unstable analog inputs
Hey Guys
hope u are all having a good weekend
ive been trying to modify some code to build a soft of home automation system.
but im seeing some very unstable analog inputs
and i cant realy find why
im using the ethernet shield and the sensor shield and 2 lm35 sensors boards from dfrobot
when refreshing the page or enabling outputs the temperature vallues wil change slightly
#include <LED.h>
#include <WString.h>
#include <Ethernet.h>
#include <avr/pgmspace.h>
prog_char string_0[] PROGMEM = "";
prog_char string_1[] PROGMEM = "<tr><td><input type=submit name=b1 value=Led1></td><td>";
prog_char string_2[] PROGMEM = "<tr><td><input type=submit name=b2 value=Led2></td><td>";
prog_char string_3[] PROGMEM = "<tr><td><input type=submit name=b3 value=Led3></td><td>";
prog_char string_4[] PROGMEM = "<tr><td><input type=submit name=b4 value=Led4></td><td>";
prog_char string_5[] PROGMEM = "<tr><td><input type=submit name=b5 value=Led5></td><td>";
prog_char string_6[] PROGMEM = "<tr><td><input type=submit name=b6 value=Led6></td><td>";
prog_char string_7[] PROGMEM = "</form>";
prog_char string_8[] PROGMEM = "<img src=data:image/gif;base64,R0lGODlhEAAQAKIAAAD/AACGAISGhMbHxv///wAAAAAAAAAAACwAAAAAEAAQAAADUEiq1b6QNEHFGC2W6srFyyY0QAk0V8GM5WJ6qlgA7ptuc20GME4TplKAJ/EBg4BhDIYUKosp5JAokWB2U6LKiilkM1XGpxPSeAYQcKRIhiQAADs= alt=On ></td><td>";
prog_char string_9[] PROGMEM = "<img src=data:image/gif;base64,R0lGODlhEAAQAKIAAP////f398DAwICAgAAAAAAAAAAAAAAAACwAAAAAEAAQAAADTRiq1L4wtEGHEC2S6sjFyzY0H+aB0ngB7OcRqcoC5Tl5cymot9CWFAKgR9MFhy/dhYO8nD7MoQQDrYykU5O1wYIxXI6ZN3SaISPkTiQBADs= alt=Off ></td><td>";
prog_char string_10[] PROGMEM = "";
PROGMEM const char *string_table[] = // change "string_table" name to suit
string_0,
string_1,
string_2,
string_3,
string_4,
string_5,
string_6,
string_7,
string_8,
string_9,
string_10
char buffer[400]; // make sure this is large enough for the largest string it must hold
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 15 };
byte gateway[] = { 192, 168, 1, 1 };
byte subnet[] = { 255, 255, 255, 0 };
String inString = String(35);
Server server(80);
LED led1 = LED(2);
LED led2 = LED(3);
LED led3 = LED(4);
LED led4 = LED(5);
LED led5 = LED(6);
LED led6 = LED(7);
LED led7 = LED(8);
LED led8 = LED(9);
String msg="";
int tam=0;
int st1=9,st2=9,st3=9,st4=9,st5=9,st6=9,st7=9,st8=9;
Ethernet.begin(mac, ip,gateway,subnet);
server.begin();
long tmp;
Client client = server.available();
int led=0;
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if we've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so we can send a reply
if (inString.length() < 35) {
inString.append(c);
if (c == '\n' && current_line_is_blank) {
if(inString.contains("b1")){
led1.toggle();
if(led1.getState()) st1=8;
else st1=9;
led=1;
if(inString.contains("b2")){
led2.toggle();
if(led2.getState()) st2=8;
else st2=9;
led=2;
if(inString.contains("b3")){
led3.toggle();
if(led3.getState()) st3=8;
else st3=9;
led=3;
if(inString.contains("b4")){
led4.toggle();
if(led4.getState()) st4=8;
else st4=9;
led=4;
if(inString.contains("b5")){
led5.toggle();
if(led5.getState()) st5=8;
else st5=9;
led=5;
if(inString.contains("b6")){
led6.toggle();
if(led6.getState()) st6=8;
else st6=9;
led=6;
if(inString.contains("msg")){
strcpy(msg,inString.substring(inString.indexOf("g")+2,inString.indexOf(" H")));
//Serial.print("msg: ");
//Serial.println(msg);
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
          //Scrivo l'intestazione
          client.println("<html>");
          //client.println("<META http-equiv=REFRESH content=3; url=/ >");
          client.println("<style> a:link{font:8pt/11pt verdana; color:red} a:visited {font:8pt/11pt verdana; color:blue} body {font:8pt/11pt verdana; color:black; background-color:white} </style>");
          client.println("<title>Home Automation </title>");
          client.println("</head>");
          client.println("<body>");
          client.println("<img src=http://members.quicknet.nl/m.vos2/logo.gif></td><td>");
          client.println("<font size= 4><form method=GET>");
client.println("  ");
client.print("Temp 1 is ");
analogReference(DEFAULT);
delay(10);
tmp=((long)analogRead(0)*5000)/1024;
client.print(tmp / 10);
client.print(".");
client.print(tmp % 10 );
client.print(" C");
client.println("
client.print("Temp 2 is ");
delay(10);
tmp=((long)analogRead(1)*5000)/1024;
client.print(".");
client.print(tmp % 10);
client.print(" C" );
client.println("<P>
client.println("<table width=100>");
strcpy_P(buffer, (char*)pgm_read_word(&(string_table[0]))); // Necessary casts and dereferencing, just copy.
client.println( buffer );
for (int i = 1; i < 8; i++)
strcpy_P(buffer, (char*)pgm_read_word(&(string_table[i]))); // Necessary casts and dereferencing, just copy.
switch(i){
          client.println("B");
case 1: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st1]))); client.println( buffer ); break;
case 2: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st2]))); client.println( buffer ); break;
case 3: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st3]))); client.println( buffer ); break;
case 4: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st4]))); client.println( buffer ); break;
case 5: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st5]))); client.println( buffer ); break;
case 6: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st6]))); client.println( buffer ); break;
delay(30);
          client.println("</table>");
          client.println("<a href=/>Refresh</a>");
          client.println("</body>");
          client.println("</html>");
if (c == '\n') {
// we're starting a new line
} else if (c != '\r') {
// we've gotten a character on the current line
current_line_is_blank = false;
// give the web browser time to receive the data
delay(1);
inString = "";
client.stop();
First thing I noticed is two calls to analogReference, with an argument of DEFAULT. Since this is the default setting, this function does not need to be called at all.
Slightly as in 1 degree, or slightly as in 10 degrees? The lm35 is rated at +/- 0.5 degrees C.
Does the LED library set the pinMode?
wel it varies between .5 and 2,5 degrees
The LM35s need a rock solid analogue reference voltage to give repeatable results, its more than possible the voltage swings a bit when accessing stuff via the ethernet shield because its quite a power hog. How are you powering the board/shield ?
wel currently its running on usb power. but the results are the same when powering the board from my lab psu
