the standard 64 bit math brings in about 5000 bytes and it is all pass by value (8 bytes apiece plus some shifting about). This takes my current project beyond the 14k boundry.
these functions bring in 1214 bytes(I think), and everything is pass by reference
I don't know how fast they are, don't need superfast for my current app.
compared to the LCD pauses, performance probably isn't a big deal,
and I get to stop worrying about scaling my 32 bit functions with a bunch of conditionals ![]()
64 bit numbers are represented as an array of length 2 , [0] is most significant.
I chose array because it is pass by reference and didn't have to make a new type in arduino
also hoping the bits are in contiguous memory if an optimized version materializes
yah, it could be a library, but current project is intended to be simple cut and paste, minimal fuss on the end user. yah there could be more functions, but these are just what I needed and space is already at a premium.
//realized by Dave Brink
unsigned long zero64[]={0,0}; //just for comparisons sake
void init64(unsigned long an[], unsigned long bigPart, unsigned long littlePart ){
an[0]=bigPart;
an[1]=littlePart;
//left shift 64 bit "number"
void shl64(unsigned long an[]){
an[0] <<= 1;
if(an[1] & 0x80000000)
an[0]++;
an[1] <<= 1;
//right shift 64 bit "number"
void shr64(unsigned long an[]){
an[1] >>= 1;
if(an[0] & 0x1)
an[1]+=0x80000000;
an[0] >>= 1;
//add ann to an
void add64(unsigned long an[], unsigned long ann[]){
an[0]+=ann[0];
if(an[1] + ann[1] < ann[1])
an[0]++;
an[1]+=ann[1];
//subtract ann from an
void sub64(unsigned long an[], unsigned long ann[]){
an[0]-=ann[0];
if(an[1] < ann[1]){
an[0]--;
an[1]-= ann[1];
//true if an == ann
boolean eq64(unsigned long an[], unsigned long ann[]){
return (an[0]==ann[0]) && (an[1]==ann[1]);
//true if an < ann
boolean lt64(unsigned long an[], unsigned long ann[]){
if(an[0]>ann[0]) return false;
return (an[0]<ann[0]) || (an[1]<ann[1]);
//divide num by den
void div64(unsigned long num[], unsigned long den[]){
unsigned long quot[2];
unsigned long qbit[2];
unsigned long tmp[2];
init64(quot,0,0);
init64(qbit,0,1);
if (eq64(num, zero64)) { //numerator 0, call it 0
init64(num,0,0);
return;
if (eq64(den, zero64)) { //numerator not zero, denominator 0, infinity in my book.
init64(num,0xffffffff,0xffffffff);
return;
init64(tmp,0x80000000,0);
while(lt64(den,tmp)){
shl64(den);
shl64(qbit);
while(!eq64(qbit,zero64)){
if(lt64(den,num) || eq64(den,num)){
sub64(num,den);
add64(quot,qbit);
shr64(den);
shr64(qbit);
//remainder now in num, but using it to return quotient for now
init64(num,quot[0],quot[1]);
//multiply num by den
void mul64(unsigned long an[], unsigned long ann[]){
unsigned long p[2] = {0,0};
unsigned long y[2] = {ann[0], ann[1]};
while(!eq64(y,zero64)) {
if(y[1] & 1)
add64(p,an);
shl64(an);
shr64(y);
init64(an,p[0],p[1]);
void setup(){
unsigned long a1[]={0x2,0xFFFFFFFF};
unsigned long a2[]={0x0,0x0FFFFFFF};
prt(a1);
mul64(a1,a2);
prt(a1);
div64(a1,a2);
prt(a1);
init64(a2,a1[0],a1[1]);
div64(a1,a2);
prt(a1);
void loop(){}
void prt(unsigned long an[]){
Serial.print(an[0],HEX);
Serial.print(" ");
Serial.println(an[1],HEX);
