Hello, I am a final year student studying mecnhanical engineering and I am currently doing a project for a subject that I am taking. The project that I am doing is a mobile robot which is using an ESP32-WROOM-32, a MPU6050, and an ultrasonic sensor. So my problem is I wanted to find displacement using the accelerometer of the MPU6050 and I have already implemented an UKF to the accelerometer readings. I have made the code but somehow the readings that I am getting is not the displacement but whenever I tilt the robot up the readings increases and when I tilt the robot straight up the readings go up to 1.09 and then if I continue to flip it on its back the readings decreases again. Is there anything wrong with my code?
Here is my code that I am using and I am omitting the my wifi name and password and also I am omitting the urls for the sensors and also the MAC address for the ESP32 because I am using 2 mobile robots communicating between each other
#include <Wire.h>
#include <MPU6050_tockn.h>
//#include <TinyGPSPlus.h>
#include <Kalman.h>
#include <Ultrasonic.h>
//#include <esp_now.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <HTTPClient.h>
MPU6050 mpu(Wire);
//TinyGPSPlus gps;
//HardwareSerial SerialGPS(2);
WiFiClient client;
WiFiServer server(80);
// Constants for the low-pass filter
const float alphaLPF = 0.2; // Filter coefficient (0 < alpha < 1)
// Variables for the low-pass filter
float filteredAccelerationY = 0.0;
// Constants for Kalman filter
const float dt = 0.01; // Time step (in seconds)
const float varAcc = 10.0; // Variance of accelerometer measurements (value usually 0.01 to 0.1)
const float varProcess = 0.01; // Variance of process noise (value usually 1.0 to 10.0)
// Variables for Kalman filter
float positionY = 0.0;
float velocityY = 0.0;
float covPositionY = 10000.0; //Value usually 100.0 to 1000.0
float covVelocityY = 10000.0; //Value usually 100.0 to 1000.0
//Variables for GPS
double latitude, longitude, DataLat5, DataLat6;
String loadLat, loadlong;
String lat_str, lng_str;
String DataLat1, DataLat2, DataLat3, DataLat4;
// Motor A
int enA = 13;
int in1 = 12;
int in2 = 14;
// Motor B
int enB =19;
int in3 = 15;
int in4 = 18;
// Ultrasound sensor pins
int trigPin = 2;
int echoPin = 4;
// Threshold distance for wall detection
int wallDistanceThreshold = 30; // Adjust as needed
// Create an Ultrasonic object
Ultrasonic ultrasonic(trigPin, echoPin);
const char* ssid = "xxxxx"; //gantikan dengan nama WiFi
const char* password = "xxxxx"; //gantikan dengan password WiFi
//URL link to Post Ultrasonic
//String serverNameUltrasonic ="";
//String serverNameGPS1 ="";
//String serverNameGPS2 ="";
//String serverNamePosX ="";
String serverNamePosY ="";
//String serverNameYaw ="";
unsigned long lastTime = 0;
//Set timer to 5 seconds (5000)
unsigned long timerDelay = 5000;
// REPLACE WITH THE RECEIVER'S MAC Address
uint8_t broadcastAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
// Structure example to send data
typedef struct struct_message {
int id; // must be unique for each sender board
float positionY;
} struct_message;
// Create a struct_message called myData
struct_message myData;
// Create peer interface
esp_now_peer_info_t peerInfo;
// Helper function to serialize a float value to a byte array
void serializeFloat(float value, uint8_t* buffer) {
memcpy(buffer, &value, sizeof(float));
Wire.begin();
// Initialize MPU6050
mpu.begin();
mpu.calcGyroOffsets();
//tetapkan paparan series
WiFi.begin(ssid, password);
while(WiFi.status()!=WL_CONNECTED)
Serial.println("Connecting to WiFi");
Serial.println("Connected to WiFi network");
Serial.println("IP address");
//SerialGPS.begin(9600, SERIAL_8N1, 16, 17);
//tetapkan peranti sebagai stesen WiFi
WiFi.mode(WIFI_STA);
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
return;
// Register peer
memcpy(peerInfo.peer_addr, broadcastAddress, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
// Add peer
if (esp_now_add_peer(&peerInfo) != ESP_OK){
Serial.println("Failed to add peer");
return;
// Update MPU6050 readings
mpu.update();
moveDetect();
// Get accelerometer and gyroscope data
float AccelerationY = mpu.getAccY();
// Low-Pass filter for MPU6050 acceleration
filteredAccelerationY = alphaLPF * AccelerationY + (1 - alphaLPF) * filteredAccelerationY;
// Perform Unscented Kalman filter update step for accelerometer data
ukfUpdate(filteredAccelerationY);
// Print the estimated position to the Serial Monitor
Serial.print("Estimated Position (Y): ");
Serial.println(positionY, 2);
// Set values to send
myData.id = 1;
myData.positionY = positionY;
// Send message via ESP-NOW
esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
if (result == ESP_OK) {
Serial.println("Sent with success");
else {
Serial.println("Error sending the data");
delay(100);
void moveDetect()
// Read the distance from the ultrasound sensor
float distance = ultrasonic.read();
// Check if the distance is below the threshold
if (distance < wallDistanceThreshold) {
// Stop the motor
analogWrite(enA, 0);
analogWrite(enB, 0);
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
// Optional: Add any other actions you want to perform when the wall is detected
// Move the motor forward (example)
analogWrite(enA, 150);
analogWrite(enB, 153);
digitalWrite(in1, HIGH);
digitalWrite(in4, HIGH);
delay(10); // Adjust delay based on the desired sampling rate
void ukfUpdate(float measurementY) {
// Predict step
float predictedPositionY = positionY + velocityY * dt;
float predictedCovPositionY = covPositionY + covVelocityY * dt + varProcess;
// Generate sigma points
float sigmaPoint1Y = predictedPositionY + sqrt(predictedCovPositionY);
float sigmaPoint2Y = predictedPositionY - sqrt(predictedCovPositionY);
// Apply process model to sigma points
float propagatedSigmaPoint1Y= sigmaPoint1Y + velocityY * dt;
float propagatedSigmaPoint2Y = sigmaPoint2Y + velocityY * dt;
// Calculate predicted measurement mean and covariance
float predictedMeanY = (propagatedSigmaPoint1Y + propagatedSigmaPoint2Y) / 2.0;
float predictedCovMeasurementY = pow(propagatedSigmaPoint1Y - predictedMeanY, 2) + varAcc;
// Calculate Kalman gain
float kalmanGainY = predictedCovPositionY / (predictedCovPositionY + predictedCovMeasurementY);
// Update step
positionY = predictedPositionY + kalmanGainY * (measurementY - predictedMeanY)+0.04;
covPositionY = (1 - kalmanGainY) * predictedCovPositionY;
// Calculate velocity based on updated position
velocityY = (positionY - predictedPositionY) / dt;
//memeriksa keadaan sambungan wifi
if(WiFi.status()==WL_CONNECTED)
HTTPClient http;
String serverPosY = serverNamePosY + positionY;
//nama domain untuk pautan URL atau alamat internet protokol
http.begin(serverPosY.c_str());
//Menghantar HTTP GET request
int httpResponseCode = http.GET();
//Free resources
http.end();
Serial.println("WiFi Disconnected");
Is there anyone who can help me?
