Be careful when you copy/paste from an HTML document. HTML does not copy correctly. You must verify the original and the "pasted" code are the same.
// pinMode( 2, OUTPUT); // change to INPUT_PULLUP
pinMode( 2, INPUT_PULLUP);
// pinMode( 4, OUTPUT); // chenge to INPUT_PULLUP
pinMode( 4, INPUT_PULLUP);
pinMode( 13, OUTPUT);
pinMode( 12, OUTPUT);
pinMode( 11, OUTPUT);
// if (digitalWrite(2) == HIGH) { // this should be digitalRead(2) == LOW, remove semi-colon (;)
if (digitalRead(2) == LOW) { // remove semi-color (;)
digitalWrite(11, HIGH);
delay(2000);
digitalWrite(11, LOW);
digitalWrite(12, HIGH);
delay(2000);
digitalWrite(12, LOW);
delay(2000);
// remove extra braces and stray if else (nothing)
// if( digitalWrite(4)== HIGH); { // this should be digitalRead() == LOW, remove semi-colon (;)
if ( digitalRead(4) == LOW) {
digitalWrite(13, HIGH);
delay(2000);
digitalWrite(13, LOW);
delay(2000);
delay(2000);
digitalWrite(12, LOW); // add this line
// digitalWrite(HIGH); // remove
// if else { // remove
for WOKWI.COM
diagram.json
"version": 1,
"author": "Anonymous maker",
"editor": "wokwi",
"parts": [
{ "type": "wokwi-arduino-nano", "id": "nano", "top": 0, "left": 0, "attrs": {} },
"type": "wokwi-pushbutton",
"id": "btn1",
"top": -41.8,
"left": 163.2,
"attrs": { "color": "green" }
"type": "wokwi-led-bar-graph",
"id": "bargraph1",
"top": -120,
"left": -42.8,
"rotate": 180,
"attrs": { "color": "lime" }
"id": "btn2",
"top": -89.8,
"left": 163.2,
"connections": [
[ "nano:GND.2", "btn1:2.l", "black", [ "v0" ] ],
[ "nano:2", "btn1:1.l", "green", [ "v0" ] ],
[ "nano:GND.2", "btn2:2.l", "black", [ "v0" ] ],
[ "nano:4", "btn2:1.l", "green", [ "v0" ] ],
[ "nano:13", "bargraph1:A1", "green", [ "v14.4", "h-19.7", "v-115.2" ] ],
[ "nano:12", "bargraph1:A2", "green", [ "v0" ] ],
[ "nano:11", "bargraph1:A3", "green", [ "v0" ] ],
[ "bargraph1:C3", "bargraph1:C2", "green", [ "h0" ] ],
[ "bargraph1:C2", "bargraph1:C1", "green", [ "h0" ] ],
[ "nano:GND.2", "bargraph1:C1", "black", [ "v-14.4", "h-163.7" ] ]
"dependencies": {}
