unsigned difference
Hello all. I just came across some code involving a time difference, and also involving 'unsigned long' values ---- and I notice an 'AND' operation --- namely : & 0XFFFFL
It has a comment next to it, that says //get unsigned difference.
The line of code is: unsigned long difference = (now - previous) & 0xFFFFL ;
Can somebody help explain the importance (significance) of the "& 0xFFFFL" ? Just trying to understand and learn only.
Thanks very much in advance!
https://forum.arduino.cc/index.php?topic=229667.0
 // then update the long counter
unsigned long difference = (now - previous) & 0xFFFFL ;  // get unsigned difference
Full code:
unsigned long prev_accurate_time = 0L ;
unsigned long total_count = 0L ;
unsigned long prev_count = 0L ;
unsigned long previous_tick = 0L ;
unsigned int previous = 0 ;
void loop ()
  // first perform observation
  unsigned int now = TCNT1 ;
  unsigned long accurate_time = micros () ;
  previous = now ;
  total_count += difference ;
  // check for time passing
  if (millis () - previous_tick >= 1000L)
    previous_tick += 1000L ; // setup for next second.
    // calculate accurate values for the approximate 1s interval, pass to be displayed
    display (total_count - prev_count,
                 accurate_time - prev_accurate_time) ;
    prev_accurate_time = accurate_time ;  // update for next second
    prev_count = total_count ;
It is throwing away all but the lowest 16 bits of the difference.
Regards,
Ray L.
now and previous are 16 bit variables on a standard Arduino.
RayL and Jrem ........ thanks very much! Genuinely appreciated!
You might try removing the &0xFFFFL to see if it makes a difference.
I don't know exactly how the compiler handles the promotion of 16 bit to 32 bit integers, and it might be that the extra operation prevents the sign bit (if set, for a negative difference) from being propagated and filling bits 16-31 of the long integer.
Edit: Scratch that idea.
unsigned int a=0;
unsigned int b=1;
unsigned long c=0;
c = (a-b)&0xFFFFL;
Serial.println(c);  //prints 65535
c = (a-b);
void loop() {}
1. Given the following declarations:
unsigned int now;     //variable 'now' can hold a value from 0 to 65535 (0x0000 to 0xFFFF); 16-bit positive
unsigned int previous = 0;  //same as variable 'now'
unsigned long difference; //'difference' will hold 32-bit data (always positive) from 0 to 4294967295
//(0x00000000 to 0xFFFFFFFF); 0x refers to hexadecimal base
2. The value of the variable 'now' comes from TCNT1 which can hold an unsigned (always positive) number from 0 to 65535 (0x0000 to 0xFFFF). Let us assume that the current content of TCNT1 is 0x8765 (34681) and previous = 0 (0x0000).
3. Let us compute the difference between 'now' and 'previous'.
unsigned int y = now - previous
==> y = 0x8765 - 0x0000
==> y = 0x8765 (decimal 34681)
==> y = 0b1000011101100101   (0b refers to binary base)
4. Let us retain all the bits of y of Step-3 by making bit-wise AND (&) with 1111111111111111 (0xFFFF)
==> y = y & 0xFFFF
==> y = 0b1000 0111 0110 0101 & 0b1111 1111 1111 1111
==> y = 0b1000 0111 0110 0101  (unsigned int)
==> y = 0x8765
5. Let us keep the 'unsigned 16-bit' value of y of Step-4 in an 'unsigned 32-bit' variable named difference. How do we do it?
(1) Enlarge the storage size of y from 16-bit to 32-bit by placing this text '(unsigned long)' before y. This is known as casting. (2) And then store this: '(unsigned long)y' into the variable 'difference'.
unsigned long difference = (unsigned long)y;
==>unsigned long difference = (unsigned long)y & 0xFFFF; //going backward
==>unsigned long difference = (unsigned long)(now-previous) & 0xFFFF;  //going backward
==>unsigned long difference = (now-previous) & 0xFFFFUL;    //UL (not L) is a casting and replaces (unsigned long)
