unsigned long arithmetics problem
Hey folks
i am having a big headache adding number to unsigned long
my code is
static time_t addTime(Time fir, Time oth) {
      unsigned int total = (oth.hours * 3600) + (oth.minutes * 60) + oth.seconds;
      time_t temp = total + fir.stamp;
      return temp;
please help me out
i wanna add total (43200 ) to fir.stamp ( which is of type time_t from timeLib.h ( 948209158 ) ) the answer should be = 948252358 but i get the answer = 948186822
from time library
if !defined(__time_t_defined) // avoid conflict with newlib or other posix libc
typedef unsigned long time_t;
endif
thanks in advance :)
unsigned int total is that part of the problem?
948252358 - 948186822 = 65536 :o
First of all, tell us which time library. There are a few.
Since the function returns a 'time_t', then why not use a 'time_t' ?
time_t temp = (time_t) oth.seconds;
temp += (time_t) oth.minutes * 60UL;
temp += (time_t) oth.hours * 3600UL;
temp += (time_t) fir.stamp;
return temp;
I doubt if you need that code. You want to add the number of seconds since that day to a 'stamp' ? What if the result happens to be in the next day ?
Thanks @koepel it worked flawlessly :D
