Unresponsive Nano 33 IOT after "mis-powering" it
Hi there,
I'm relatively new to the forum and arduino in general, but i have a problem with my arduino nano IOT 33 which was which was working fine as i was able to use it as an RTC with an oled display, until i mistakenly plugged in my 6v battery pack to the wrong pins. I plugged the gnd of the battery pack to the reset pin of the arduino, and the 6v to the gnd pin on the arduino, it was plugged in for about a minute, because i wasnt paying attention while i did, and only noticed it because my display didn't turn on for a long time. Anyways, right now the green LED turns on, but my computer doesn't recognize the nano iot through both it's regular USB and a USB to serial converter connecting to all the right pins on the arduino, and the code thaw was on it also seems to be fried.
My question is , is there anyway i could fix it, because the board stills looks as good as new, and there was solid signs of the chips being burnt, the at16u2 most likely is though.
or should i go ahead and buy a new nano board?.
It's "toast".
I do not know your skill set or resources but the best solution would be to buy two more and use the fried one as a template for mounting other boards. You could try to replace that chip and get some experience you might get it to work.
We've all made mistakes like that. Treat it as a learning experience!
It will do, not everything bad results in a burn or visible damage, those are just the spectacular fails.
But inside if you could look it will be a bit of a mess. It is mainly the bond wires, those human hair thick gold wires, that connect the chip to the pins on the frame that melt.
