unsigned long exit status 1 error
I have this error,
while_trail:11:1: error: expected ‘,’ or ‘;’ before ‘void’
exit status 1
Can you help ?
unsigned long time_last = 0;
int interval_one = 5000; // 5 seconds, 1st while loop
int interval_two = 3000; // 3 seconds, 2nd while loop
int T =1; // Frequency in Hz
int T1= 1000/(2T);
int T2= 2
T1
delay(150);
int ledPin1 = 13; // LED connected to digital pin 13
int ledPin2 = 12; // LED connected to digital pin 12
int ledPin3 = 11; // LED connected to digital pin 11
int ledPin4 = 10; // LED connected to digital pin 11
pinMode(ledPin1, OUTPUT); // sets the digital pin as output
pinMode(ledPin2, OUTPUT); // sets the digital pin as output
pinMode(ledPin3, OUTPUT); // sets the digital pin as output
pinMode(ledPin4, OUTPUT); // sets the digital pin as output
void loop(){
// 1st while loop
time_last = millis(); //obtain reference //1000
while((millis() -time_last) <interval_one){
// time=1/freq for 5 hz time = 0.2 sec = 200 msec
// for 40 hz , time =1/40=0.025 sec = 25 msec = 25000 Microseconds , for 4 valves 6250
// for high freq delayMicroseconds should be used with the limit of 16383
digitalWrite(ledPin1, HIGH); // sets the LED on
digitalWrite(ledPin2, HIGH); // sets the LED on
digitalWrite(ledPin3, LOW); // sets the LED on
digitalWrite(ledPin4, LOW); // sets the LED on
delay(1*T1); // this value = time/number of valves
// 2nd while loop
time_last = millis(); //obtain reference // 10000
while((millis() -time_last) <interval_two){
digitalWrite(ledPin2, LOW); // sets the LED on
delay(1T2); // this value = time/number of valves
digitalWrite(ledPin1, LOW); // sets the LED on
delay(1
while_trail.ino (2.42 KB)
If the compiler tells you
expected ',' or ';' before 'void'
Then there is probably a ';' missing somewhere, usually just where it tells you ...
... and surprise(!) there is a semicolon missing here
int T2= 2*T1
Also, your title does not seem to match the problem you are expressing in the post. Please try to be consistent.
There also seem to be two functions named setup().
