num1 <= 800){
dir = 0;
move();
// move_another();
/code]
The servo moves as expected, back and forth for ~180 deg. The ping sensor works when the servo is off.
the function move_another gets good distance values from i = 45 down to i = 12 then bad distance
Now a good distance is the maximum range- 350 cm and the bad distance is 15 cm. Oddly enough, if I hold
my hand in front of the bad reading, it gives me a good reading under 15 cm.
The function move gets 29 good distances then 29 bad ones ( always 15 cm)
It measures good values, i.e 350 cm, which I can influence with my hand to give different accurate values. The bad values start
in the middle of a sweep, i.e. num1 < 1550 go down to 750 and back up to 1650 then get good again.
I wrote another function which has good and bad readings and a few dodgy reading, i.e. 120 cm when it should be 350.
I am trying to keep the sketch as simple as possible in order to understand why ping works sometimes and not others.
I thought perhaps the servo motor gives an interference sound and I tested another servo motor with the same result.
I also tested another ping sensor with the same results.
Thanks for having a look. Any suggestions are welcome!
Regards,
Cappy
