//This is an islamic prayer player based on Arduino Mega
//1. Calculate prayer times according to time-zone & location
//2. Activate amplifire
//3. play call for prayer at appropiate time
//4. shut-off amplifire
#include <time.h>
#include "Wire.h"
#include <EEPROM.h>
#include <LiquidCrystalTr_I2C.h>
#include <math.h>
#include <string.h>
using namespace std;
#include "RTClib.h"
LiquidCrystal_I2C lcd(0x27,20,4);
#define DS1307_I2C_ADDRESS 0x68 // This is the I2C address
//#include <DS3232RTC.sh>
#include "DFRobotDFPlayerMini.h"
//button vars
byte lockTR[] = {B00100,B01010,B01010,B11111,B10001,B10101,B10001,B11111}; //lock sign
byte sTR[] = {B00000,B01110,B10000,B01110,B00001,B01110,B00000,B00100};
const int commonPin = 2;
const int buttonPins[] = {4,6,3,5};
const int amfipin = 7;
const int role1pin = 8; //minare lamps
const int role2pin = 9; //internal lamps
const int LCDPin = 10;
const int beeppin = 11;
unsigned long lastFire = 0;
int activekey = 0;
boolean bitti, bitti1, ezantrap;
int newhour=0;
int newminute=0;
int hareket = 0;
bool guvence=false;
int sayacim=0;
float tempo;
RTC_DS3231 rtc;
boolean tick = false;
boolean manual = false;
boolean ekran = true;
boolean interlace = true;
unsigned long previousMillis = 0; // update time
unsigned long previousMillis1 = 0; // conversion
unsigned long previousMillis3 = 0; // ezan
unsigned long pselamillis = 0; // for SELA
unsigned long pezanmillis = 0; // for EZAN
unsigned long previousswap = 0; // mainb loop screen swap
unsigned long interval = 10000;// 10 seconds
unsigned long interval1 = 21600000; //conversion 6 hrs
unsigned long interval2 = 0;//ezan delay 346 seconds
unsigned long selainterval = 296000;
unsigned long intervalswap = 7000;//screen flip
//unsigned long currentMillis3;
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
int newhours, newminutes;
//old ezan vars.
byte sabahhour,sabahminute,fajrhour,fajrminute,guneshour, gunesminute, oglehour,ogleminute,ikindihour,ikindiminute,aksamhour,aksamminute,yatsihour,yatsiminute;
byte sabahezanhour, sabahezanminute,oglehourSela,ogleminuteSela,timezone;
int il = 0;
byte selaokunsun; // Cuma günü sela okunsun
byte ilkodu, persembeselaokunsun,cumavakitsabitle,cumavakitzamansaat,cumavakitzamandakika,ezantercihi,amfigecikme,sabahezangecikme,ezansuresi,cumaseladakika,persembeseladakika,persembeselahour,persembeselaminute;
byte gunestemkinsaat,gunestemkindakika,sabahtemkinsaat,sabahtemkindakika,ogletemkinsaat,ogletemkindakika,ikinditemkinsaat,ikinditemkindakika,aksamtemkinsaat,aksamtemkindakika,yatsitemkinsaat,yatsitemkindakika,ramazanayi;
byte role1startsaat,role1startdakika,role1stopsaat,role1stopdakika,role2startsaat,role2startdakika,role2stopsaat,role2stopdakika;
byte role1=0, role2=0, role3=0,lcdgecis=7;
byte parolavarmi=0;byte parolanedir=0;
byte sabahdiff, sabahmajmo, gunesdiff, gunesmajmo, oglediff, oglemajmo, ikindidiff, ikindimajmo, aksamdiff, aksammajmo, yatsidiff, yatsimajmo;
int calculatedsabah = 0, calculatedgunes=0,calculatedogle=0,calculatedikindi=0,calculatedaksam=0,calculatedyatsi=0;
// new ezan vars.
double dhuhr_minutes;
const int NUM_ITERATIONS = 1; // number of iterations needed to compute times
double julian_date;
double latitude;
double longitude;
double Time_Zone = 3;
char ch;
static const char* TimeName[] = {"Fajr","Sunrise","Dhuhr","Asr","Sunset","Maghrib","Isha"};
enum JuristicMethod {Shafi, Hanafi};
enum TimeID{Fajr, Sunrise, Dhuhr, Asr, Sunset, Maghrib, Isha, TimesCount};
enum CalculationMethod{
MWL, // Muslim World League (MWL)
Karachi, // University of Islamic Sciences, Karachi
ISNA, // Islamic Society of North America (ISNA)
Makkah, // Umm al-Qura, Makkah
Egypt, // Egyptian General Authority of Survey
Jafari, // Jafari
Tehran, // Tehran
CalculationMethodsCount
enum AdjustingMethod{ // Adjusting Methods for Higher Latitudes
None, // No adjustment
MidNight, // middle of night
OneSeventh, // 1/7th of night
AngleBased, // angle/60th of night
struct MethodConfig{
double fajr_angle;
bool maghrib_is_minutes;
double maghrib_value; // angle or minutes
bool isha_is_minutes;
double isha_value; // angle or minutes
MethodConfig(){
fajr_angle = 18.0;
maghrib_is_minutes = true;
maghrib_value = 0.0; // angle or minutes
isha_is_minutes = false;
isha_value = 18.0; // angle or minutes
MethodConfig(double fajr_angle,
bool maghrib_is_minutes,
double maghrib_value,
bool isha_is_minutes,
double isha_value)
: fajr_angle(fajr_angle)
, maghrib_is_minutes(maghrib_is_minutes)
, maghrib_value(maghrib_value)
, isha_is_minutes(isha_is_minutes)
, isha_value(isha_value)
MethodConfig method_params[CalculationMethodsCount];
unsigned int calc_method ;
unsigned int asr_juristic;
AdjustingMethod adjust_high_lats;
String two_digits_format(int num);
static String int_to_string(int num);
static double fix_hour(double a);
static void get_float_time_parts(double time, int& hours, int& minutes);
String float_time_to_time24(double Time);
String float_time_to_time12(double Time, bool no_suffix = false);
double deg2rad(double d);
double rad2deg(double r);
static double dsin(double d);
static double dcos(double d);
static double dtan(double d);
static double darcsin(double x);
static double darccos(double x);
static double darctan(double x);
static double darctan2(double y, double x);
static double darccot(double x);
static double fix_angle(double a);
static double time_diff(double time1, double time2);
void sun_position(double jd, double &D, double &Eq_t);
double equation_of_time(double jd);
double sun_declination(double jd);
double compute_mid_day(double _t);
double compute_time(double g, double t);
void day_portion(double times[]);
double compute_asr(int Step, double t);
void compute_times(double times[]);
double night_portion(double angle);
void adjust_high_lat_times(double times[]);
void adjust_times(double times[]);
void compute_day_times(double times[]);
double get_julian_date(int Year, int Month, int Day);
void get_prayer_times(int Year, int Month, int Day, double _latitude, double _longitude, double _timezo, double times[]);
void get_prayer_times(time_t date, double latitude, double longitude, double Tzone, double times[]);
int fdvolume=20, fdeq=3;
byte ezanfile;
byte imam = 0;
String hadise ="";
int zero = 0;
int hours, minutes;
int kalansaat; //byte
int kalandakika; //byte
double fajr, gunes, ogle, ikindi, aksam, yatsi;
char weynstring[54]; //global string
//mp3
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
// end of mp3
byte decToBcd(byte val)
return ( (val / 10 * 16) + (val % 10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val / 16 * 10) + (val % 16) );
// Gets the date and time from the ds1307 and prints result
void getDateDs1307()
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.write(zero);
Wire.endTransmission();
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
second = bcdToDec(Wire.read() & 0x7f);
minute = bcdToDec(Wire.read());
hour = bcdToDec(Wire.read() & 0x3f);
dayOfWeek = bcdToDec(Wire.read());
dayOfMonth = bcdToDec(Wire.read());
month = bcdToDec(Wire.read());
year = bcdToDec(Wire.read());
void setDateDs1307() //set date (removed)
void printTime()
char s[12];
lcd.setCursor(6, 0);
lcd.print(" ");
lcd.print(char(dayOfMonth / 10 + 0x30));
lcd.print(char(dayOfMonth % 10 + 0x30));
lcd.print("/");
lcd.print(char(month / 10 + 0x30));
lcd.print(char(month % 10 + 0x30));
lcd.print("/");
lcd.print(char(year / 10 + 0x30));
lcd.print(char(year % 10 + 0x30));
lcd.setCursor(15, 0);
lcd.print(" ");
lcd.print( char( hour / 10 + 0x30) );
lcd.print( char( hour % 10 + 0x30) );
lcd.print(":");
lcd.print( char(minute / 10 + 0x30));
lcd.print( char(minute % 10 + 0x30));
//lcd.print(":");
//lcd.print(char (second / 10 + 0x30));
//lcd.print(char (second % 10 + 0x30));
adjust_high_lats = None;
dhuhr_minutes = 0;
Time_Zone = 3;
//latitude = 38.41885;
//longitude = 27.12872;
pinMode(amfipin, OUTPUT);
pinMode(role1pin, OUTPUT);
pinMode(role2pin, OUTPUT);
pinMode(LCDPin, OUTPUT);
digitalWrite(amfipin, HIGH);//amfi is OFF
digitalWrite(role1pin, HIGH);//lights 1
digitalWrite(role2pin, HIGH);//lights 2
Wire.begin();
Serial.begin(9600); //console
Serial1.begin(9600); //df player
if (lcdgecis < 3) {intervalswap=3;}
else if (lcdgecis > 20) {intervalswap=20;}
else intervalswap = lcdgecis*1000;
configureCommon(); // Setup pins for interrupt keys
attachInterrupt(digitalPinToInterrupt(commonPin), pressInterrupt, FALLING);
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
Serial.flush();
while (1) delay(10);
lcd.begin();
lcd.backlight();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("*******************");
lcd.setCursor(0, 3);
delay(2000);
lcd.setCursor(0, 2);
lcd.print("1..");
if (!myDFPlayer.begin(Serial1)) {Serial.println(F("Unable to begin DF"));while(true);}
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.setTimeOut(500); //Set serial communictaion time out 500ms
myDFPlayer.volume(fdvolume);
if (fdeq==1) {myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);}
if (fdeq==2) {myDFPlayer.EQ(DFPLAYER_EQ_POP);}
if (fdeq==3) {myDFPlayer.EQ(DFPLAYER_EQ_ROCK);}
if (fdeq==4) {myDFPlayer.EQ(DFPLAYER_EQ_JAZZ);}
if (fdeq==5) {myDFPlayer.EQ(DFPLAYER_EQ_CLASSIC);}
if (fdeq==6) {myDFPlayer.EQ(DFPLAYER_EQ_BASS);}
myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
myDFPlayer.disableLoop(); //disable loop.
myDFPlayer.enableDAC(); //Enable On-chip DAC
myDFPlayer.playFolder(8, 4);//welcome tone
roledevrede(); //relay control
roledevredisi(); //all relays off
getDateDs1307(); //get time/date
loadtape(); //load default values from eeprom
lcd.clear();
calculatetimes(); //1'st run
myDFPlayer.pause();
beep();beep();beep();
void loadtape()
for(int bisse=1; bisse<54; bisse++)
weynstring[bisse]=EEPROM.read(bisse);
ilkodu = weynstring[1];Serial.print("ilkodu :");Serial.println(ilkodu);
selaokunsun=weynstring[2];Serial.print("Sela okunsun :");Serial.println(selaokunsun);
persembeselaokunsun=weynstring[3];Serial.print("Persembe sela :");Serial.println(persembeselaokunsun);
cumavakitsabitle = weynstring[4];Serial.print("Cuma Sabit :");Serial.println(cumavakitsabitle);
cumavakitzamansaat = weynstring[5];Serial.print("Cuma sabitle :");Serial.println(cumavakitzamansaat);
cumavakitzamandakika = weynstring[6];Serial.print("Cuma sabit vkt:");Serial.println(cumavakitzamandakika);
imam=weynstring[17];Serial.print("imam :");Serial.println(imam);
amfigecikme=weynstring[18];Serial.print("Amfi Gecikme :");Serial.println(amfigecikme);
sabahezangecikme=weynstring[19];Serial.print("Sabah Gecikme :");Serial.println(sabahezangecikme);
//gunestemkinsaat=weynstring[20];Serial.print("gns tmkn ort :");Serial.println(gunestemkinsaat);
//gunestemkindakika=weynstring[21];Serial.print("gns tmkn dak :");Serial.println(gunestemkindakika);
fdvolume=weynstring[22];Serial.print("Volume :");Serial.println(fdvolume);
fdeq=weynstring[23];Serial.print("Fdeq :");Serial.println(fdeq);
ramazanayi=weynstring[24];Serial.print("Ramazan ayi :");Serial.println(ramazanayi);
timezone=weynstring[25]; Time_Zone=timezone;Serial.print("Time zone :");Serial.println(timezone);
parolavarmi=weynstring[26];Serial.print("Parola varmi :");Serial.println(parolavarmi);
cumaseladakika=weynstring[28];Serial.print("Cuma Sela dak :");Serial.println(cumaseladakika);
persembeseladakika=weynstring[29];Serial.print("Persembe sela :");Serial.println(persembeseladakika);
role1=weynstring[30];Serial.print("Role 1 :");Serial.println(role1);
role2=weynstring[31];Serial.print("Role 2 :");Serial.println(role2);
role1startsaat=weynstring[33];Serial.print("Role 1 start/saat :");Serial.println(role1startsaat);
role1startdakika=weynstring[34];Serial.print("Role 1 start/dak :");Serial.println(role1startdakika);
role1stopsaat=weynstring[35];Serial.print("Role 1 stop/saat :");Serial.println(role1stopsaat);
role1stopdakika=weynstring[36];Serial.print("Role 1 stop/dak :");Serial.println(role1stopdakika);
role2startsaat=weynstring[37];Serial.print("Role 2 start/saat :");Serial.println(role2startsaat);
role2startdakika=weynstring[38];Serial.print("Role 2 start/dak :");Serial.println(role2startdakika);
role2stopsaat=weynstring[39];Serial.print("Role 2 stop/saat :");Serial.println(role2stopsaat);
role2stopdakika=weynstring[40];Serial.print("Role 2 stop/dak :");Serial.println(role2stopdakika);
lcdgecis=weynstring[41];Serial.print("LCD gecis hizi :");Serial.println(lcdgecis);
sabahdiff = weynstring[42];
sabahmajmo = weynstring[43];
gunesdiff = weynstring[44];
gunesmajmo = weynstring[45];
oglediff = weynstring[46];
oglemajmo = weynstring[47];
ikindidiff = weynstring[48];
ikindimajmo = weynstring[49];
aksamdiff = weynstring[50];
aksammajmo = weynstring[51];
yatsidiff = weynstring[52];
yatsimajmo = weynstring[53];
void savetape() //save defaults when setup is complete
EEPROM.write(bisse, weynstring[bisse]);
Serial.print("\t");
Serial.print(weynstring[bisse], DEC);
void erasetape() // load defaults on request
EEPROM.write(bisse, 0);
} EEPROM.write(1, 35);
EEPROM.write(2, 0);
EEPROM.write(3, 0);
EEPROM.write(4, 0);
EEPROM.write(5, 0);
EEPROM.write(6, 0);
EEPROM.write(17, 3);
EEPROM.write(18, 3);
EEPROM.write(19, 55);
EEPROM.write(22, 10);
EEPROM.write(23, 0);
EEPROM.write(24, 0);
EEPROM.write(25, 3);
EEPROM.write(26, 0);
EEPROM.write(27, 0);
EEPROM.write(28, 0);
EEPROM.write(29, 0);
EEPROM.write(30, 0);
EEPROM.write(31, 0);
EEPROM.write(33, 0);
EEPROM.write(34, 0);
EEPROM.write(35, 0);
EEPROM.write(36, 0);
EEPROM.write(37, 0);
EEPROM.write(38, 0);
EEPROM.write(39, 0);
EEPROM.write(40, 0);
EEPROM.write(41, 7);
Serial.print("eeprom erased...");
unsigned long currentswap = millis(); //screen swapper
if (currentswap - previousswap > intervalswap)
previousswap = currentswap;
if (ekran==true) {ekran=false;}
else {ekran=true;}
if (ekran==true)
if (manual == false) {ticker1();}
else {ticker1a();}
unsigned long currentMillis = millis(); //set to 10 sec. THIS IS THE REAL DEAL
if (currentMillis - previousMillis > interval)
getDateDs1307();
printTime();
calculatetimes();
kalansure(); //calculate and display time left for next prayer time
ezanperiod(); //calculate mp3 files period
isitezantime(); //check if time has come to announce call for prayer
else {fujitsu2();}
if (activekey == 1)
manual = true;
beep();
activekey=0;
if (activekey == 2)
beep();
guven();
activekey=0;
if (activekey == 3) //free
beep();
activekey=0;
if (activekey == 4)
// setdateabi();
beep();
activekey=0;
if ((manual == true) && (guvence==false))
ticker1a();
if (activekey == 1)
//roledevrede();
beep();
manual = false;
ticker1();
activekey=0;
if (activekey == 2)
beep();
selamiezan();
activekey=0;
if (activekey == 3)
beep();
rolekurulum();
activekey=0;
if (activekey == 4)
beep();
setkurulum();
activekey=0;
while (guvence==true) //if keypad locked continue duty
// key logo on top
getDateDs1307();
printTime();
kalansure();
if (tick==true) {tickermain();} else {ticker1();}
unsigned long currentMillis1 = millis(); //set to 6 Hrs.
if (currentMillis1 - previousMillis1 > interval1)
previousMillis1 = currentMillis1;
calculatetimes();
if (activekey == 1)
sayacim=sayacim+1;
activekey=0;
if (activekey == 2)
sayacim=sayacim+2;
activekey=0;
if (activekey == 3)
sayacim=sayacim+3;
activekey=0;
if (activekey == 4)
if (sayacim ==8) {sayacim=0;activekey=0;lcd.setCursor(0,0);lcd.print(" ");guvence=false;break;}
sayacim=0;
activekey=0;
Serial.println(sayacim);
void fujitsu2()
printTime();
tickermain();
void guven()
if ((parolavarmi == 1) && (guvence == false)) {lcd.setCursor(0,0); lcd.print("kilit"); guvence=true;}
else if ((parolavarmi == 1) && (guvence == true)) {lcd.setCursor(0,0);lcd.print(" "); guvence=false;}
activekey=0;
void selamiezan()////////////////////////////////////////////// Manual selection for pray time or sela
activekey=0;
lcd.clear();
ticker7();
lcd.setCursor(0,0);
lcd.print("seçiniz");
activekey=0;bitti1=false;
while (bitti1==false)
if (activekey==1) {activekey=0;beep();selaoku();bitti1=true;}
else if (activekey==2) {activekey=0;beep();ezanoku();bitti1=true;} //kalan sure required for manual ezan
else if (activekey==3) {activekey=0;beep();digitalWrite(amfipin, !digitalRead(amfipin));bitti1=true;} //amfi aç/kapa
else if (activekey==4) {activekey=0;beep();bitti1=true;}
else {activekey=0;}
lcd.clear();
void isitezantime()
int timeinminutes = ((hour * 60) + minute);
int sabezantotalmin=(sabahezanhour * 60) + sabahezanminute;
int ogletotalminutes=(oglehour * 60) + ogleminute;
int ikinditotalminutes=(ikindihour * 60) + ikindiminute;
int aksamtotalminutes=(aksamhour * 60) + aksamminute;
int yatsitotalminutes=(yatsihour * 60) + yatsiminute;
// kalansaat = 0; kalandakika = 0;
//------------------------------------------------------------------EZAN ACTION-----------------------------------------------------------------------------
if (ezantrap == false) //to avoid repetition in case ezan returns earlier than expected
if ((hour==sabahezanhour) && (minute==sabahezanminute) && (ramazanayi==0)) {ezanfile=1;Serial.println("aroma 1");ezanoku();}
else if ((hour==sabahhour) && (minute==sabahminute) && (ramazanayi==1)) {ezanfile=1;Serial.println("aroma 2");ezanoku();} //ramazan sabah ezanı
else if ((hour==cumavakitzamansaat) && (minute==abs(cumavakitzamandakika)) && (cumavakitsabitle==1) && (dayOfWeek==5)) //Cuma ozel ezanı--note that time was replaced somewhere else with new hour and minute
ezanfile=2;Serial.println("aroma 3");ezanoku();
else if ((hour==oglehour) && (minute==abs(ogleminute)) && (cumavakitsabitle==0)) //normal ogle vakti
ezanfile=2;Serial.println("aroma 4");ezanoku();
else if ((hour==oglehour) && (minute==abs(ogleminute)) && (cumavakitsabitle==1) && (dayOfWeek!=5)) //ogle vakti ve Cuma degil
ezanfile=2;Serial.println("aroma 5");ezanoku();
else if ((hour==ikindihour) && (minute==abs(ikindiminute))) {ezanfile=3;Serial.println("aroma 6");ezanoku();}
else if ((hour==aksamhour) && (minute==abs(aksamminute))) {ezanfile=4;Serial.println("aroma 7");ezanoku();}
else if ((hour==yatsihour) && (minute==abs(yatsiminute))) {ezanfile=5;Serial.println("aroma 8");ezanoku();}
//-------------------------------------------------------------------sela ACTION----------------------------------------------------------------------------
else if ((ramazanayi==0) && (dayOfWeek==5) && (selaokunsun == 1) && (cumavakitsabitle = 0) && (hour==oglehourSela) && (minute=ogleminuteSela)) {ezanfile=2;Serial.println("aroma 9");selaoku();}
else if ((ramazanayi==0) && (dayOfWeek==4) && (persembeselaokunsun == 1) && (hour==persembeselahour) && (minute==persembeselaminute)) {ezanfile=2;Serial.println("aroma 10");selaoku();}
else if ((ramazanayi==1) && ((hour*60)==yatsitotalminutes-45)) {ezanfile=2;Serial.println("aroma 11");selaoku();} //daily sela in Ramazan
void isitroletime() //activate lights automa. in Ramadan month
if (role1 == 0) {role1devredisi();}
else if (role2 == 0) {role2devredisi();}
else if (role1 == 1) {role1devrede();}
else if (role2 == 1) {role2devrede();}
if ((role1 == 2) && (role1startsaat==hour) && (role1startdakika==minute)) {role1devrede();}
else if ((role2 == 2) && (role2startsaat==hour) && (role2startdakika==minute)) {role2devrede();}
else if ((role1 == 2) && (role1stopsaat==hour) && (role1stopdakika==minute)) {role1devredisi();}
else if ((role1 == 2) && (role2stopsaat==hour) && (role2stopdakika==minute)) {role2devredisi();}
if ((ramazanayi == 1) && (hour==aksamhour) && (minute==aksamminute)) {role1devrede();role2devrede();} //relay 1+2 on
else if ((ramazanayi == 1) && (hour==aksamhour) && (minute==(aksamminute)+15)) {role2devredisi();} //relay 1 off
else if ((ramazanayi == 1) && (hour==role1stopsaat) && (minute ==role1stopdakika)) {role1devredisi();}// relay 1 timer off
else if ((ramazanayi == 1) && (hour==sabahhour) && (minute==sabahminute)) {role1devredisi();role2devredisi();} // relay 1 & 2 OFF
else if ((ramazanayi == 1) && (hour==role2stopsaat) && (minute ==role2stopdakika)) {role2devredisi();}
//Serial.println("module: end isitroletime");
void kalansure() //used only by manual ezan to determine timing of prayer
//Serial.println("module: start kalansure");
// ezanperiod(); //hangi ezan ne kadar sürer DF player için
// -----------------------------------------------------------------KALAN ZAMAN -----------------------------------------------------
if ((timeinminutes > sabezantotalmin) && (timeinminutes < ogletotalminutes))
hadise="öğle ye ";
kalandakika = (ogletotalminutes - timeinminutes);
kalansaat = int(kalandakika/60);kalandakika = kalandakika - (kalansaat*60);
ezanfile = 1;
else if ((timeinminutes > ogletotalminutes) && (timeinminutes < ikinditotalminutes))
hadise="ikindi ye ";
kalandakika = (ikinditotalminutes - timeinminutes);
ezanfile = 2;
else if((timeinminutes > ikinditotalminutes) && (timeinminutes < aksamtotalminutes))
hadise="akşam a ";
kalandakika = (aksamtotalminutes - timeinminutes);
ezanfile = 3;
else if ((timeinminutes > aksamtotalminutes) && (timeinminutes < yatsitotalminutes))
hadise="yatsı ya ";
kalandakika = (yatsitotalminutes - timeinminutes);
ezanfile = 4;
hadise="sabah a ";
if ((timeinminutes > yatsitotalminutes) && (timeinminutes < 1439)) {kalandakika = ((1439-timeinminutes)+sabezantotalmin);Serial.println("<1439=");Serial.println(kalandakika);}//adjusted bug before 23:59
else {kalandakika = (sabezantotalmin - timeinminutes);Serial.println(">1439=");Serial.println(kalandakika);}
ezanfile = 5;
//Serial.println("module: end kalansure");
void ezanperiod() //calculated period of each ezan according to time and muezzin
if (ezanfile == 1) {interval2=377140;}
else if (ezanfile == 2) {interval2=239800;}
else if (ezanfile == 3) {interval2=362970;}
else if (ezanfile == 4) {interval2=179850;}
else if (ezanfile == 5) {interval2=359700;}
else //default if not selected
interval2 = 379999;
void ezanoku()
Serial.println("ezanoku::::: start ");
ezantrap=true;
roledevrede();
Serial.println("relay on");
boolean stillplaying = true;
lcd.clear();activekey=0; lcd.setCursor(0,0); lcd.print("*Amfi*");delay(int(amfigecikme)*1000);//wait for amp
int tiktok = 5;int menuoption =0; ticker5();
lcd.setCursor(0,0); lcd.print("*ezan*");
fdvolume=EEPROM.read(22); weynstring[23]=EEPROM.read(23);
if (fdvolume > 30) {fdvolume=30;} else if (fdvolume < 0) {fdvolume=0;}
myDFPlayer.playFolder(imam, ezanfile); // start playing till millis routine decides its over
unsigned long intervalx = interval2;
Serial.println("intervalx=");Serial.println(intervalx); //correct info
while (stillplaying == true)
unsigned long currentMillis3=millis();
Serial.println("currentMillis3=");Serial.println(currentMillis3);
Serial.println("previousMillis3=");Serial.println(previousMillis3);
Serial.println("ezanmodule::::: formula=");Serial.println(currentMillis3 - previousMillis3);
if (currentMillis3 - previousMillis3 >= intervalx) //ezan period timer
previousMillis3 = currentMillis3;
Serial.println("ezan::::exiting timer...");
stillplaying=false;
if ((activekey == 1) && (tiktok==5)) {beep();menuoption=1;tiktok=6;ticker6();activekey=0;} //trigger ses ayarı
if ((activekey == 2) && (tiktok==5)) {beep();menuoption=2;tiktok=6;ticker6();activekey=0;} //trigger eko ayarı
if ((activekey == 1) && (menuoption==1))// vol vol vol
//----- ses
beep();ticker6();myDFPlayer.volumeDown();fdvolume=fdvolume - 1;if (fdvolume < 0) {fdvolume=0;}activekey=0;
lcd.setCursor(13,3); lcd.print(" "); lcd.setCursor(13,3); lcd.print(fdvolume); tiktok==6; activekey=0;
if ((activekey == 2) && (menuoption==1))
//+++++ ses
beep();ticker6(); myDFPlayer.volumeUp(); fdvolume=fdvolume + 1;if (fdvolume > 30) {fdvolume=30;} if (fdvolume < 0) {fdvolume=0;}
lcd.setCursor(13,3); lcd.print(" "); lcd.setCursor(13,3); lcd.print(fdvolume); tiktok=6; activekey=0;
if (activekey == 3)
beep();
activekey=0;
if ((activekey == 4) && (menuoption==1))
beep();menuoption=0; tiktok=5; ticker5(); activekey=0;
if ((activekey == 1) && (menuoption==2))// eko eko eko eko
beep();
ticker6();
fdeq=fdeq - 1;
if (fdeq<1) {fdeq=6;}
if (fdeq>6) {fdeq=1;}
activekey=0; lcd.setCursor(13,3); lcd.print(" "); lcd.setCursor(13,3);
lcd.print(fdeq); tiktok==6; activekey=0;
if ((activekey == 2) && (menuoption==2))
beep();
ticker6();
fdeq=fdeq + 1;
lcd.setCursor(13,3); lcd.print(" "); lcd.setCursor(13,3); lcd.print(fdeq);
if (activekey == 3)
beep();activekey=0;
if ((activekey == 4) && (menuoption==2))
if ((activekey == 4) && (menuoption==0))
//stop
beep();myDFPlayer.pause(); activekey=0; stillplaying=false;
activekey=0;
if ((fdvolume) != (EEPROM.read(22))) {EEPROM.write(22, fdvolume);} //compare if changed and update eeprom
if ((fdeq) != (EEPROM.read(23))) {EEPROM.write(23, fdeq);}
lcd.setCursor(0,0);lcd.print(" "); ticker1a();
myDFPlayer.pause();
Serial.println("relay off");
roledevredisi();
getDateDs1307();
printTime();
// kalansure();
calculatetimes();
ezantrap=false;
Serial.println("ezanoku:::::end of loop");
void selaoku() //same as ezan but different file
boolean stillplaying;
roledevrede();
lcd.clear();lcd.setCursor(0,0); lcd.print("*Amfi*"); delay(int(amfigecikme)*1000);//wait for amp
activekey=0; int tiktok = 5;int menuoption =0; ticker5();lcd.setCursor(0,0);lcd.print("*sela*");
fdvolume=EEPROM.read(22); weynstring[23]=EEPROM.read(23); fdeq=weynstring[23];
myDFPlayer.playFolder(1, 6);
Serial.println("sela interval is");Serial.println(selainterval);
unsigned long cselamillis = millis();
if (cselamillis - pselamillis > selainterval)
{pselamillis = cselamillis; Serial.println("exiting sela condition with pselamillis=");Serial.println(pselamillis);stillplaying=false;}
//----- ses
beep();ticker6(); myDFPlayer.volumeDown();fdvolume=fdvolume - 1;activekey=0;if (fdvolume < 0) {fdvolume=0;}
//+++++ ses
beep();ticker6(); myDFPlayer.volumeUp(); fdvolume=fdvolume + 1; lcd.setCursor(13,3); lcd.print(" "); if (fdvolume > 30) {fdvolume=30;}
if (activekey == 3)
beep();activekey=0;
beep();
ticker6();
fdeq=fdeq - 1;
beep();
ticker6();
fdeq=fdeq + 1;
lcd.print(fdeq); tiktok=6; activekey=0;
if (activekey == 3)
beep();activekey=0;
beep(); myDFPlayer.pause(); activekey=0;stillplaying=false;
activekey=0; lcd.setCursor(0,0);lcd.print(" "); ticker1a();
myDFPlayer.pause();
roledevredisi();
getDateDs1307();
printTime();
// kalansure();
calculatetimes();
void ticker1() //manual
lcd.setCursor(0,3);
lcd.print("elle ");
void ticker1a() //oto prayer relay setup
lcd.setCursor(0,3);
lcd.print("oto sela röle ayar");
void ticker2() //son=done
lcd.setCursor(0,3);
lcd.print("---- +++++ son");
void ticker3()
lcd.setCursor(0,3);
lcd.print("evet hayir son");
void ticker4() //volume up down stop
lcd.setCursor(0,3);
lcd.print("ses- ses+ dur");
void ticker5()
lcd.setCursor(0,3);
lcd.print("ses eko dur");
void ticker6() //volume up down back
lcd.setCursor(0,3);
lcd.print("---- +++++ geri");
void ticker7()
lcd.setCursor(0,3);
lcd.print("Sela Ezan Amfi geri");
void tickermain()
kalansure();
lcd.setCursor(0, 1);
lcd.print(" ");
lcd.print(" ");
lcd.setCursor(0,2);
lcd.print(hadise);
lcd.setCursor(10,2);
lcd.print( char( kalansaat / 10 + 0x30) );
lcd.print( char( kalansaat % 10 + 0x30) );
lcd.print(":");
lcd.print( char(kalandakika / 10 + 0x30));
lcd.print( char(kalandakika % 10 + 0x30));
void rolekurulum() //display and adjust relays to on/off/auto
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" R1 R2 LCD");
lcd.setCursor(0,1);
lcd.print(" OT OT 30 ");
lcd.setCursor(0,2);
lcd.print(" AÇ AÇ 60 ");
lcd.setCursor(0,3);
lcd.print(" KA KA 99 son");
activekey=0;bitti=0;
rolegoster();roleaction();
int amfisayac=0, role2sayac=0,role3sayac=0;activekey=0;
while (bitti==false)
if (activekey==1) {beep();amfisayac = amfisayac + 1; if (amfisayac<0){amfisayac=2;} if (amfisayac>2){amfisayac=0;}role1=amfisayac;rolegoster();roleaction();activekey=0;}
else if (activekey==2) {beep();role2sayac = role2sayac + 1; if (role2sayac<0){role2sayac=2;} if (role2sayac>2){role2sayac=0;}role2=role2sayac;rolegoster();roleaction();activekey=0;}
else if (activekey==3) {beep();role3sayac = role3sayac + 1; if (role3sayac<0){role3sayac=2;} if (role3sayac>2){role3sayac=0;}role3=role3sayac;rolegoster();roleaction();activekey=0;}
else if (activekey==4) {beep();activekey=0;bitti=true;}
else {activekey=0;}
EEPROM.write(role1, weynstring[30]);
EEPROM.write(role2, weynstring[31]);
lcd.clear();
calculatetimes();
//check difference then update eeprom
void roleaction()
if ((role1 == 0) or (role1 == 2)) {digitalWrite(role1pin, HIGH);}
if (role1 == 1) {digitalWrite(role1pin, LOW);}
if ((role2 == 0) or (role2 ==2)) {digitalWrite(role2pin, HIGH);}
if (role2 == 1) {digitalWrite(role2pin, LOW);}
if (role3 == 0) {analogWrite(LCDPin, 255);}
if (role3 == 1) {analogWrite(LCDPin, 170);}
if (role3 == 2) {analogWrite(LCDPin, 85);}
void rolegoster()
if (role1 == 2) {lcd.setCursor(0,1);lcd.print(">");lcd.setCursor(0,2);lcd.print(" ");lcd.setCursor(0,3);lcd.print(" ");}
if (role1 == 1) {lcd.setCursor(0,1);lcd.print(" ");lcd.setCursor(0,2);lcd.print(">");lcd.setCursor(0,3);lcd.print(" ");}
if (role1 == 0) {lcd.setCursor(0,1);lcd.print(" ");lcd.setCursor(0,2);lcd.print(" ");lcd.setCursor(0,3);lcd.print(">");}
if (role2 == 2){lcd.setCursor(5,1);lcd.print(">");lcd.setCursor(5,2);lcd.print(" ");lcd.setCursor(5,3);lcd.print(" ");}
if (role2 == 1){lcd.setCursor(5,1);lcd.print(" ");lcd.setCursor(5,2);lcd.print(">");lcd.setCursor(5,3);lcd.print(" ");}
if (role2 == 0){lcd.setCursor(5,1);lcd.print(" ");lcd.setCursor(5,2);lcd.print(" ");lcd.setCursor(5,3);lcd.print(">");}
if (role3 == 2){lcd.setCursor(10,1);lcd.print(">");lcd.setCursor(10,2);lcd.print(" ");lcd.setCursor(10,3);lcd.print(" ");}
if (role3 == 1){lcd.setCursor(10,1);lcd.print(" ");lcd.setCursor(10,2);lcd.print(">");lcd.setCursor(10,3);lcd.print(" ");}
if (role3 == 0){lcd.setCursor(10,1);lcd.print(" ");lcd.setCursor(10,2);lcd.print(" ");lcd.setCursor(10,3);lcd.print(">");}
void setkurulum() //setup menu (deleted)
void setdateabi() {} //n/o
void calculatetimes()
ilkoordinat();
int g=3;
ch='0';
int deli = 0;
calc_method = ch & 0x0F;
method_params[0] = MethodConfig(18.0, true, 0.0, false, 17.0); // MWL
method_params[1] = MethodConfig(18.0, true, 0.0, false, 18.0); // Karachi
method_params[2] = MethodConfig(15.0, true, 0.0, false, 15.0); // ISNA
method_params[3] = MethodConfig(18.5, true, 0.0, true, 90.0); // Makkah
method_params[4] = MethodConfig(19.5, true, 0.0, false, 17.5); // Egypt
method_params[5] = MethodConfig(16.0, false, 4.0, false, 14.0); // Jafari
method_params[6] = MethodConfig(17.7, false, 0.0, false, 14.0); // Tehranch = '1';
asr_juristic = ch & 0x0F;
struct tm current_date;
// copy,ng current date into variables prayer_times uses
current_date.tm_sec = second; /** < seconds after the minute - [ 0 to 59 ] */
current_date.tm_min = minute; /** < minutes after the hour - [ 0 to 59 ] */
current_date.tm_hour = hour; /** < hours since midnight - [ 0 to 23 ] */
current_date.tm_mday = dayOfMonth; /** < day of the month - [ 1 to 31 ] */
current_date.tm_wday = dayOfWeek; /** < days since Sunday - [ 0 to 6 ] */
current_date.tm_mon = month; /** < months since January - [ 0 to 11 ] */
current_date.tm_year = (((year)+2000) - 1900); /** < years since 1900 +++year - 1900; */
time_t date = mktime(¤t_date);
double times[TimesCount];
get_prayer_times(date, latitude, longitude, 3, times);
//***************************************************************************************morning prayer calculations------------------------
String hour1 = (float_time_to_time24(times[0]).c_str());
String hr=String((hour1).charAt(0))+String((hour1).charAt(1));String mn=String((hour1).charAt(3))+String((hour1).charAt(4));
newhour=hr.toInt(); newminute=mn.toInt();
calculatedsabah = (newhour*60)+newminute; tempo=0;
if (sabahdiff == 1) //fix time +++++++++++++
deli = calculatedsabah + sabahmajmo;
sabahhour = int((deli)/60); sabahminute = deli - (sabahhour*60);
else if (sabahdiff == 2)
deli = calculatedsabah - sabahmajmo;
else {sabahhour=newhour;sabahminute=newminute;}
hr="";mn="";newhour=0;newminute=0;deli=0;
//***************************************************************************************prayer calculations------------------------
hour1 = (float_time_to_time24(times[1]).c_str());
hr=String((hour1).charAt(0))+String((hour1).charAt(1));mn=String((hour1).charAt(3))+String((hour1).charAt(4));
calculatedgunes = (newhour*60)+newminute; tempo=0;
if (gunesdiff == 1) //fix time +++++++++++++
deli = calculatedgunes + gunesmajmo;
guneshour = int((deli)/60); gunesminute = deli - (guneshour*60);
else if (gunesdiff == 2)
deli = calculatedgunes - gunesmajmo;
else {guneshour=newhour;gunesminute=newminute;}
hour1 = (float_time_to_time24(times[2]).c_str());
calculatedogle = (newhour*60)+newminute; tempo=0;
if (oglediff == 1) //fix time +++++++++++++
deli = calculatedogle + oglemajmo;
oglehour = int((deli)/60); ogleminute = deli - (oglehour*60);
else if (oglediff == 2)
deli = calculatedogle - oglemajmo;
else {oglehour=newhour;ogleminute=newminute;}
//*****************************************careful asr/sunset are different use asr******prayer calculations------------------------
hour1 = (float_time_to_time24(times[3]).c_str());
calculatedikindi = (newhour*60)+newminute; tempo=0;
if (ikindidiff == 1) //fix time +++++++++++++
deli = calculatedikindi + ikindimajmo;
ikindihour = int((deli)/60); ikindiminute = deli - (ikindihour*60);
else if (ikindidiff == 2)
deli = calculatedikindi - ikindimajmo;
else {ikindihour=newhour;ikindiminute=newminute;}
hour1 = (float_time_to_time24(times[5]).c_str());
calculatedaksam = (newhour*60)+newminute; tempo=0;
if (aksamdiff == 1) //fix time +++++++++++++
deli = calculatedaksam + aksammajmo;
aksamhour = int((deli)/60); aksamminute = deli - (aksamhour*60);
else if (aksamdiff == 2)
deli = calculatedaksam - aksammajmo;
else {aksamhour=newhour;aksamminute=newminute;}
hour1 = (float_time_to_time24(times[6]).c_str());
calculatedyatsi = (newhour*60)+newminute; tempo=0;
if (yatsidiff == 1) //fix time +++++++++++++
deli = calculatedyatsi + yatsimajmo;
yatsihour = int((deli)/60); yatsiminute = deli - (yatsihour*60);
else if (yatsidiff == 2)
deli = calculatedyatsi - yatsimajmo;
else {yatsihour=newhour;yatsiminute=newminute;}
if ((cumavakitsabitle==1) && (dayOfWeek==5))
oglehour = cumavakitzamansaat;
ogleminute = cumavakitzamandakika;
//--------------------------------------------------------------------------------- display time
lcd.print(" ");
lcd.print(" ");
lcd.print("İ");
lcd.setCursor(1, 1);
lcd.print( char( sabahhour / 10 + 0x30) );
lcd.print( char( sabahhour % 10 + 0x30) );
//lcd.print(sabahhour);
lcd.setCursor(3, 1);
lcd.print(":");
lcd.setCursor(4, 1);
//lcd.print(sabahminute);
lcd.print( char( sabahminute / 10 + 0x30) );
lcd.print( char( sabahminute % 10 + 0x30) );
lcd.setCursor(7, 1);
lcd.print("G");
lcd.setCursor(8, 1);
lcd.print( char( guneshour / 10 + 0x30) );
lcd.print( char( guneshour % 10 + 0x30) );
//lcd.print(guneshour);
lcd.setCursor(10, 1);
lcd.print(":");
lcd.setCursor(11, 1);
//lcd.print(gunesminute);
lcd.print( char( gunesminute / 10 + 0x30) );
lcd.print( char( gunesminute % 10 + 0x30) );
lcd.setCursor(14, 1);
lcd.print("Ö");
lcd.setCursor(15, 1);
lcd.print( char( oglehour / 10 + 0x30) );
lcd.print( char( oglehour % 10 + 0x30) );
//lcd.print(oglehour);
lcd.setCursor(17, 1);
lcd.print(":");
lcd.setCursor(18, 1);
//lcd.print(ogleminute);
lcd.print( char( ogleminute / 10 + 0x30) );
lcd.print( char( ogleminute % 10 + 0x30) );
lcd.print("İ");
lcd.setCursor(1, 2);
//lcd.print(ikindihour);
lcd.print( char( ikindihour / 10 + 0x30) );
lcd.print( char( ikindihour % 10 + 0x30) );
lcd.setCursor(3, 2);
lcd.print(":");
lcd.setCursor(4, 2);
//lcd.print(ikindiminute);
lcd.print( char( ikindiminute / 10 + 0x30) );
lcd.print( char( ikindiminute % 10 + 0x30) );
lcd.setCursor(7, 2);
lcd.print("A");
lcd.setCursor(8, 2);
//lcd.print(aksamhour);
lcd.print( char( aksamhour / 10 + 0x30) );
lcd.print( char( aksamhour % 10 + 0x30) );
lcd.setCursor(10, 2);
lcd.print(":");
lcd.setCursor(11, 2);
//lcd.print(aksamminute);
lcd.print( char( aksamminute / 10 + 0x30) );
lcd.print( char( aksamminute % 10 + 0x30) );
lcd.setCursor(14, 2);
lcd.print("Y");
lcd.setCursor(15, 2);
//lcd.print(yatsihour);
lcd.print( char( yatsihour / 10 + 0x30) );
lcd.print( char( yatsihour % 10 + 0x30) );
lcd.setCursor(17, 2);
lcd.print(":");
lcd.setCursor(18, 2);
//lcd.print(yatsiminute);
lcd.print( char( yatsiminute / 10 + 0x30) );
lcd.print( char( yatsiminute % 10 + 0x30) );
String two_digits_format(int num){
char tmp[16];
tmp[0] = '\0';
sprintf(tmp, "%2.2d", num);
return String(tmp);
char tmp[16];
tmp[0] = '\0';
if (num>=0 && num<=9) sprintf(tmp, "0%d", num);
else sprintf(tmp, "%d", num);
return String(tmp);
static double fix_hour(double a){
a = a - 24.0 * floor(a / 24.0);
a = a < 0.0 ? a + 24.0 : a;
return a;
static void get_float_time_parts(double time, int& hours, int& minutes){
time = fix_hour(time + 0.5 / 60); // add 0.5 minutes to round
hours = floor(time);
minutes = floor((time - hours) * 60);
String float_time_to_time24(double Time){
if(isnan(Time))
return String();
int hours, minutes;
get_float_time_parts(Time, hours, minutes);
return two_digits_format(hours) + ':' + two_digits_format(minutes);
String float_time_to_time12(double Time, bool no_suffix = false){
if (isnan(Time))
return String();
int hours, minutes;
const char* suffix = hours >= 12 ? " PM" : " AM";
hours = (hours + 12 - 1) % 12 + 1;
return int_to_string(hours) + ':' + two_digits_format(minutes) + (no_suffix ? "" : suffix);
double deg2rad(double d){
return d * M_PI / 180.0;
double rad2deg(double r){
return r * 180.0 / M_PI;
static double dsin(double d){
return sin(deg2rad(d));
static double dcos(double d){
return cos(deg2rad(d));
static double dtan(double d){
return tan(deg2rad(d));
static double darcsin(double x){
return rad2deg(asin(x));
static double darccos(double x){
return rad2deg(acos(x));
static double darctan(double x){
return rad2deg(atan(x));
static double darctan2(double y, double x){
return rad2deg(atan2(y, x));
static double darccot(double x){
return rad2deg(atan(1.0 / x));
static double fix_angle(double a){
a = a - 360.0 * floor(a / 360.0);
a = a < 0.0 ? a + 360.0 : a;
return a;
static double time_diff(double time1, double time2){
return fix_hour(time2 - time1);
void sun_position(double jd, double &D, double &Eq_t){
double d = jd - 2451545.0; // jd is the given Julian date
double g = fix_angle(357.529 + 0.98560028 * d);
double q = fix_angle(280.459 + 0.98564736 * d);
double L = fix_angle(q + 1.915 * dsin(g) + 0.020 * dsin(2 * g));
double R = 1.00014 - 0.01671 * dcos(g) - 0.00014 * dcos(2 * g);
double e = 23.439 - 0.00000036 * d;
double RA = darctan2(dcos(e) * dsin(L), dcos(L)) / 15.0;
D = darcsin(dsin(e) * dsin(L)); // declination of the Sun
RA = fix_hour(RA);
Eq_t = q / 15.0 - RA; // equation of time
double equation_of_time(double jd){
double D;
double Eq_t;
sun_position(jd, D, Eq_t);
return Eq_t;
double sun_declination(double jd){
double D;
double Eq_t;
return D;
double compute_mid_day(double _t){
double t = equation_of_time(julian_date + _t);
double z = fix_hour(12 - t);
return z;
double compute_time(double g, double t){
double d = sun_declination(julian_date + t);
double z = compute_mid_day(t);
double v = 1.0 / 15.0 * darccos((-dsin(g) - dsin(d) * dsin(latitude)) / (dcos(d) * dcos(latitude)));
return z + (g > 90.0 ? - v : v);
void day_portion(double times[]){
for (int i = 0; i < TimesCount; ++i){
times[i] /= 24.0;
double compute_asr(int Step, double t){
double g = -darccot(Step + dtan(fabs(latitude - d)));
return compute_time(g, t);
void compute_times(double times[]){
day_portion(times);
times[Fajr] = compute_time(180.0 - method_params[calc_method].fajr_angle, times[Fajr]);
times[Sunrise] = compute_time(180.0 - 0.833, times[Sunrise]);
times[Dhuhr] = compute_mid_day(times[Dhuhr]);
times[Asr] = compute_asr(1 + asr_juristic, times[Asr]);
times[Sunset] = compute_time(0.833, times[Sunset]);
times[Maghrib] = compute_time(method_params[calc_method].maghrib_value, times[Maghrib]);
times[Isha] = compute_time(method_params[calc_method].isha_value, times[Isha]);
double night_portion(double angle){
switch (adjust_high_lats)
case AngleBased:
return angle / 60.0;
case MidNight:
return 1.0 / 2.0;
case OneSeventh:
return 1.0 / 7.0;
default:
// Just to return something!
// In original library nothing was returned
// Maybe I should throw an exception
// It must be impossible to reach here
return 0;
void adjust_high_lat_times(double times[]){
double night_time = time_diff(times[Sunset], times[Sunrise]); // sunset to sunrise
// Adjust Fajr
double fajr_diff = night_portion(method_params[calc_method].fajr_angle) * night_time;
if (isnan(times[Fajr]) || time_diff(times[Fajr], times[Sunrise]) > fajr_diff)
times[Fajr] = times[Sunrise] - fajr_diff;
// Adjust Isha
double isha_angle = method_params[calc_method].isha_is_minutes ? 18.0 : method_params[calc_method].isha_value;
double isha_diff = night_portion(isha_angle) * night_time;
if (isnan(times[Isha]) || time_diff(times[Sunset], times[Isha]) > isha_diff)
times[Isha] = times[Sunset] + isha_diff;
// Adjust Maghrib
double maghrib_angle = method_params[calc_method].maghrib_is_minutes ? 4.0 : method_params[calc_method].maghrib_value;
double maghrib_diff = night_portion(maghrib_angle) * night_time;
if (isnan(times[Maghrib]) || time_diff(times[Sunset], times[Maghrib]) > maghrib_diff)
times[Maghrib] = times[Sunset] + maghrib_diff;
void adjust_times(double times[]){
times[i] += Time_Zone - longitude / 15.0;
times[Dhuhr] += dhuhr_minutes / 60.0; // Dhuhr
if (method_params[calc_method].maghrib_is_minutes) // Maghrib
times[Maghrib] = times[Sunset] + method_params[calc_method].maghrib_value / 60.0;
times[Isha];
if (method_params[calc_method].isha_is_minutes) // Isha
times[Isha] = times[Maghrib] + method_params[calc_method].isha_value / 60.0;
if (adjust_high_lats != None)
adjust_high_lat_times(times);
void compute_day_times(double times[]){
double default_times[] = { 5, 6, 12, 13, 18, 18, 18 }; // default times
times[i] = default_times[i];
for (int i = 0; i < NUM_ITERATIONS; ++i)
compute_times(times);
adjust_times(times);
double get_julian_date(int Year, int Month, int Day){
if (Month <= 2)
Year -= 1;
Month += 12;
double a = floor(Year / 100.0);
double b = 2 - a + floor(a / 4.0);
double c = floor(365.25 * (Year + 4716)) + floor(30.6001 * (Month + 1)) + Day + b - 1524.5;
return c;
void get_prayer_times(int Year, int Month, int Day, double _latitude, double _longitude, double _timezo, double times[]){
latitude = _latitude;
longitude = _longitude;
Time_Zone = _timezo;
julian_date = get_julian_date(Year, Month, Day);
julian_date = julian_date - longitude / (double) (15 * 24);
compute_day_times(times);
void get_prayer_times(time_t date, double latitude, double longitude, double Tzone, double times[]){
tm* t = localtime(&date);
get_prayer_times((1900 + t->tm_year), (t->tm_mon + 1), (t->tm_mday), latitude, longitude, Tzone, times);
void ilkoordinat()
// latitude;
// longitude;
switch (ilkodu)
case 1: //adana
latitude=37;longitude=35.321333;
case 2://adıyaman
latitude=37.764751;longitude=38.278561;
case 3://afyonkara
latitude=38.750714;longitude=30.556692;
case 4://ağrı
latitude=39.626922;longitude=43.021596;
case 68://aksaray
latitude=38.36869;longitude=34.03698;
case 5://amasya
latitude=40.64991;longitude=35.83532;
case 6://ankara
latitude=39.92077;longitude=32.85411;
case 7://antalya
latitude=36.88414;longitude=30.70563;
case 75://ardahan
latitude=41.110481;longitude=42.702171;
case 8://artvin
latitude=41.18277;longitude=41.818292;
case 9://aydın
latitude=37.856041;longitude=27.841631;
case 10://balıkesir
latitude=39.648369;longitude=27.88261;
case 74://bartın
latitude=41.581051;longitude=32.460979;
case 72://batman
latitude=37.881168;longitude=41.13509;
case 69://bayburt
latitude=40.255169;longitude=40.22488;
case 11://bilecik
latitude=40.056656;longitude=30.066524;
case 12://bingol
latitude=39.062635;longitude=40.76961;
case 13://bitlis
latitude=38.393799;longitude=42.12318;
case 14://bolu
latitude=40.575977;longitude=31.578809;
case 15://burdur
latitude=37.461267;longitude=30.066524;
case 16://bursa
latitude=40.266864;longitude=29.063448;
case 17://çanakkale
latitude=40.155312;longitude=26.41416;
case 18://çankırı
latitude=40.601343;longitude=33.613421;
case 19://çorum
latitude=40.550556;longitude=34.955556;
case 20://denizli
latitude=37.77652;longitude=29.08639;
case 21://diyarbakır
latitude=37.91441;longitude=40.230629;
case 81://düzce
latitude=40.843849;longitude=31.15654;
case 22://edirne
latitude=41.681808;longitude=26.562269;
case 23://elazığ
latitude=38.680969;longitude=39.226398;
case 24://erzincan
latitude=39.75;longitude=39.5;
case 25://erzurum
latitude=39.9;longitude=41.27;
case 26://eskişehir
latitude=39.776667;longitude=30.520556;
case 27://gaziantep
latitude=37.06622;longitude=37.38332;
case 28://giresun
latitude=40.912811;longitude=38.38953;
case 29://gümüşhane
latitude=40.438588;longitude=39.508556;
case 30://hakkari
latitude=37.583333;longitude=73.733333;
case 31://hatay
latitude=36.401849;longitude=36.34981;
case 76://ığdır
latitude=39.887984;longitude=44.004836;
case 32://isparta
latitude=37.764771;longitude=30.556561;
case 34://istanbul
latitude=41.00527;longitude=28.97696;
case 35://izmir
latitude=38.41885;longitude=27.12872;
case 46://kahramanmaraş
latitude=37.585831;longitude=36.937149;
case 78://karabük
latitude=41.2061;longitude=32.62035;
case 70://karaman
latitude=37.17593;longitude=33.228748;
case 36://kars
latitude=40.616667;longitude=43.1;
case 37://kastamonu
latitude=41.38871;longitude=33.78273;
case 38://kayseri
latitude=38.73122;longitude=35.478729;
case 71://kırıkkale
latitude=39.846821;longitude=33.515251;
case 39://kırklareli
latitude=41.733333;longitude=27.216667;
case 40://kırşehir
latitude=39.14249;longitude=34.17091;
case 79://kilis
latitude=36.718399;longitude=37.12122;
case 41://kocaeli
latitude=40.85327;longitude=29.88152;
case 42://konya
latitude=37.866667;longitude=32.483333;
case 43://kütahya
latitude=39.416667;longitude=29.983333;
case 44://malatya
latitude=38.35519;longitude=38.30946;
case 45://manisa
latitude=38.619099;longitude=27.428921;
case 47://mardınvbo
latitude=37.321163;longitude=40.724477;
case 33://mersin
latitude=36.8;longitude=34.63333;
case 48://muğla
latitude=37.215789;longitude=28.363611;
case 49://muş
latitude=38.946189;longitude=41.753893;
case 50://nevşehir
latitude=38.69394;longitude=34.685651;
case 51://niğde
latitude=37.966667;longitude=34.683333;
case 52://ordu
latitude=40.983879;longitude=37.876411;
case 80://osmaniye
latitude=37.213026;longitude=36.176261;
case 53://rize
latitude=41.02005;longitude=40.523449;
case 54://sakarya
latitude=40.693997;longitude=30.435763;
case 55://samsun
latitude=41.292782;longitude=3.33128;
case 56://siirt
latitude=37.9333333;longitude=41.95;
case 57://sinop
latitude=42.02314;longitude=35.153069;
case 58://sıvas
latitude=39.747662;longitude=37.017879;
case 63://şanlıurfa
latitude=37.159149;longitude=37.789909;
case 73://şırnak
latitude=37.418748;longitude=42.491834;
case 59://tekirdağ
latitude=40.983333;longitude=27.516667;
case 60://tokat
latitude=40.316667;longitude=36.55;
case 61://trabzon
latitude=41.00145;longitude=39.7178;
case 62://tunceli
latitude=39.307355;longitude=39.438778;
case 64://uşak
latitude=38.682301;longitude=29.266667;
case 65://van
latitude=38.48914;longitude=43.40889;
case 77://yalova
latitude=40.65;longitude=29.266667;
case 66://yozgat
latitude=39.818081;longitude=34.81469;
case 67://zonguldak
latitude=41.456409;longitude=31.798731;
case 99://lefkoşa
latitude=35.10;longitude=32.21;
default:
// all below is for key routine
void pressInterrupt() { // ISR
if (millis() - lastFire < 50) { // default is 200
return;
lastFire = millis();
configureDistinct(); // Setup pins for testing individual buttons
for (int i = 0; i < sizeof(buttonPins) / sizeof(int); i++) { // Test each button for press
if (!digitalRead(buttonPins[i])) {
press(i);
configureCommon(); // Return to original state
void configureCommon() {
pinMode(commonPin, INPUT_PULLUP);
pinMode(buttonPins[i], OUTPUT);
digitalWrite(buttonPins[i], LOW);
void configureDistinct() {
pinMode(commonPin, OUTPUT);
digitalWrite(commonPin, LOW);
pinMode(buttonPins[i], INPUT_PULLUP);
void press(int button) { // Our handler
activekey = (button + 1);
void roledevrede()
digitalWrite(amfipin, LOW);//off
void roledevredisi()
digitalWrite(amfipin, HIGH);//off
void role1devrede()
digitalWrite(role1pin, LOW);//off
void role1devredisi()
digitalWrite(role1pin, HIGH);//off
void role2devrede()
digitalWrite(role2pin, LOW);//off
void role2devredisi()
digitalWrite(role2pin, HIGH);//off
//mp3 routine
void printDetail(uint8_t type, int value){
switch (type) {
case TimeOut:
Serial.println(F("Time Out!"));
case WrongStack:
Serial.println(F("Stack Wrong!"));
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
case DFPlayerUSBInserted:
Serial.println("USB Inserted!");
case DFPlayerUSBRemoved:
Serial.println("USB Removed!");
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value) {
case Busy:
Serial.println(F("Card not found"));
case Sleeping:
Serial.println(F("Sleeping"));
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
case FileMismatch:
Serial.println(F("Cannot Find File"));
case Advertise:
Serial.println(F("In Advertise"));
default:
default:
void parolakontrol()
int hadipass=0;byte parolanedirtemp=0;
while (hadipass == 0)
lcd.setCursor(0,1);
lcd.print("parola giriniz ");
lcd.setCursor(16,1);
lcd.print(parolanedirtemp);
bitti=0;
if (activekey==1) {parolanedirtemp= parolanedirtemp -1; if (parolanedirtemp==-1) {parolanedirtemp=255;}lcd.setCursor(16,1); lcd.print(" ");lcd.setCursor(16,1);lcd.print(parolanedirtemp);}
else if (activekey==2) {parolanedirtemp= parolanedirtemp +1; if (parolanedirtemp>255) {parolanedirtemp=1;}lcd.setCursor(16,1); lcd.print(" ");lcd.setCursor(16,1);lcd.print(parolanedirtemp);}
activekey=0;
if ((parolanedir == parolanedirtemp) or (parolanedir == 129))
hadipass=1;
bitti=true; }
lcd.print("olmaz");
delay(30000);
lcd.print(" ");
else {activekey=0;}
lcd.clear();
void beep()
tone(beeppin, 1000); delay(150); noTone(beeppin); delay (150);
